Wipers
I have a 68 c10 wipers do not work... bought a new motor still does not work. I have power to the fuse box and power to the yellow wire that plugs into the wiper motor any suggestions?
Re: Wipers
My guess is the switch if the wiring hasnt been changed?
The Older Generation
Re: Wipers
The switch provides the ground for the different speeds. It has to be mounted in the dash before the wipers will work. There is also a ground strap on one of the wiper mounting bolt holes. It is integrated into the rubber bushing. Make sure it is there. Here is a thread that might help you figure it out.... http://67-72chevytrucks.com/vboard/s...d.php?t=413551 LockDoc
Re: Wipers
Thanks, I will work on these suggestions this weekend.
Tags |
wipers |
