Old 09-22-2015, 09:15 PM   #1
OlSmokey
Starting Shortbed Conversion Tomorrow
hey guys i'm doing a shortbed conversion, i've read numerous threads, watched a lot of videos, and talked to people, and now the weather is good enough so i'm ready. just wondering, is there anything that those with experience doing it could tell me as a little tidbit? thanks so much guys! This site is awesome!
OlSmokey is offline   Reply With Quote
Old 09-22-2015, 09:25 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Starting Shortbed Conversion Tomorrow
If I read it right, the cabs for short Vs long differ? In what way?
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is online now   Reply With Quote
Old 09-22-2015, 09:32 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Cabs are the same
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 09-22-2015, 10:39 PM   #4
67 chevelle
67 chevelle's Avatar
z cut , under the cab ,and box frame in that 12 inch area when done , stacy david , did it right ,, check out gearz
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 09-22-2015, 11:53 PM   #5
SierraMtns
SierraMtns's Avatar
http://www.powerblocktv.com/episode/...0#.VgIiK6SvOHg
SierraMtns is offline   Reply With Quote
Old 09-22-2015, 11:54 PM   #6
SierraMtns
SierraMtns's Avatar
http://www.powerblocktv.com/episode/...r#.VgIiTaSvOHg
Old 09-23-2015, 12:04 AM   #7
faribran
Like some of the articles say, make X reference marks on the frame. Measure multiple time then BURN IT IN.. Yes do the Z cut, you will be glad you did
faribran is offline   Reply With Quote
Old 09-23-2015, 09:29 AM   #8
Advanced Design
Advanced Design's Avatar
And this thread includes great information on converting the bed.
http://67-72chevytrucks.com/vboard/s...d.php?t=667694
Advanced Design is offline   Reply With Quote
Old 09-23-2015, 09:37 AM   #9
aggie91
I'm just glad to be here!
aggie91's Avatar
While the link that Advanced Design posted is good and another way to do the work, I believe this is the better way to do the job.
This link has been in the FAQ and is the Z method others have mentioned above. He has lots of great pictures thru the process.
http://67-72chevytrucks.com/vboard/s...d.php?t=123624
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 09-23-2015, 09:52 AM   #10
OlSmokey
aggie that is actually the thread i've studied the most!
thanks everyone for the responses!!
Old 09-23-2015, 03:42 PM   #11
harrisoncole4
harrisoncole4's Avatar
Id be interested so see some updates through this build
harrisoncole4 is offline   Reply With Quote
Old 09-23-2015, 05:24 PM   #12
Advanced Design
The thread is excellent for frame conversion. Apologies for any confusion, I was referencing the shortening of the bed in the link I provided. He tipped the ends and ended up with much less welding to deal with. Farmtrucks is doing that now with high school build II.
Old 09-23-2015, 10:55 PM   #13
OlSmokey
Harrison I'll definitely keep updates coming. I wasn't able to start today. there was something that came up, but for sure by next monday there should be something!
Old 09-23-2015, 11:23 PM   #14
the ideaman
the ideaman's Avatar
http://www.earlyclassic.com/tech.asp...20No!-Shortbed
Since we know these guys and used their boxing plates, this is the way we did the frame work. I wouldn't hesitate to do it to another truck.
the ideaman is offline   Reply With Quote
Old 09-24-2015, 01:33 AM   #15
88Stanger
88Stanger's Avatar
olsmokey,
I literally just did this conversion a couple months ago. The only thing that i did different than what the threads or Gears did was i put the phish plate on the outside of the frame. It was alot easier to weld and i kinda like the look. measure three times, then just go for it. Now, the interesting part is that on gears they used a saws-all for the z cut on the round portion, well i tried this and decided to try something else. I honestly used a jig saw with a metal blade and it worked surprisingly easy! It really is easy, and it will surprise you how simple it is, just do your research and if you have a direct question, ask it here, the help here has been awesome!!!
good luck and please post pics.
88Stanger is offline   Reply With Quote
Old 09-24-2015, 10:07 PM   #16
tbonham27
make sure that frame is true while you have it apart....string and tape measure all you need..
tbonham27 is offline   Reply With Quote
