Old 05-15-2017, 07:38 PM   #126
rvrfoot
Re: What did you do to your truck today part IV
Working on the roof.Name:  DSCN0840.jpg
rvrfoot is offline   Reply With Quote
Old 05-16-2017, 10:15 AM   #127
Robert Haas
Originally Posted by rvrfoot View Post
I just installed my sway bar.Attachment 1650944
Attachment 1650943
You are going to have a problem. I had it on mine as well. at full droop with the steering at full lock you are going to have hard contact with the steering links on both sides.
simple enough fix;
Take the sway bar apart and shorten the sleeves by 1/2"
Robert Haas is offline   Reply With Quote
Old 05-16-2017, 10:48 PM   #128
rvrfoot
Thanks for the heads up i will check on it this weekend.
Old 05-21-2017, 03:38 PM   #129
drmatera
drmatera's Avatar
Just scored these truck ralleys for $100 for all 4. 15 x 8
1981 K10 (4.8 / 4L60E swap)
1982 C10 (5.3 / 4L80E swap)
1985 C20 Suburban (454 / 4L80E)
drmatera is offline   Reply With Quote
Old 05-21-2017, 05:36 PM   #130
StepSide1965
That's what I'm going to run on my truck, like the center caps, what are they off of.
StepSide1965 is offline   Reply With Quote
Old 05-21-2017, 05:42 PM   #131
drmatera
drmatera's Avatar
Not really sure, the guy said they were on his '85 C10 when he bought it. They are in really good shape too....
Old 05-21-2017, 11:31 PM   #132
65chevysub
65chevysub's Avatar
Thats the same wheels I have on my burb. They came off of an 86 Suburban. Kind of hard to see but I temporarily sprayed them silver until I can get them back to original. Also going to make my center caps all chrome. Saw the how to on Youtube
65chevysub is offline   Reply With Quote
Old 05-22-2017, 08:54 AM   #133
graymage
graymage's Avatar
finally home for a couple weeks so lets see what I can get done, so far the fire wall is painted will pick it up today, got ebrake mounted
graymage is offline   Reply With Quote
Old 05-22-2017, 11:48 AM   #134
forestb
forestb's Avatar
If you fail at your attempt to do something did you still get something done.
Spent the day trying to figure out why my tail lights are not working.
And yes I checked the ground
forestb is offline   Reply With Quote
Old 05-24-2017, 07:57 PM   #135
Northwest Outlaw
Northwest Outlaw's Avatar
Tried to road trip her, she had other plans...
full story coming to my build thread soon
1961 Chevy Apache "BoomStick"
-First build, lots of plans, little experience. What's the worst that could happen?
http://67-72chevytrucks.com/vboard/s...d.php?t=694506
Northwest Outlaw is offline   Reply With Quote
Old 05-24-2017, 08:51 PM   #136
GMDad
GMDad's Avatar
My buddy put those rally wheels on his 68 SWB. Ordered a set of clips that bolt in where the 3 screws that hols the rally cap go on. Has a set of mid 50s Chev pickup caps coming to install. Painted the wheels whits with a narrow trim ring. Will try to get a pic in a week or two when all together. I think they will look really good.
GMDad is offline   Reply With Quote
Old 05-24-2017, 09:11 PM   #137
Lugnutz65
Lugnutz65's Avatar
Finished the CPP disc brake upgrade on my 1965 Short Step. Captainfab firewall adapter plate, 1995 Blazer brake booster and MC, Speedway pushrod extender with Heim joint, Summit Racing brake bias (but has Wilwood name - cast into the metal) so I can fine tune the rear brakes.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 05-24-2017, 09:30 PM   #138
graymage
graymage's Avatar
got cab on and started on master cylinder and pedal and shifter
Old 05-25-2017, 03:37 PM   #139
AngryPirate
AngryPirate's Avatar
Out of curiosity, what are you doing for the clutch cylinder that would usually be part of the master cylinder? I'd like to move away from the single reservoir my 60 GMC has.
thanks!
AngryPirate is offline   Reply With Quote
Old 05-25-2017, 03:45 PM   #140
graymage
graymage's Avatar
thanks!
I am running a 700r4 so I quess I don't understand the question
Old 05-25-2017, 03:47 PM   #141
rvrfoot
I think he seen the shifter in your truck
Old 05-25-2017, 03:54 PM   #142
graymage
graymage's Avatar
Ok I see, I quess I got the illusion I was looking for
Old 05-25-2017, 04:07 PM   #143
AngryPirate
Ah. I saw the floor shifter that looks like a stick.
Old 05-25-2017, 04:29 PM   #144
The Rocknrod
Moderator
The Rocknrod's Avatar
I took the brake pedal bracket from inside the cab, laid in on carpet sideways.
Installed the brake pedal spring and return bumper.
Mounted captainfabs bracket to it.
Mounted the power brake booster to that.
Then built out the brake pedal pushrod to the correct length, with adjustment left of course.
That way I didnt have to do it in the truck after their done painting it.
Just wish I took pictures.
Old 05-26-2017, 06:11 PM   #145
ironman3452
ironman3452's Avatar
http://67-72chevytrucks.com/vboard/a...&d=1495836428e
old and new pictures of wheels and tires I had on my 64 panel, old wheels and tires were 16.5 , new ones are 17 inch
ironman3452 is offline   Reply With Quote
Old 05-26-2017, 06:25 PM   #146
Prflyer1
Prflyer1's Avatar
Originally Posted by wolfsden View Post
Painted the white stripe and added the molding trim with 3M double sided tape.
I did not want to drill holes in my truck and the tape works great.
Good lord I love these wheels!!!
1966 Chevy C10 Not named yet, help!
1984 GMC 4x4 SB "The Hunter"
My 66 C10 fun build: http://67-72chevytrucks.com/vboard/s...d.php?t=738705
Prflyer1 is offline   Reply With Quote
Old 05-26-2017, 06:29 PM   #147
Prflyer1
Prflyer1's Avatar
Out of all the things on my build, this one is what I am most proud today! lol the painted white shifter ball
Old 05-26-2017, 10:22 PM   #148
jbgroby
jbgroby's Avatar
Added another option.....my Bing Crosby Option.
jbgroby is offline   Reply With Quote
Old 05-27-2017, 12:26 AM   #149
graymage
graymage's Avatar
so today I got the hydro boost plumbed and the new wiper motor installed
Old 05-27-2017, 05:11 PM   #150
AngryPirate
Finally got the crossmember parking brake set up remove, cleaned up and re-installed and I have a parking brake now!
I'm pretty sure I put everything back correctly.
