Old 05-05-2015, 08:17 PM   #126
lower50's
lower50's's Avatar
Re: My 52 GMC Build
We had a great weekend off roading. With a little bit of carnage. One guy broke his drive shaft on a rock. Another spit the caps out of his front u joint.
My 67 Jeep ran great. Here are some picks.
Now back to the 52.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 05-05-2015, 08:32 PM   #127
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
dang looks fun. I like the camping idea. haven't done that since I was a kid.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 05-05-2015, 08:39 PM   #128
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Ya we go into the forest Friday morn and come out Sunday. All we have is what we bring in our Jeeps. It's a lot of fun. We usually go spring and fall (before and after the bugs) with some local day trips here and there.
1951 MG TD
Old 05-06-2015, 09:04 PM   #129
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: My 52 GMC Build
It looks like you guys had a blast! I've heard the mosquitos get severly nasty up there!
Ryan
1969 Chevy milk truck
Old 05-07-2015, 05:49 PM   #130
lower50's
lower50's's Avatar
Re: My 52 GMC Build
It was great!!! Ya mosquitos get bad but bug spray works great. The black fly's tho omg it's like you have an afro of little biting bugs. That's why we go spring and fall. They started to come out on Sunday.
1951 MG TD
Old 05-07-2015, 05:54 PM   #131
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Got my scraper bars on. I need them to protect the fenders from driveways and such. First pic is on the back and second is under rad support.
I was thinking of using this piece of 5" chrome pipe for my exhaust tip, but I have a piece of 6" stainless I think ill use.
1951 MG TD
Old 05-07-2015, 06:03 PM   #132
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Today I worked on my floor. I cut out the recessed part to make flat and made my transmission hump seat support. The rear of the seats will bolt to this bar.
I'm making a 3rd seat/arm rest on top of the hump. From the rear of an s-10
1951 MG TD
Old 05-07-2015, 08:44 PM   #133
Dieselwrencher
Re: My 52 GMC Build
Nice work! Those scraper bars should help!
Ryan
Old 05-08-2015, 10:36 AM   #134
05snopro440
05snopro440's Avatar
Re: My 52 GMC Build
Great idea on the scraper bars! To me, it looks terrible when someone airs down their ride and you can watch the body panels flex as they contact the ground, unfortunately I see that quite a bit with air ride vehicles.
I can't wait to see how this truck turns out, it's looking awesome!
My 455 Buick powered '46 GMC Build Thread
My '46 GMC on Photobucket
05snopro440 is offline   Reply With Quote
Old 05-08-2015, 10:42 AM   #135
Coldshot
Coldshot's Avatar
Re: My 52 GMC Build
Really digging those pipes! But I like your plan for the bigger ones.
Coldshot is offline   Reply With Quote
Old 05-08-2015, 12:14 PM   #136
steve aleve
Re: My 52 GMC Build
This thing is looking great!!! What a monster. I was just looking back at some of your posts and I noticed how low you have your cab set on the frame. I wanted to see what your plans for your radiator are? Are you going to tilt it forward to miss the steering box? Also, what are you planning on doing for the drive shaft tunnel? Specifically with the brace that comes down the center of the back of the cab? Looking awesome!
steve aleve is offline   Reply With Quote
Old 05-08-2015, 03:10 PM   #137
lower50's
lower50's's Avatar
Re: My 52 GMC Build
05snopro440 Ya I agree. Rear ones where a necessity. I had it aired out and lifted the front and almost bent the rear of the rear fenders, because I chopped and lowered the fenders. But its all good now.
Coldshot I'm running just one pipe out pass side. 3" from turbo straight out to 6" tip
1951 MG TD
Old 05-08-2015, 03:25 PM   #138
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks everyone
Yes its going to be tilted back at the top slightly and go just in front of box. Also the rad is going down between the frame where clamps are and will hang down below a little.
For the tunnel I was going to make a bracket out of angle same as the one I have for the seats and weld it to the cab bracket and floor. I'm also going to make a drive shaft hoop front and rear, just in case.
1951 MG TD
Old 05-08-2015, 03:33 PM   #139
lower50's
lower50's's Avatar
Re: My 52 GMC Build
So today I built the other floor/ seat support, a little wider and taller than the rear. Got them kinda welded in. Floor is super sturdy now.
Then wallah I have seats to sit and play on. Very comfortable driving position!!
1951 MG TD
Old 05-08-2015, 03:41 PM   #140
Dieselwrencher
Re: My 52 GMC Build
Nice work! Do you have a time frame of when you will hit the streets in it?
Ryan
Old 05-08-2015, 03:41 PM   #141
05snopro440
Re: My 52 GMC Build
Attachment 1400413
Attachment 1400414
Are those from a Sunfire or Grand Prix or something like that?
Old 05-08-2015, 04:47 PM   #142
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Dieselwrencher My goal was 1.5 years from now but its looking like it might be next spring
05snopro440 seats are out of an 2001 s-10
1951 MG TD
Old 05-08-2015, 11:23 PM   #143
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
getting there. I made the same style floor, only the whole way from front to back in my cab. I didn't have a good floor to work off of at all. Luckily my rockers where good. The floor ate up alot of my cab hours which is about 150 total. thats with all new patches, cleaned and painted firewall and inside back wall.
The radiator deal is a pain. I used on both my trucks, a tri5 car aluminum rad. If I were to do it again, I'd really try another way. I had to tilt mine, which looks good but you just gotta fab up a cradle for it to sit on. I did away with the stock rad support, just made mine own. radiator moch up eats up some time thats for sure.
I keep forgetting you have larger fenders which I know are taller. but are they loner too? seems like most all s10 frames get cut right at the pws box. you seem to have a good 5" more.
Old 05-08-2015, 11:29 PM   #144
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Yes 99 they are longer. The rear cab mounts lined up with the rear extended cab S-10 mounts. To give an idea. I think the are 5-6" longer that helps me fit that monster.
1951 MG TD
Old 05-19-2015, 04:53 AM   #145
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Got my exhaust welded up and 95% mounted. I miss working with stainless. Also cut and figured out the finish I like for the for my 6" tail pipe. Now I just have to trim the inner fender.
1951 MG TD
Old 05-19-2015, 11:48 PM   #146
lower50's
lower50's's Avatar
Re: My 52 GMC Build
So exhaust is done I am planning on trailering the truck to a car show (if the weather is half decent) not far away called the Unfinished Nationals. It's on June 7 in Paris Ontario. The show has everything: rat rods, customs, show vehicles, ect. There are at least 2 awards I qualify for, best unfinished, most custom. This will be my 3rd year going, 1st with my GMC. So my plan right now is to get the rad and inter cooler in so I can get the motor running for the show.
1951 MG TD
Old 05-20-2015, 03:39 PM   #147
Dieselwrencher
Re: My 52 GMC Build
Great work on the exhaust and good luck getting the rad in to go to the show!
Ryan
Old 05-20-2015, 10:20 PM   #148
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
good luck with your deadline. Im done making deadlines!!
Old 05-20-2015, 11:23 PM   #149
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks guys. Well today I made up some starter cables from some 2/0 welding cable I have, same as in the back. Also got the inner fender hacked and back in. Built the cover for exhaust and got it tacked in. I still need to clean up the inside of my cut to cover and make a cap for the top.
1951 MG TD
Old 05-25-2015, 06:15 PM   #150
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Well the rad is in. Just have to add some gussets and find some rad hoses. I used 1.5" angle welded to the rad, then 1/4" rubber and 2" angle welded to the frame. So I can sill get it out. I'm just in front of the psb and on a slight angle back at the top. The inter-cooler fits right on top of the cross member.
1951 MG TD
bagged, build, diesel, gmc, hot rod
