03-03-2013, 02:22 PM | #276 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Re: My Unexpected '66 SWB-Fleet-Restomod Project!
Well I finished my heater control knobs the other day....I'm thinking of it as jewelery for the old girl.
I didn't have my camera with me so shot some random pics with the phone. I wasn't sure how good the quality would be, and was surprised. If I would have known they would be this good, I would have taken more pics! It all started when I was modifying the heater controls so that I could remove the front bezel to paint or polish to match my dash. I got started by center-drilling all of the riveted areas, and grinding the heads off. Then I drilled all of those spots & tapped them for a #6-32 screws. It worked perfectly! once that the unit was disassembled, I cleaned it up and sandblasted & painted the sheet-metal bracket & reassembled the unit...It still looked boring! Nice, but boring. BTW this heater control is not from my truck, as mine had a heater delete plate in the dash. A friend happened to have this laying around for some unknown reason, and gave it to me. Hence it why it has cut cables & wires. I plan on using it to control a vintage air unit somehow...I WILL figure a way to make it work.
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
03-03-2013, 02:24 PM | #277 |
And now, without further adieu, on to the fabrication of the heater control knobs!
I started with a piece of aluminum big enough to yield 5 knobs from, in order to have a backup plan for screwing up a few in the process. NOTHING ever goes as planned in your mind! Once that I was pleased with the profile of the knob shape, I drilled & tapped #10-24 holes in the bottom of the knob profile that would be used to retain the knobs onto the levers of the control. Then, through the center of each tapped hole I milled a 3/32" slot for the control lever to fit into. So as you will see, the threads on each side of the slot hold the setscrew that retains the lever. Pretty simple really...NOT! Once that all of this was completed, I separated the knobs from the workpiece by sawing them & machining the sawed surfaces to size. I then milled a groove into the face of them with a 3/16" ball nosed cutter, and polished the individual knobs! I didn't even screw one up!...yet.
03-03-2013, 02:30 PM | #278 |
And now, on to the pics of the finished product!...The bezel still needs to be painted to match my dash, of course.
03-03-2013, 02:47 PM | #279 |
I'm just glad to be here!
Very nice!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
03-03-2013, 02:56 PM | #280 |
Here! Here! I'd buy a set!
03-03-2013, 02:59 PM | #281 |
How in the world have I missed this thread?
Very nice work! I am blown away by your fabrication skills. Also, I love the color.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
03-03-2013, 09:06 PM | #282 |
wow those are awesome, great work.. now there's 3 things
my 65 fleetside build http://67-72chevytrucks.com/vboard/s...d.php?t=442370 big back glass conversion http://67-72chevytrucks.com/vboard/s...dow+conversion |
03-03-2013, 09:16 PM | #283 |
chevy only
WHOA!!! NICE WORK KAT!! you need to produce those and all the knobs for the switches and shifter and the the indicator for the colum.... cool stuff
CHEVY ONLY... Nothin Else ! |
03-03-2013, 09:27 PM | #284 |
WOW very nice . you have mad skills!!!!!!
03-03-2013, 10:04 PM | #285 |
Great skills man, came out really great
03-04-2013, 08:14 AM | #286 |
Color combo is great, Skills Awesome, keeps getting better, then Modge drops the milling machine on us....OUCH. Scoot over Billet...Modge-it ....Great build can't wait to see whats next.
03-04-2013, 08:42 AM | #287 |
top notch... ash tray and heater knobs. whats next???
03-07-2013, 11:27 PM | #288 | |||
Thanks Man, I figured that I had about 8 extra hours of time to spare, and what better way to waste it!
Ha-Ha-Ha! Most of the time I feel that it is the things that you can't buy which make a real custom! Quote:
Ha-Ha-Ha-Ha!...Thanks, maybe you do need to PM me your address! Quote:
Thanks, but it is still a lot of work,....with good rewards though! Thanks, I try hard, & sometimes I get it right! Quote:
Thank you much!....I still got a few tricks up my sleeve!
03-08-2013, 07:17 AM | #289 |
Wow, that looks awesome! Nice job.
My frame Layin 63 short bed project http://67-72chevytrucks.com/vboard/s...d.php?t=551353 |
03-14-2013, 09:09 PM | #290 | |
I sent some stuff out to a local plater for zinc coating on some small stuff. We'll see how it turns out...I'll post some pics.
03-14-2013, 11:26 PM | #291 |
Ok I totally showed your heater knobs to the wife because she could not understand some of the words I was using and the attitude....
She thinks it is awesome. I think you are just showing off now !!! On the other hand, man that really is cool work, and like Dino said, a full matching set of accessories would be pretty amazing! Let me know when you get your Gold Account so I can put my order in !!
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
03-15-2013, 12:28 PM | #292 | |
Those words coming from a master of it??? Am I missing something here? So, I'm guessing that you post pics purely for educational purposes! ha-Ha-Ha!... Well, so do I! Problem is, this stuff turned out so good, that every passer-by is gonna think that I bought it. I just thought to my self that if I am gonna waste 8-plus hours doing something crazy-stupid, it might just as well be this!!! Keeps me from sitting in front of a TV!
03-15-2013, 04:37 PM | #293 |
There is potentially a large market for those knobs, most people don't like the plastic ones and billet is a big seller. Just a thought...Vernski
03-15-2013, 04:42 PM | #294 |
GMC's n H.D.'s too!
I'd be in for a set of 4 heater knobs IF you go that way!
Awesome thread!! |
03-15-2013, 06:04 PM | #295 |
Very impressive knobs you have sir.....
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
03-15-2013, 07:05 PM | #296 |
GMC's n H.D.'s too!
Forgot my sons truck needs knobs too, id be down for 7 knobs!
Posted via Mobile Device |
03-15-2013, 07:18 PM | #297 |
Late to the party... Subscribed, Loving the color combo and Sick Skillz only scratches the surface! Great job!!!
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
03-15-2013, 11:32 PM | #298 |
ashtray and heater knobs look killer, i agree with flips i would like a set too! i think you would be able to sell them atleast on here, they would sell like hotcakes, lol!!
my project: http://67-72chevytrucks.com/vboard/s...d.php?t=456163 |
03-16-2013, 01:56 AM | #299 |
I was posting on Bomps thread today that we really need to get you on the video band wagon !!
The stuff you are making is awesome ! I know I would love one of those ashtray handles, though I dont need the heater knobs.... sorry ..... Ok Pot, this is the Kettle apologizing.... LOL
03-16-2013, 04:22 AM | #300 |
sooooo...I'm going to need a set of a/c knobs, headlight knob, wiper knob and matching knob for the gauge dimmer switch from dakota digital. where can i sends the paypal monies???
66 SWB Stepside: Project C-O6 06 ZO6 MSM 6spd 562/520rw N/A 06 Caddy CTS The Daily 07 Hayabusa - absolute chaos |
