Old 06-27-2018, 08:49 AM   #1
CG
BlahBlahBlah
Is four/six level drop?
Looking at complete drop kits. Is four six level, or a slight rake that can be fixed with small blocks in the rear?
Also this seems to be the lowest kit I can find looking at different vendors, is there another kit option for a bit lower and still have a streetable ride? Air is not an option.
I think buying a complete kit, shocks, springs, spindles, shock mounts, and track bar would be the best bang for my buck (probably buy a C Notch too). Seems like piecing together really bumps the overall cost up.
Old 06-27-2018, 11:57 AM   #2
68 P.O.S.
Re: Is four/six level drop?
From what I have seen, yes, 4-6 is supposed to be level. Personally I think 4-7 is better, but that's my opinion. The kits do make it easier so you know you have everything, and you can always call them to change springs out for a different size drop or different shocks, or whatever. The vendors normally work with you.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 06-27-2018, 12:00 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
If you are running 15" wheels you can add up to a 1.5" lowering block,... but I wouldn't do that unless you have a c-notch in the frame.
Larger diameter wheels (18" and larger), you can run a 2" lowering block without getting into scrubline issues.
Keith
Convert to disc brakes.
Old 06-27-2018, 02:24 PM   #4
Yep, pretty much levels the truck, since they are known for coming with 2" rake. I think the 4/6 looks great and that is what my '67 SWB (chassis) has. But the vibe with that truck is from the era, so a 2" rake would be more appropriate. and more hot rod-like. Also, no c-notch for me and I want the truck to carry a load and tow a trailer. So between liking both level or raked and wanting the truck to be able to carry more than a cooler, I will be getting bags in place of springs. Change with my mood and not loose use as a truck
Old 06-27-2018, 04:40 PM   #5
68Stepbed
68Stepbed's Avatar
CG, 4/6 is somewhat level, but will still have a slight rake. My truck used to have a 4.5/6.75 drop. This was achieved with ECE 2.5" drop spindles, 2" drop springs up front and 6" Hotchkis rear springs along with a .75" drop block. As you can tell, it still had a slight rake, but not much.
To get it lower than advertised would be to trim front coil springs, then add blocks to the rear.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 06-27-2018, 10:39 PM   #6
CG
BlahBlahBlah
Ill be running 15's same size tires all four corners. Looks like 4/6 will work well with blocks to level it up.
Thanks for the picks that's a great stepper you have!
Old 06-28-2018, 11:32 AM   #7
68Stepbed
68Stepbed's Avatar
What size wheels/tires do you plan to run?
Thanks for the compliment!
Matt
Old 06-28-2018, 10:36 PM   #8
CG
BlahBlahBlah
I don't remember the exact size I have that info on a different computer. But I believe 15x7 rims with regular (what's that mean lol) size tires with thin whites
Old 06-29-2018, 08:00 AM   #9
68Stepbed
68Stepbed's Avatar
You should be good, then. Some of the 8" rallies have a somewhat deep backspace and interfere with the control arm when lowered with drop spindles. The quick fix is to run a 15x7 wheel, so should be no issues on your end.
Matt
