01-06-2015, 04:18 AM | #126 |
Re: 68 c10 2wd in Sacramento, CA
Thanks again. While my son is finishing the body work, I am going to get the suspension swapped over (much easier with the body off). Unfortunately, the parts truck (78 C10) we bought cheap a friend really wants to build up, so he is going to look for just a suspension set-up for us to swap for the parts truck.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
01-29-2015, 11:50 AM | #127 |
well, I actually got a chance to do a little work on the thrasher today. pulled out the sander and some rattle cans and started to try and make it at least only 2 colors instead of 5
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding My build : 68 C10 Short Bed Conversion |
01-29-2015, 11:57 AM | #128 |
I also scored on a new passenger door. the current door I have has rot through the bottom and has been molested for speakers. it also looks like 5 different style mirrors have been mounted on it. The new one I just got was sitting in the garage at my buddies house, his uncle asked me if I could use it, if so, take it. it's a hugger orange, I hate to paint over it, but it has to happen
heres the old door here's the rot in the bottom. and here is the new door, If I can get the trim off without jacking it up, it is free to whomever want to pay for the shipping....
01-30-2015, 01:20 AM | #129 |
OK, so today I got a little crazy with my angle grinder ... The left side front fender and bed side are from a 67 parts truck that was in pretty dire shape. they had the original paint still on them and had sat outside in the mountains for years. All the paint was cracked and chipping and there was some surface rust. I tried to sand a little and paint it....no good. Then I decided to whip out my paint wheel on the angle grinder, and get to stripping.
then applied a base layer of primer/sealer. there were 2 spots with bondo so I smoothed them out a bit, and I will be putting a little more bondo over the seams where I shortened the bed.
02-23-2015, 02:49 PM | #130 |
So a few little updates:
Scored a drivers side door also. completely stripped and in awesome condition. Now I'm on the lookout for a pair of shorty fleet side panels. Repaired my heater/defroster, had to open up the switch and clean all the crap out of the contacts, same for the windshield wipers. now all is working. Paid my registration and now she is road worthy, lights, heater, and wipers... ordered a set of 5" lowering springs and an adjustable panhard from summit. will install and post pics soon :-)
02-23-2015, 03:40 PM | #131 | |
Rich J. 1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD 2002 Chevy Tahoe 4X4 5.3L SOLD 2015 Chevy Silverado Crew 4X4 5.3L |
02-23-2015, 10:56 PM | #132 |
Nice work!
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
02-27-2015, 01:53 AM | #133 |
Lowered the truck today. Used cpp 5" lowering springs in the back, and I cut 2 coils out of the front springs. ...ride is a little bouncy, but still better than the boaty stock ride.
before... after
02-27-2015, 02:16 AM | #134 |
I drove it to work today to do the springs, it was awesome, the motor in it has tons of power, now I just need an od transmission. I am not stopping till I find a 5 speed or 6 speed. I want that thrill of banging through the gears. ;-)
02-27-2015, 11:27 PM | #135 |
Just checked out your build. Just curious , is the bouncy ride from the two coils being cut or your shocks? I'm thinking about cutting one coil off my springs.
02-28-2015, 01:14 AM | #136 |
I'm thinking a little of both. cutting the springs actually makes the spring a little stiffer, less coils means less material to flex. Plus, I need to get the front realligned it has bad camber now.
02-28-2015, 01:24 AM | #137 |
it's more like bouncy like the springs are stiff.
03-20-2015, 10:17 PM | #138 |
RAT1968 '68 Cab/'71 Parts
Truck's turning out so nice. Even though she's fine as she is, I had to do a tiny bit of body work.
Couldn't help myself!!!
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
03-21-2015, 02:25 PM | #139 |
Your truck is looking great! I digg the new stance.
03-21-2015, 02:51 PM | #140 |
C/10 junkie
Great build. I'm local as well
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
03-25-2015, 11:08 PM | #141 |
nice, I wish I could do bodywork that good myself. I am just not good at the finish work. Although I chopped the sides, eventually I would like to replace them, so right now it's a little ratty..... but it's fast as hell.
04-15-2015, 12:25 PM | #142 |
I got a copy of DesktopDyno2000 today and I plugged in all the info from my engine and I was Pleasantly surprised. The original estimation I was given from the PO was around 380 hp. I pulled out all the receipts from the parts and work done to the engine, and the specs from the parts, and I found it a little more...
It looks like around 429hp, with a peak tq of 421lbs/ft
04-16-2015, 02:48 PM | #143 |
I bet it's a lot of fun. My truck has like half of that. Ha!
04-16-2015, 08:23 PM | #144 | |
04-24-2015, 12:11 PM | #145 | |
I ran the block numbers and the head numbers. The block is from a 75 c10, the heads are 2.02's. The PO told me that when they got the truck the motor had been built incorrectly and threw a crank bearing, so they had it line bored, and the cylinders bored out. so the config is: 350 bored .080 over (so it's a 364) 10.1 pistons 2.02 intake valves 1.60 ex valves ported heads, elgin pro stock cam stock rockers produces .450 valve lift int, .480 valve lift ex large port long tube headers, eddy torker intake, eddy 750 cfm carb, hei (recently just installed that) I was looking at doing an ls swap, but I have found that the roughly 400 hp is plenty enough to get me into trouble, If I really step on it it is hard to keep the wheels hooked up. it isn't crazy power, but plenty enough to have fun.
04-30-2015, 08:50 AM | #146 |
Took some artsy fartsy pics of the thrasher this morning at about 5 am... light was making it look good. Enjoy
04-30-2015, 10:11 AM | #147 |
nice write up and good Job!
I am right in the middle of doing this exact thing with my 69, shorten the bed, rails and such. motor great job!! Thanks for the pics. |
04-30-2015, 11:09 AM | #148 |
Looking good!
05-02-2015, 12:35 AM | #149 |
if you haven't started you bed sides yet, check out this thread, I wish I had thought of this
http://67-72chevytrucks.com/vboard/s...d.php?t=667694
05-06-2015, 09:37 AM | #150 |
Ok, wanted to do another quick cost rundown.
$1000 for the truck that I traded for this truck :-) $ free new front suspension and disc brake system $ 60 new tires and an extra set of rims $ 40 cpp 6 lug rotors $ free drive line $ 30 u-joints $ 20 exhaust gaskets $ free bedside, fender, and cab patch $ 20 brake line and adapter $ 35 title transfer $ 15 coolant $ 10 brake line $ 20 jug of dot 3 $ 5 carb adapter nipple for the booster $ 20 bed hardware $ 10 new headlight adjusters $ 100 cpp 5" lowering springs $ 29 adj, panhard bar $ 0 Hei distributor (thanks to my brother) $ 30 Hei coil $ 0 Hei plug wires (leftover from a previous vehicle) $ 35 Cab corner patches $ 65 Rocker panel outer patches $ 70 Paint supplies including paint. _________________________ total $ 1614
