08-27-2014, 08:27 PM | #1 |
gearing and ratios
1985 chevy, 350 crate motor, carbed, 700r4 trans, 35 inch tires, axle gears 3.08s, transfer case is np 208, good or bad idea?
1985 High Sierra step side 4x4 |
08-27-2014, 08:29 PM | #2 |
Newbee
Re: gearing and ratios
Probably want to go 3.73 with the OD.
08-27-2014, 10:53 PM | #3 |
35'' tires and a 700................4.56 gears
08-27-2014, 11:46 PM | #4 |
Fabricate till you "puke"
35" tire, I would also go 4.56 on the gear longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
08-28-2014, 12:03 AM | #5 |
60-66 Nut
I agree with a 4.56 gear with those 35" tires. The 3.08 gears with 35" tires would just be absurd.
08-28-2014, 01:01 AM | #6 |
Alright sounds pretty conclusive, 4.56s it is. Haha and just curious if i switch the gears, how would it run with 33s? Mpg? performance? over all? Cause most likely it'd be a lil while b4 35s.
08-28-2014, 01:14 AM | #7 |
Check out this website. Great driveline / gear / tire calculator. Use the drop downs to input your tranny and transfer, then input your tires and change up the gearing till you get the rpms where you want them at specific speeds. Can also do a side by side comparison.
http://www.grimmjeeper.com/gears.html
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
08-28-2014, 03:12 AM | #8 |
If you are running 33" tire now,IMHO, they will need a 4.10-4.33 gear to work out properly. I will step back, & let Capt chime in....I respect his opinion also Longhorn
08-28-2014, 08:05 AM | #9 |
Which sounds good, but if I'm going over to the 35s sometime this winter there's no use putting gears that match up with 33s, see what I'm saying? Might as wel gear for 35s, an run 33s for a while
08-28-2014, 01:02 PM | #10 |
Even 33s with a 4.56 will be fine. I had a 1990 suburban years ago that I had put in 4.56 gearing with 31'' tires, and the 700 ... best change I ever made. You got to remember when the trans shifts into 4th and locks up the convertor you are reducing the effective ratio by almost a third. So your 4.56 becomes just around a 3.2 ratio final drive. Stick with the 4.56
08-28-2014, 02:32 PM | #11 |
I had 3.08 and 35 on my 85, I don't think it ever shifted into overdrive until 60+
Another option would be a 3/4 ton rear or swap to 1 tone axles, if you still have 2 10 bolts. |
08-28-2014, 10:55 PM | #12 |
It sound to me that you have it figured....no point in doing it 2 times longhorn
Tags |
350, 35s, 700r4, gearing, ratios |
