Old 03-31-2012, 11:35 PM   #1
vannatta20
vannatta20's Avatar
1968 C10 5.3 swap, the easy way.
This is my second LSx swap. First was in the 68 firebird. I learned a lot and wanted to do a simple and affordable swap in my 68 and make it
my daily driver. (This was my only vehicle at the time) I have been trying to use as many factory parts as possible. I did all this in my garage
and driveway with very limited amount of tools. I borrowed a engine
hoist and stand from a friend and got to work. I removed the front end as an entire assembly which is very easy to do. Next I mocked up the
engine with all the accy's on including the a/c. Everything to fit which is great because the accy drives from a fbody or any
other platform cost alot to convert too. I fitted it with the included truck exhaust manifolds but I had to notch the frame. I ended up using
camaro LS3 exhaust manifolds which fit great and no notching is needed. I got them for 80$ used.
Next I bolted on the engine and frame mounts. i drilled new holes for the 73-87 truck frame mounts and
bolted them down. The driveshaft seemed like it would fit without being modified but it was tough to move the engine forward just using a
engine hoist by myself. I ended up using a ratcheting tie strap tied to the engine and frame. I just ratcheted the engine forward until the drive
shaft could be installed to the rear end. The mounts have a few inches to adjustablility which is great. Below are my costs.
Engine with all accy including computer. 600$ 130000 miles
Tranny, got lucky my dad had an extra 4l60E with low miles. Free
2001 Camaro fuel tank with fuel pump, radiator and e fans. 200$ (Edit Do not use a camaro radiator. It will overheat due to not enough cooling capacity for the
heavier trucks) A stock replacement worked great for me off of ebay.)
Engine mounts 120$
Ls3 exhaust manifolds (80$)
Radiator hose (25$)
Wiring harness. It came with the engine. To save alot of $$ reuse it. Its basically a stand alone. Its ugly and needs to have everything
mounted in the same position of the vehicle it came off of. PCM and battery needs to be mounted on the drivers side. fuse block wiring info http://www.lt1swap.com/underhoodfuseblock.htm
All wiring related info can be found on lt1swap.com
How I kept it simple. Used dirty dingo adjustable mounts for mid to late 80's GM trucks. They have 2 inches forward and back adjustability. Next I got frame mounts for free from the same era of trucks.
[ATTACH]Name:  DSC01430.jpg
Size:  58.1 KB[/ATTACH]
The engine mount on the left is the factory inline 6.(not used in swap) The mount on the right is a late 70's clam style mount(both l and r used
in swap. This pic is used to show the difference between mounts.
I usually have a extra PCM or two for sale. I will put a base tune with vats deleted and all emission related junk. PM for details.
vannatta20 is offline   Reply With Quote
Old 03-31-2012, 11:43 PM   #2
vannatta20
vannatta20's Avatar
Re: 1968 C10 5.3 swap, the easy way.
more
Old 03-31-2012, 11:45 PM   #3
vannatta20
vannatta20's Avatar
Name:  2012-03-27 18.49.12.jpg
Old 03-31-2012, 11:50 PM   #4
vannatta20
vannatta20's Avatar
Goods news My factory drive shaft slid right into the tranny and is the correct length! I adjusted the motor foward/back to get it to work with the tranny. Factory 5.3 exhaust manifolds fit with some minor trimming of the frame. Factory a/c fits but the a/c lines would need some work to fit around the frame. Tomorrow will be the first start and will post more pics.
Old 04-01-2012, 12:18 AM   #5
vannatta20
vannatta20's Avatar
Engine start a few weeks ago just on a stand
Old 04-01-2012, 01:04 AM   #6
gringoloco
A guy with a truck
gringoloco's Avatar
Nice! That is the easy way. How far forward is your engine? What trans did you remove? Good work so far
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-01-2012, 09:02 AM   #7
Indian113
Indian113's Avatar
Thats sweet!! I like what your doing and how your doing it. Keep us posted.
Indian113 is offline   Reply With Quote
Old 04-01-2012, 09:23 AM   #8
vannatta20
vannatta20's Avatar
Good question on the tranny. I had a factory 3 speed manual. The engine sits more to the rear. Ill take some pics. I am using the factory wiring harness and fuse box.
Old 04-01-2012, 10:45 AM   #9
gringoloco
A guy with a truck
gringoloco's Avatar
She sounds like a thumper. Stock cam?
-Chris
Old 04-01-2012, 08:32 PM   #10
vannatta20
vannatta20's Avatar
Stock cam just sounds mean with no exhaust.
First start today installed in the truck!
Old 05-03-2012, 08:36 PM   #11
vannatta20
vannatta20's Avatar
Its a driver
Old 05-03-2012, 11:31 PM   #12
ls1nova71
ls1nova71's Avatar
Nice! I like it, but I think I would have added power steering. Oh, and loose the clutch pedal.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-04-2012, 01:48 AM   #13
v62go
i like your choice in music....
v62go is offline   Reply With Quote
Old 05-04-2012, 10:11 AM   #14
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Check out Doc's Blocks for the AC manifold/lines that will work for you.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-04-2012, 10:20 AM   #15
orngsikL
orngsikL's Avatar
motivation!
build thread - 1972 C/10 "Ethyl"
1974 C/10 " Paw Paw"
C/10 Club Louisiana
instagram -
@esso_c10
@projectpawpaw
orngsikL is offline   Reply With Quote
Old 05-04-2012, 03:17 PM   #16
vannatta20
vannatta20's Avatar
I got a underdash a/c from a friend for 40$. Going to plumb up the system next week and test it out. If it doesnt cool well enough I will the the vintage air gen 4. Any one have a cheap set of auto pedals?
Old 05-04-2012, 05:51 PM   #17
mooseknuckles
mooseknuckles's Avatar
those are sweet guages!
mooseknuckles is offline   Reply With Quote
Old 05-04-2012, 06:10 PM   #18
gringoloco
A guy with a truck
gringoloco's Avatar
A basic cluster is 3-hole and will fit your gauges perfectly. You can remove the clutch pedal
-Chris
Old 05-04-2012, 08:07 PM   #19
vannatta20
vannatta20's Avatar
I ordered a billet insert for my dash that is 3 gauges only. Prob is it didnt fit at all? http://www.classicparts.com/1969-72-...tinfo/24-194B/
its about a 1/2 inch to wide. I am going to return it and get the basic 3 gauge panel. How can I remove the clutch pedal? Looks like pivot rod is welded to it. I could take the angle grinder to it...
Old 05-04-2012, 08:12 PM   #20
vannatta20
vannatta20's Avatar
its about a 1/2 inch to wide. I am going to return it and get the basic 3 gauge panel. How can I remove the clutch pedal? Looks like pivot rod is welded to it. I could take the angle grinder to it... Also whats the easiest way to plug the gas cap hole. How can I get the gas cap in there and make it stay put?
Old 05-04-2012, 08:58 PM   #21
faribran
tell me about those gauges...what brand and where do i get them? they appear to work with the LS engine??
faribran is offline   Reply With Quote
Old 05-04-2012, 09:07 PM   #22
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
if the cab gas tank isn't worth saving you could drain it, clean it out, and cut the filler neck off and make a bracket to hold it in place. Then put the cap on and leave it.
Or....fill it with a piece of metal and weld it in, use some filler, and a little primer and your done. You can buy the precut metal piece at various dealers selling parts for these trucks...or make your own.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-04-2012, 09:12 PM   #23
vannatta20
vannatta20's Avatar
Cheap autometers
Amazon.com: Auto Meter 1699 Old Tyme White... Amazon.com: Auto Meter 1699 Old Tyme White...tach
Amazon.com: Auto Meter 1388 Arctic White/Red PTR... Amazon.com: Auto Meter 1388 Arctic White/Red PTR...Electric speedo
quad gauge I paid 90$ amazon mis priced it though....
Amazon.com: Auto Meter 1210 Old Tyme White II... Amazon.com: Auto Meter 1210 Old Tyme White II...
Old 05-05-2012, 12:03 AM   #24
gringoloco
A guy with a truck
gringoloco's Avatar
The clutch pedal and rod should come out, but you'll have to drop the column and pedal assembly. I've seen where guys will use a piece of flat bar and a carriage bolt through the filler cap to sandwich it in place, if that makes sense. What did you do for a tank?
-Chris
Old 05-05-2012, 12:35 AM   #25
vannatta20
vannatta20's Avatar
My fuel tank is a hot mess. I tried a LS1 camaro fuel tank and that did not fit at all underneath my bed. The tank is now im my bed tool box... Going to get a custom tank and house the LS1 fuel pump assembly.
