07-10-2013, 04:15 PM | #1 |
Modify Upper control arms?
I need help. Understand from the start that your talkin to a dummy. I have this 71 2wd that I bought with air bag suspension. I took the front bags out and put in 2" drop springs with dropped spindles. Had some play in the steering so I replaced the steering box, tie rods, lower control arms (PO had been dragging the ground with them), pittman arm, & idler arm. Hey, everything was 40+ years old. I take it to the local shop for an alignment. They say the left front has about an inch of shims and needs another inch of shims. Too many shims. They suggest I get a modified (longer) upper control arm. They say if I drive it I'll tear up the left front tire. Does this make sense? And where would I get such a thing as a modified upper control arm?
4oldcars Driving: 1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado The ones I let go: 1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed |
07-10-2013, 06:32 PM | #2 |
Re: Modify Upper control arms?
The bags are shorter than the original springs. It increase camber and you need the tire to be more upright. You can do this two ways:
Longer upper control arms Shorter lower control arms I am sectioning both but I am taking 1'' out of the bottom and .25'' of the the top. With longer upper control arms you will end up with clearance issues with the fender.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
07-10-2013, 10:38 PM | #3 |
Really need pictures to see everything. 2" of shims is a lot of shims, so I'm hoping something is glaringly wrong and can be fixed.
Posted via Mobile Device |
07-12-2013, 12:38 AM | #4 |
Two things here..... The first is what alignment spec is the guy using? If he's trying to obtain the OE numbers, he's going to utilize more shims to get the +.5 spec vs. -.5 which would yield the same amount of tire wear but have better handling. Second, its not uncommon to have to utilize slightly longer studs when aligning with dropped springs.
07-12-2013, 10:15 AM | #5 |
Thank you scoti. Sounds reasonable. I took it to a different shop.
