10-20-2015, 07:31 PM | #51 |
Who Me?
Re: New member with a 1960
I think you have the wood prep covered!!
Steve 1997 Tahoe LT 4D 2WD (DD) 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
10-21-2015, 09:02 AM | #52 |
I just bought this 60.
10-21-2015, 10:01 AM | #53 |
I do need some advice regarding the bed, in the mid section (Tire Area) of the bed it measures about 49-1/2 wide, at the front and rear of the bed it is right at 50 which leads me to the assumption that the center needs to go outwards, is this correct? I see no way to bring the front and back inwards, I was thinking of building a jig and using a bottle jack to push the center area outwards and brace it out until the bed floor is installed. What do you guys suggest?
10-21-2015, 12:08 PM | #54 |
How do the center cross sills fit? I would tell you to try to line the holes on the center cross sills up with the holes on the L shape brackets that are supposed to run along the side of the bed but it does not appear as if your truck has them. How are you going to keep your bed attached without the L shaped rails sitting on top of the wood?
10-21-2015, 04:22 PM | #55 | |
10-21-2015, 04:33 PM | #56 |
After looking, there are no holes in my bed for angle strips?
10-21-2015, 05:12 PM | #57 |
Truck is looking good! Nice job.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
10-21-2015, 05:52 PM | #58 |
The angle strips are welded to the sides of the bed and lay on top of the wood. I don't have any pictures on hand but if you look at one of the threads about bed wood you will find what I am talking about. Both step sides and fleet sides have them. Have you checked to see if the top of your bed sides are straight I could not imagine those being bowed also.
10-22-2015, 10:43 PM | #59 |
10-26-2015, 05:03 AM | #60 |
10-26-2015, 07:41 PM | #61 |
Who Me?
You're and animal on that wood!! Nice job!!
10-27-2015, 07:52 AM | #62 |
Thank you sir, I have done my years share of sanding...LOL I hope do be finished by the end of the weekend except for the final sanding and buffing, I want to let it cure for a couple of weeks first. FINALLY I got the e-mail where most of my front end parts are in transit besides ball joints and steering rebuild kit (on backorder) I ordered the LS Swap headers and motor mount/frame mount kit also. Getting ready to order truck wiring harness and engine harness. The LS goes to the shop at the end of the week for bottom end rebuild, head work/port etc and blower install. We are moving right along again! |
11-03-2015, 10:48 AM | #63 |
11-03-2015, 12:07 PM | #64 |
Nice work. That truck has some of the best patina I've ever seen
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
11-03-2015, 03:45 PM | #65 |
make sure to poly all edges and underneath as well,...it will seal up the wood and help stop warpage...looks good,..that semi gloss or high gloss?
1961 c10 longbed - gone 1964 c10 swb |
11-04-2015, 01:29 PM | #66 |
11-24-2015, 09:03 PM | #67 |
11-25-2015, 02:21 AM | #68 |
60-66 Nut
Very nice
11-25-2015, 09:04 AM | #69 |
11-25-2015, 10:53 AM | #70 |
Love the wood!
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
11-30-2015, 10:02 AM | #71 |
Thanks,
I think I found some ball joints...hopefully and if so we will start moving again! |
12-02-2015, 09:39 AM | #72 |
My backordered ball joints arrived... We can get back on this junk! It should be on 4 tires by the weekend, then brake lines/booster/MC
what are some good resources for pre bent lines? |
12-02-2015, 10:43 AM | #73 |
Summit Racing would have them.
12-02-2015, 12:21 PM | #74 |
12-03-2015, 04:18 PM | #75 |
I got my Brake Booster bracket ordered from Captainfab, pleasant fellow to deal with!
