Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 02-15-2014, 11:54 PM   #126
luna
Re: ***Dream Truck Build*** 72 swb fleet with a cummins and one tons
Awesome looking build can't wait to see it all finished
luna is offline   Reply With Quote
Old 07-14-2014, 02:57 AM   #127
kamwil05
This truck is freaking legit! nice work man!
kamwil05 is offline   Reply With Quote
Old 07-16-2014, 01:06 PM   #128
rgreathouse
Thanks for the compliments! I am still slowly making progress. Still picking away at rust repair and firewall smoothing with help from a friend. Also received my totally stainless complete body bolt kit, new body mount kit from lmc, and two new reproduction bedsides since mine werent as clean as I thought they were.
1972 c10,2wd,long bed,250,4spd---->
1972 SWB Fleetside 4x4 12v Cummins build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=513791
rgreathouse is offline   Reply With Quote
Old 07-16-2014, 01:21 PM   #129
rgreathouse
Started drivers side inner/outer rocker, floor, footwell and lower door hinge plate repair.
Old 07-16-2014, 01:22 PM   #130
rgreathouse
Totally stainlees
Old 07-28-2014, 02:50 PM   #131
rgreathouse
Cabs almost done and back home! Bed fit together nicely!
Old 07-28-2014, 04:03 PM   #132
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Great work! It's looking awesome!
Ryan
1969 Chevy milk truck
Old 07-28-2014, 08:19 PM   #133
rgreathouse
Thanks dieselwrencher! I just put the cab and bed back on the chassis and it's so nice to see it going back together even though I know it will be coming back apart.
I need to mock up tcase shifter, fuel door, linkages and decide on Intercooler. I've also decided its way too tall and need to look into options for lowering it without getting rid of crossover steering and keeping oil pan away from the diff. Any ideas? Link it and coilovers, bags, custom leafs... Also need ideas for Intercooler
Old 07-28-2014, 08:21 PM   #134
DWilbur
Originally Posted by obijuan View Post
if i were you id remove the steering block on the driver side knuckle. those studs tend to shear, and there is a better alternative out there. instead of that, ive used a dropped 4x4 pitman arm coming off the box. 90% sure its sold by superlift. its basically the stock one with a few inches drop.
With the drop pitman arm you will need drop drag link with the 6" lift. I sheared off the studs on the lift block for the steering arm. the parts available from super lift.
DWilbur is offline   Reply With Quote
Old 10-04-2014, 11:48 PM   #135
mx289
mx289's Avatar
Any new updates ?
How are those "totally stainless" bolts working out ?
Tom
71 K2500
71 K5 Jimmy
mx289 is offline   Reply With Quote
Old 10-04-2014, 11:55 PM   #136
rgreathouse
Yea I'm still making progress. Wheels and tires are here and waiting on my new custom leafs from offroad design. Finishing up some other suspension stuff like towing bags and traction bars. Once I'm happy with suspension I'll take it all back apart to start body work.
Totally stainless is awesome, highly recommend them!
Old 10-07-2014, 10:06 PM   #137
mx289
mx289's Avatar
Ok thanks i will check into them.
Any wheel and tire pics ?
You were going 20x12ish were'nt you ?
Tom
71 K2500
71 K5 Jimmy
Old 10-07-2014, 11:11 PM   #138
rgreathouse
Yea I'll post some pics with wheels and tires. My goal is to fit in my garage so under 7'. Currently I have 20x12 weld cheyennes and new 33s. I did not care for the stance of a 6" lift with 33s so I've ordered ord 4" progressive rate custom leafs and we'll see how it looks.
Old 10-08-2014, 06:21 AM   #139
CUSTOM/10
CUSTOM/10's Avatar
Awesome build !!!! That really will be a "Dream Truck" 72 swb 4x4 with a cummins and 1 ton running gear !!!! Love it.....
Watch the height though..... Here's a picture of mine with a 2-1/2" lift on 33"
tires and a 7' door. I had a 6'6" door and had to put in the 7'..... and it's close !!!
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 10-08-2014, 10:44 AM   #140
Dieselwrencher
Gary, there's no g in cummins.
Ryan
Old 10-08-2014, 11:42 AM   #141
CUSTOM/10
CUSTOM/10's Avatar
Damn spell check !!! "LOL"
Gary
72 SWB 4x4
My 72 SWB Build
Old 10-08-2014, 08:56 PM   #142
Dieselwrencher
Gets ya every time.
Ryan
Old 02-02-2015, 07:21 PM   #143
young.gun
Subscribed! I'm doing a 1972 lwb with a 97 Cummins swap! I just read your build now I'm caught up, I really like that frame boxing did you do that on a wet table or plasma table? I want to box mine pretty much front to back that why I ask
young.gun is offline   Reply With Quote
Old 02-02-2015, 08:12 PM   #144
rgreathouse
Young.gun- most of my brackets and plates were cut out on a torchmate table. Diy4x.com makes frame boxing plates for 73-87 and when I last spoke to them they were possibly going to make plates for 67-72. I need to update this thread! I've got lots of update! Thanks for checking in.
Old 02-03-2015, 12:25 PM   #145
nuke1
nuke1's Avatar
This is exactly what I would like to build for myself. except I would have a auto in it. Great job so far
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-05-2015, 11:43 AM   #146
puller
Nice Build! look forward to seeing more.....
puller is offline   Reply With Quote
Old 02-09-2015, 10:52 PM   #147
stepside83
stepside83's Avatar
very cool build
stepside83 is offline   Reply With Quote
Old 05-08-2015, 09:34 PM   #148
Bladeboy1998
Just read the whole thing! Love it! We need me updates though...
Bladeboy1998 is offline   Reply With Quote
Old 06-01-2015, 04:31 PM   #149
onetonwrecker
onetonwrecker's Avatar
Man the truck looks amazing. I'm currently doing a similar swap. I have a 68 c-30. mines staying 2 wheel drive but I am having motor mounting issues. I see you have had a lot of questions about yours. sorry if I asked something some one else already has but I see you used second gen mounts. I believe I will have to do the same in order to keep it low in the engine bay. I was wondering if you had any close up shots of the mount and how you did it in your frame? I may copy your idea if that's aright. Awesome build hope mine turns out half as good as yours is.
onetonwrecker is offline   Reply With Quote
Old 06-27-2015, 06:47 PM   #150
mx289
mx289's Avatar
So,about those updates and pictures ?
Tom
71 K2500
71 K5 Jimmy
