Old 06-27-2013, 02:37 PM   #1
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Post 1970 C10 Chevy Suspension
got drum brakes 6-lug on all four corners and want at least disc brakes in the front.
While I'm at it wanting to drop the nose down a few inches w/o Sacrificing ride quality. Since I don't want to just buy a kit what's the best way of adding off the shelf parts or finding them in my local salvage yard? What year model Chevy/GMC truck parts will be inter changeable to reach my goals?
Thanks.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 06-27-2013, 03:07 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 1970 C10 Chevy Suspension
Buy 63-70 drop spindles. $229 most everywhere.
Local parts store items:
1) 73 HD rotors and bearings
2) 73 HD calipers
3) 71-72 brake hoses (some use 4x4 hoses)
4) 71-72 M/C and prop valve.
My opinion,... junk yard parts are wore out.
What would you really want to re-use?
Keith
Convert to disc brakes.
Old 06-28-2013, 10:27 AM   #3
C20-67_N_MO
Appreciate the information.
Thanks Keith.
Old 06-28-2013, 10:32 AM   #4
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
I can get Mcgaughy's drop spindles for 63-70 and a 6-lug rotor kit if you decided to go that way .They would be 1.25" thick rotors with 7/16 studs so you would not have any lug nut issues and you wouldnt have to change the rear diff . Your stock drum drum brake wheels would not work though. 71 and newer 4x4 wheels or aftermarket would tho.
ksbrktracer is offline   Reply With Quote
Old 06-28-2013, 10:42 AM   #5
C20-67_N_MO
At this stage I'm just exploring my options before I decide to sink money into it. As I'll be rebuilding the whole front suspension then once completed I'll work on all brake components.
Thank you.
Old 07-02-2013, 12:26 AM   #6
stsalvage
Scrapper 1
stsalvage's Avatar
If all is possible try to keep your front in the way the factory set it up.Do you have any Alignment problems if not do the drop or stock spindle remember to change the upper Ball joint if you can do the bottom one you be in heaven and sence you have screw in bushings there really cheep to buy and do at home one at a time after you get that front end back in shape
time to do the rear end if you have leaf springs there wore out have a shop press new bushings in and change all brake rubber lines and if possible change rear wheel cylinders and brake shoes it will ride and stop like a dream
stsalvage is offline   Reply With Quote
Old 07-12-2013, 10:40 AM   #7
C20-67_N_MO
Post Re: 1970 C10 Chevy Suspension
I see your point with factory settings. I'd rather have a nice air ride system even though they are quiet expensive. Or at least in the front as I want a narrowed rear axle for wide tires.
My build will be in stages as I am just trying to gather enough information to make an intelligent decision. Wanting a safe and ugly truck. I'll worry about the exterior at a latter date.
