Old 02-08-2017, 01:21 AM   #1
76/85 Truck
76/85 Truck's Avatar
Turbo 350 4x4 Strut Rod Braces
Hello! In the process of building a turbo 350 for my 76 Chevy K20. The bellhousing cracked completely off of the transmission that used to be in it.
I keep hearing about rods that bolt from the lower transmission bell housing to the engine block. When I bought this truck, it had no supporting bars on the transmission or transfer case.
It has an NP205 if that helps. Any ideas of where to find these rods or pictures of said rods? Trying to avoid breaking another transmission. Thanks in advance!
Rich
My first truck!! 1976 Chevy 3/4 ton Camper Special and a 1985 GMC body. Has a 350, 4 BBL Edelbrock, with a Turbo 350, and NP205 T-case.
76/85 Truck is offline   Reply With Quote
Old 02-08-2017, 03:19 AM   #2
andrewmp6
Re: Turbo 350 4x4 Strut Rod Braces
You might have better luck in the 4x4 part of the forum.
Old 02-08-2017, 07:14 AM   #3
Jaysonb
Jaysonb's Avatar
The transmissions with the rods you speak of are what is called a "k" case. It has a a more robust case, and the fly wheel cover is thick cast aluminum, and there are 2 support rods that bolt from the cover, to plates that mount under the motor mounts.
Jaysonb is offline   Reply With Quote
Old 02-08-2017, 07:34 AM   #4
D13
D13's Avatar
The K case is later model 700R4 in 4wd applications and has all the features noted above. That is not directly related to the rods. The rods are used to help manage the long overhang from the t-case to the bell housing.
The support rods were used on most, if not all, 4wd applications including th400 and th350 units. I haven't really looked for new one because they were so common in the junkyards. IIRC they generally run to the engine mounts.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 02-08-2017, 07:55 AM   #5
Jaysonb
Jaysonb's Avatar
There are th350 K cases as well. The support rod that goes from the transfer case to one of the bell housing bolts is not unique to the K case, but the 2 support rods that go from the torque converter cover to the motor mount brackets is only a K case feature.
Old 02-08-2017, 08:04 AM   #6
Jaysonb
Jaysonb's Avatar
A K case transmission has 3 support struts, 2 from the torque converter cover to the motor mount brackets, and 1 from the side of the transfer case to a bell housing bolt.
Old 02-10-2017, 01:59 AM   #7
76/85 Truck
I can't find any online. May have to search local wrecking yards. Are they absolutely necessary? I recently heard of them, and was assuming that's why I broke the bellhousing on the last one.
Rich
Old 02-10-2017, 02:15 AM   #8
mcmlxix
Collector of Projects
mcmlxix's Avatar
I would add a second cross member for additional support. Also, make sure all mounts are rubber or poly, don't mix and match. Also if trans mount is new and motor mounts are worn, it could cause additional stress on components as the truck flexes.
Rich
1972 K5 Blazer CST Click HERE
Old 02-10-2017, 08:06 AM   #9
cadillac_al
I was waiting to see a pic of that th350 brace again. I never ever see them on trucks up here. They all must have got thrown away in their early life. My k10 looks totally unmolested and owned by an older gentleman and that rod was still gone off my truck. My buddy has one that he uses for a fireplace poker. I tried to buy it off him a few times but I figured I lived this long without it I can keep on living without it. It looks like a pia to get the bellhousing bolt started anyway. I drive fast on rough roads and haven't broke a tranny yet. I don't think the trans will break unless you are catching too much air.
That 2nd crossmember in ingenius. I may look into that.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
k20, strut rod, transmission, turbo 350
