01-03-2015, 04:01 PM | #76 | |
Re: NJ Suburban
Oh yes! It bolted right up after I cleaned it up.
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
01-03-2015, 04:03 PM | #77 |
Re: NJ Suburban
Leon the body work is going to take a while mostly because of funds. My small engine work falls off in the winter and my cash flow is greatly reduced!
I need to order a set of long adjustable sanding blocks. Man are they expensive! Paul
01-03-2015, 11:25 PM | #78 | |
The Older Generation
Re: NJ Suburban
I can imagine. I just bought a decent set of semi rigid blocks and the price of those will make your toes curl.... LockDoc
05-26-2015, 08:43 PM | #79 |
Re: NJ Suburban
Well can't believe it has been 4 months since the last update. Also can't believe it has been that long since I've done any work. My regular 9-5 has been busy and my small engine repair sideline is really taking off.
I'm getting ready to send the next two panels to the sandblaster soon. The hole are all closed up on the front fender and now I'm working on one of the rear barn doors. First off there is some rust through on the inside lip and some bubbles on the outside. Is it possible to use a side door lower patch panel to fix the area or will I have to make the parts? The other issue is that it is covered with dent on the inside. The door is going to weigh 100 pounds with all the bondo to level them out. Any suggestions on how to get these dents out without pulling off the entire outer skin? Paul
05-26-2015, 09:56 PM | #80 |
Re: NJ Suburban
well good to hear your back at it......
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
06-12-2015, 08:21 PM | #81 |
Re: NJ Suburban
Finally some progress. Got a HF stud welder and puller set up and it works great! The Shoot Suit pop rivet style puller is amazing too.
This door is going to take a lot of studs though! Paul
06-14-2015, 11:04 AM | #82 |
Re: NJ Suburban
Nice work. Good to know you are happy with the HF stud welder. I have considered purchasing one.
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
06-14-2015, 02:20 PM | #83 |
Re: NJ Suburban
So far Joe it has worked great. This door is using a lot of pins because of all the dents. Luckily there is a new Harbor Freight that is only a few miles away.
Paul
06-14-2015, 08:19 PM | #84 |
Re: NJ Suburban
I have considered buying one too. Good to know it works OK. The doors on my Burb were bad too. I just covered up what I could with upholstery panels and left the rest..... Good to see you working on it again. LockDoc
09-23-2015, 08:09 PM | #85 |
Re: NJ Suburban
Finally a break in my work load and another body part is painted with epoxy primer and the rough body work done! Hard to believe this is the same door.
Paul
09-23-2015, 08:14 PM | #86 | |
Re: NJ Suburban
That came out great! I need to do that to a couple of places on the inside of the Panel truck doors. Where did you get the Shoot Suit pop rivet puller? LockDoc
09-23-2015, 08:22 PM | #87 |
Re: NJ Suburban
looks fantastic Paul
09-23-2015, 08:31 PM | #88 | |
Re: NJ Suburban
Paul
09-24-2015, 10:32 AM | #89 | |
Re: NJ Suburban
OK, thanks for the info. LockDoc
09-24-2015, 10:45 AM | #90 |
Re: NJ Suburban
Oh forgot to say that the Shoot Suit people sent me a new cone right away free of charge. I managed to jury rig the old cone using a hose clamp too.
Paul
09-25-2015, 08:21 PM | #91 | |
Re: NJ Suburban
That was a good deal. It's great to hear when company's follow up on problems with their products.... Thanks, LockDoc
02-04-2016, 06:07 PM | #92 |
Equal opportunity joke ofender
Re: NJ Suburban
Hey Paul
Any progress? That door looks like it turned out real nice. They just opened a harbor freight here in town and I have been resisting the urge to go in. That spot gun might make me have to go take a peek.
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
02-05-2016, 07:32 PM | #93 | |
Re: NJ Suburban
Progress has been slow. Day job is busy and my small engine sideline is too. The only bolt on body panels left to do are the 3rd and passenger side doors and the hood. The third door I bought needed more work than I anticipated. The spot welder pin gun is a great help and so is the shrinking disk set I picked up. Hopefully the body will be home early spring! Paul
04-09-2016, 08:53 PM | #94 |
Re: NJ Suburban
Finally finished the last of the removable body parts, the passenger door and the 3rd door. Sandblasted, rough body filler work and epoxy primer. Next week the body will come home! The plan is to remove all the glass, wiring and other accessories and separate it from the 2wd frame. Not sure if I'll put it on my rotisserie or build a cart/cradle for doing body work to the main body.
04-22-2016, 09:16 PM | #95 |
Re: NJ Suburban
I'm years away from needing these but the price was right. 2004 Suburban seats front and second row for $250!
Paul
04-23-2016, 12:36 AM | #96 | |
Re: NJ Suburban
Those should work great. Let us know how the mounting goes. LockDoc
04-23-2016, 08:13 AM | #97 |
Re: NJ Suburban
nice score Paul
04-24-2016, 11:43 AM | #98 |
Re: NJ Suburban
Great seats! You wont be dissapointed. I used the same front seat in my '67. I built a bracket to utilize the original mounting points. I need to rework it however because they sit a little high.
04-26-2016, 07:32 PM | #99 | |
Re: NJ Suburban
Thanks for the pic Joe. It's gonna be a while before they get installed though! Paul
05-05-2016, 07:28 PM | #100 |
Re: NJ Suburban
Finally dragged the body home to work on!
Paul
