Old 03-16-2009, 09:03 AM   #51
87 dually burb
my short bus
87 dually burb's Avatar
Re: you want to change your 5X5 bolt pattern on 73-87 disc to 5X4.75
http://www.classicperform.com/Store/...ruck/CP4R5.htm
here is one way
**90 burb**bagged,shaved**(about done)*********
**91 burb**stock worker for now****************
*********only squares for me******************
87 dually burb is offline   Reply With Quote
Old 10-05-2010, 06:44 PM   #52
1942
Is this spindels the 73-80 style or 81-87 style?
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=55
Looks like great stuff this!
1942 is offline   Reply With Quote
Old 02-19-2011, 11:21 PM   #53
78-5.3
78-5.3's Avatar
do they make an aftermarket disc with the 4.75 bolt pattern for the C10
78 C-10 5.3 LSX -4L60E
78-5.3 is offline   Reply With Quote
Old 02-20-2011, 01:47 AM   #54
78-5.3
78-5.3's Avatar
i couldnt find them on that site is do they suit a 78 model ?
Old 02-20-2011, 05:13 AM   #55
78-5.3
78-5.3's Avatar
I Googled them,... and it brought me back here to this thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=388794
Here's the link to POL's website:
http://www.performanceonline.com/DIS...K-5514/?page=1
thanks lowlife99, i apeciate that save me alot of timeand cash with the camaro disc conversion
i have the 1.25 hd disc with 3" DJM DROPPED spindles and i wanna runn my weld pro star rims on the front!!
Old 02-21-2011, 06:51 PM   #56
crazy longhorn
Fabricate till you "puke"
I called & had the tec spec the 5514 rotor out, as I plan the same boltpattern swap on my 69. The 5514 is a car rotor(11 diam x 1 thick). It is used to run the camero brakes on the old drum spindles,along with a set of brackets, but not a bolt on replacement for the heavy truck rotor(dang!) just passing the info,crazyAl
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-21-2011, 10:33 PM   #57
lolife99
67-72 parts collector,…
lolife99's Avatar
Sorry for giving out wrong info.
They should spell that out on their website.
I apologize.
Keith
Convert to disc brakes.
Old 02-21-2011, 11:03 PM   #58
lolife99
lolife99's Avatar
I search POL and CPP's website.
It appears the 5x4.75" rotor are for the 11" 69-74 chevelle rotors (thanks crazy longhorn) that use a custom bracket that attaches to a 63-70 "drum brake" front spindle.
These require a 69-72 Camaro caliper.
CPP's complete kit, (part# 6370WBK-5) is $375.00.
Or just the bracket kit for $119.00. Part#6370DBK
Again sorry for the confusion I caused.
Keith
Old 02-21-2011, 11:15 PM   #59
N2TRUX
Happy to be here
N2TRUX's Avatar
I apologize.
Considering all the great info you provide on here, I think we can let this one slide...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-21-2011, 11:27 PM   #60
crazy longhorn
What the hey.....we are all just working together to find the better way to our "Madness" I dont really want to change spindles & all....so I guess that leaves me to redrill my rotors crazyL
Old 02-25-2011, 11:57 PM   #61
78-5.3
78-5.3's Avatar
like crazy longhorn i dont wanna change my spindles how hard would it be to redrill the spindles , and done correctly how safe???
Old 08-15-2012, 01:03 AM   #62
Boosted1984Silverado
Hola gents!
I've read over this thread a few times before joining this forum and am still somewhat confused on this topic. I have a 1984 1/2 ton Silverado. Will the 91 Camaro 1LE performance rotors fit my set up? It's currently a 5x5 and I am really trying to get it to a 5x4.75. Thanks.
Boosted1984Silverado is offline   Reply With Quote
Old 08-15-2012, 02:04 AM   #63
Also wanted to know if I could use these drop spindles with the 91 Camaro rotors.
http://www.ebay.com/itm/400140456280...84.m1423.l2649
The end result I am looking for is to safely get my 84 Silverado to a 4.5 inch pattern with about a 2" drop and that I can use with a 15" wheel. HELP!
Old 08-15-2012, 07:59 AM   #64
gringoloco
A guy with a truck
gringoloco's Avatar
Yes, those spindles, designed for 1" thick rotors, will allow installation of the 5x4.75 camaro 1LE rotors. Post some pics here when you get them on!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-15-2012, 02:12 PM   #65
Thanks for the response gringoloco. I really appreciate it and I will definately repost before and after pics. Gonna rebuild the entire front end while I'm replacing the spindles and installing the new rotors!
Old 08-16-2012, 08:56 AM   #66
N2TRUX
Happy to be here
N2TRUX's Avatar
I dont think those brakes will work with 15" wheels. Talk to way2low2 for advice on what will work.
Articles-
"Refining Sierra"
Old 08-16-2012, 10:28 AM   #67
gringoloco
A guy with a truck
gringoloco's Avatar
The 88-92 Camaro 1LE (Heavy Duty) rotor is the exact same blank as the 81-87 light duty truck rotor, which is the same part number as the 78-92 B-body 'big car' 5x5 rotor and will accept the factory light duty truck calipers in the factory position on the truck spindle. The F-body rotor has the same 11.88x1.1" dimensions and bearings as the truck rotor, just with a 5x4.75 bolt pattern instead of 5x5. Upgrading to B-body spindles w/ 1LE rotors is a common practice on GM cars with short spindles-- they gain the camber benefits of the tall spindle and upgrade from 10.5" to 12" rotors. This swap simply capitalizes on the GM pars bin mentality- the only difference between this setup and a 'normal' truck brake setup is the rotors.
All of that to say this: He should only have the same possibility of lower control arm clearance issues that all lowered 63-87 trucks have when using drop spindles with 15" wheels, depending on wheel backspacing.
-Chris
Old 08-16-2012, 10:58 AM   #68
N2TRUX
Happy to be here
N2TRUX's Avatar
Its been a while since I played with Camaro stuff, but I remember when there was a big interest in converting to 1LE brakes. Now that I think about it there was one guy that managed to massage them to fit in the stock 15" Camaro wheel. Most everyone else upgraded to the 16"+ IROC wheels and solved the issues.
Articles-
"Refining Sierra"
Old 08-16-2012, 11:08 AM   #69
gringoloco
A guy with a truck
gringoloco's Avatar
Ah, I see- now we're tracking Yes, small diameter car wheels will be very close with the bigger rotors and calipers. As with all custom setups, measure once--cut twice!
-Chris
Old 08-16-2012, 11:28 AM   #70
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by gringoloco View Post
...I've been researching this a little. It looks like the aftermarket C5 upgrade brackets might work on the light duty spindles. That is, if the dust shield/backing plates interchange between big car/light truck, then a bracket may already exist to adapt the 'Vette stuff.
More to come when I get some time...
...and to add fuel to the fire- I have found some time/money to play with this, so C5 may be coming very soon. Pics if it works
-Chris
Old 08-16-2012, 11:06 PM   #71
gringoloco
A guy with a truck
gringoloco's Avatar
Got some parts today-early measurements say it's gonna work More to come...
-Chris
Old 08-18-2012, 10:46 PM   #72
Gringoloco-
My backspacing on my 15" Centerlines is 1.5 inches at best. They are the 15x3 Convo Pros. So I shouldn't have any issues with the 91LE rotor and those drop spindles I linked right? Thanks again.
Old 08-19-2012, 12:58 AM   #73
gringoloco
A guy with a truck
gringoloco's Avatar
I wouldn't think so, but convos are drag wheels which aren't generally known for having great brake clearance. Maybe check around the F-body forums to see if anyone is running that combo...
-Chris
Old 08-19-2012, 01:48 PM   #74
Gents,
Instead of ordering drop spindles could I just replace the front springs instead or cut the ones I have now to lower it a couple of inches? I know it will probably change the geometry a little bit and make the ride a little different but I have seen front spring lowering kits and just wanted to get your opinions. Thanks.
Old 08-23-2012, 12:38 PM   #75
Guess I can do both do achieve a drop of greater than 2.5 inches. Will post pics soon.
