Old 10-01-2012, 03:06 PM   #51
eagleuh1
eagleuh1's Avatar
Re: 1968 C10 5.3 swap, the easy way.
What AC condensor did you use?
eagleuh1 is offline   Reply With Quote
Old 10-02-2012, 11:13 AM   #52
faribran
tell me more about what you have determined works with the fuel system..
faribran is offline   Reply With Quote
Old 10-02-2012, 04:45 PM   #53
eagleuh1
eagleuh1's Avatar
I used a Boyd Welding aluminum tank with in tank pump. Used summit AN 90's coming out of tank and AN tube nuts with 3/8 aluminum tubing and summit AN to quick connect to connect to Corvette filter regulator. I mounted all this to top of tank. From filter/reg I used fuel repair tube from auto zone. Grazed on AN fitting and connected short section of braided stainless fuel line to 3/8 steel fuel line along frame rail. Used another 1 1/2 foot section of braided to connect to fuel rail on engine with russel fitting. Good luck. Jim
Old 10-02-2012, 06:10 PM   #54
vannatta20
vannatta20's Avatar
44-1425DR 14 X 25 Superflow Condenser With Drier Mounted $134.99 from Nostalgic Air Parts
vannatta20 is offline   Reply With Quote
Old 10-02-2012, 06:14 PM   #55
vannatta20
vannatta20's Avatar
I agree to use the boyd welding EFI tank. What I am going to to is use the non efi tank and cut a hole and drop in a LS1 Fuel pump assembly to save money and use the factory quick disconnects. I get the fuel pump ass. used off ebay for 50$. My intake has a built in FPR so I had to tun a return line back to the tank and ran a generic fuel filter in line that uses quick disconnects.
Old 10-02-2012, 06:15 PM   #56
vannatta20
vannatta20's Avatar
Heres a vid of it. Its my daily driver now.
Old 10-02-2012, 06:45 PM   #57
eagleuh1
eagleuh1's Avatar
Cool. Didn't see what year engine you used. I just got mine running on the Boyd tank about 2 weeks ago. Had been running with a frame mounted pump under driver seat. Took suction from in cab tank with a return from the filter regulator run back to a modified stock sending unit. Kept getting pressure buildup in tank and fumes in cab. Guessing from fuel heating up. New o-ring in sending unit didn't fix it. Like that your AC runs cold. Will be swapping out my condensor when get done with my current job. Appriciate that link.
Old 10-05-2012, 06:48 PM   #58
vannatta20
vannatta20's Avatar
Drove 200 Miles yesterday and got 19.5 mpg. Thats awesome as I was driving 75 mph the entire time.
Old 10-05-2012, 07:16 PM   #59
vannatta20
vannatta20's Avatar
Old 10-21-2012, 02:32 AM   #60
faribran
I am impressed...keep up the good work...I like
Old 10-21-2012, 01:04 PM   #61
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Originally Posted by vannatta20 View Post
Better catch that big plastic box on the drivers inner fender....looks like its sliding off!
j/k
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-24-2013, 11:15 AM   #62
solidaxel
solidaxel's Avatar
Any more changes, updates or "issues"!!
Thanks for the detailed build.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-26-2013, 09:48 AM   #63
502ms
502ms's Avatar
Awesome! I got my lq4 couple of weeks ago...my t56 came in on Monday. I wanted to see if you like the dirty dingo mounts, and do they work with what is on the frame now, or what else do I need? Would you mind posting the link of the ones you got? I noticed that their site does not really show one for just 67-72 trucks.
Also, what intake did you use?
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 01-27-2013, 09:28 PM   #64
Roostboy102
Roostboy102's Avatar
I'll answer for him. You need the 73-87 factory truck frame to crossmember mounts and then order the 73-87 dingo mounts. Just got both for my swap and it's very straight forward.
72 C10 - Multicolor, 4.8 ls, NV3500. Sold
72 K5 - Under Construction
Roostboy102 is offline   Reply With Quote
Old 01-31-2013, 01:56 AM   #65
ivorton74
ivorton74's Avatar
this is how I want my swap to be...nice and simple. im gonna use this as my inspiration for my 74. im just concerned about the wiring and fuel system.
ivorton74 is offline   Reply With Quote
Old 01-31-2013, 09:17 AM   #66
solidaxel
solidaxel's Avatar
YES, those two items MUST be addressed, just throw more money at the problem, easy fix !!!
LS 3 4L70E
Old 02-24-2013, 01:24 AM   #67
slamed67
slamed67's Avatar
awesome build.. im attempting a 2001 5.3 swap into my 67 c10.. just got the complete engine, trans, harness, & ecm today.. im nervous. i hope it goes in as easy as you make it look! lol
slamed67 is offline   Reply With Quote
Old 02-25-2013, 04:25 AM   #68
vannatta20
vannatta20's Avatar
I've been deployed for the last 5 months and haven't been on the forums. Big update! My truck now has new paint! Baby blue and white. When I get home ill do a step by step how to for a budget fuel system.
Old 02-25-2013, 04:38 AM   #69
vannatta20
vannatta20's Avatar
Old 02-25-2013, 04:45 AM   #70
slamed67
slamed67's Avatar
wow!!!! man i am inspired!
Old 02-25-2013, 04:46 AM   #71
vannatta20
vannatta20's Avatar
We used the boyd welding carb tank and simply dropped in a LS1 fuel assembly I got off ebay for 50$ It works great and was simple to do. The tank also came with a fuel sender so my fuel gauge will work properly now. My dad made the truck a short bed. I bought new bedsides to help with that and they shorted the frame. Found a deal on TTII rims in 18x8 and will be installing those shortly. The rest of the truck should be finished and assembled next week some time. We used a single stage paint.
Old 02-25-2013, 04:47 AM   #72
vannatta20
vannatta20's Avatar
Old 03-17-2013, 12:18 AM   #73
19GMC66
19GMC66's Avatar
Very cool build...any new pics of the truck with paint and wheels
19GMC66 is offline   Reply With Quote
Old 03-19-2013, 08:30 AM   #74
vannatta20
vannatta20's Avatar
Here is the latest updates. It will be completed in about 2-3 weeks. Getting all wheel disc brakes and coverted to 5 lug for the new wheels. I am still deployed..When i get back very soon ill help finish it up and drive it from Missouri to new mexico
[ATTACH]Name:  883503_605753222773664_303114477_o.jpg
Size:  32.6 KB[/ATTACH]
Old 03-19-2013, 08:33 AM   #75
joesgreen67
joesgreen67's Avatar
[QUOTE=vannatta20;5956715 I am still deployed..[/QUOTE]
Thank you for your service!
joesgreen67 is offline   Reply With Quote
