01-26-2015, 09:24 PM | #1 |
fender to cowl bolt size,fender to lower cab
anyone know the size of the bolt with the washer that bolts the fenders to the cowl part on the cab and down below by the door on the cab?
i need some and dont have one here for refference. and is - 5/16-18x7/8 correct for just about all the other front end bolts?
1969 Shortbed in progress 1982 short step, few suspension and motor upgrades.getting a 468 1978 Shortbed fleet side bonanza fully loaded 1978 k20 Silverado loaded.currently engine-less 1989 k10 suburban 9" lift 65 nova And more |
01-26-2015, 10:02 PM | #2 | |
The Older Generation
Re: fender to cowl bolt size,fender to lower cab
The ones for the cowl & below are 3/8-16x1 unless they need some shims, then you would have to go to 1 1/4 inch long. Yes, the 5/16-18x7/8 will pretty much do everything else. There are a few shorter ones in the grille area but I think the 7/8 will work. LockDoc
