Old 06-28-2018, 11:32 AM   #1
mistral
Long Wheel Base to Short
Ok, I have a 1968 LWB would I be crazy to convert it to a SWB? would I hurt the value? I am sure some guys have done it, what kind of costs would I be looking at?
Thanks.
Ron
mistral is offline   Reply With Quote
Old 06-28-2018, 11:58 AM   #2
WhiteCST
WhiteCST's Avatar
Re: Long Wheel Base to Short
The only way I could see it hurting the value too bad was if it is a pristine condition truck, or a 50th anniversary truck. By all accounts that I’ve seen, making it a shortbed actually improves the value or at the least the desirability. As far as cost Brothers trucks makes a kit that anyone who can use basic tools and follow instructions can do. It costs $470 and comes with everything you need (new brake lines, new e brake equipment, new driveshaft for factory trans etc.) including a template you bolt on to the frame. If you can weld yourself you can complete the process on your own, if not the template bolts the truck together long enough to trailer it to a welder to have it done. The next expense is shortening your long bed which can take a long time to do properly, or buy a short box. They’re few and far between in good shape and all new panels will cost you close to 2k.
Here’s a link for where they did the swap and it will give you an idea: https://www.google.com/amp/www.hotro...10-trucks/amp/
And here’s a link to the brothers website: https://www.brotherstrucks.com/63-72...tinfo/LTSC372/
1953 Kaiser Manhattan “Sled”
1968 C10 CST LWB
1991 Trans Am GTA “White Nasty”
2006 Dodge Charger RT
Built TH400 for Sale
WhiteCST is offline   Reply With Quote
Old 06-28-2018, 12:00 PM   #3
WhiteCST
WhiteCST's Avatar
I am 100% sure someone will disagree with me as far as it hurting the value, but at least out in my area shortbeds are more expensive, regardless if they’re factory or converted. As long as they’re converted properly. And I forgot to say it before, nice truck! I’m currently building a 68 CST that I want to paint that color
1968 C10 CST LWB
Old 06-28-2018, 12:45 PM   #4
Boog
laying low
Boog's Avatar
Uh oh. Here we go again. 3,2,1
Some folks are pretty pasionate about the subject.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 06-28-2018, 01:04 PM   #5
cypressbog
Go Pack Go!
I say go ahead and cut it. A million of these trucks were made.
cypressbog is offline   Reply With Quote
Old 06-28-2018, 01:40 PM   #6
70cst
70cst's Avatar
Go the way you want - not sure of cost but make sure it is done right.
For me … I would not buy a converted truck but that's me … many folks would.
I like LWB trucks - many folks prefer SWB trucks
As far as a SWB being more valuable than a LWB … not in all cases.
Good luck
That's my thoughts
By the way - your truck look cool already
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 06-28-2018, 01:49 PM   #7
dropped_71chevy
To clarify, I don't believe Brother's kit includes a new drive shaft.
dropped_71chevy is offline   Reply With Quote
Old 06-28-2018, 01:56 PM   #8
hotwls13
Thanks.
Ron
Wow, nice truck! I like the SWB more than the longs. They are also more valuable. Do what you want, it's your truck.
If that was my truck, I'd probably leave it as is and build another. Haha
hotwls13 is offline   Reply With Quote
Old 06-28-2018, 02:41 PM   #9
morepwr
If it is done right, it doesn't hurt a thing other than originality. If you are making it into a something you really want then I say go for it.
morepwr is offline   Reply With Quote
Old 06-28-2018, 02:57 PM   #10
Grumpy old man
Grumpy old man's Avatar
By the time your done your going to Have $5,000 invested with all the body parts and then paint /trim/bed floor/drive shaft etc,etc and the paint won't match
Old 06-28-2018, 04:22 PM   #11
jessemthompson
I agree with grumpy old man. Your truck looks like it’s to far along to convert to a short bed. You may as well sell what you have and buy a short bed in the same condition. I would not cut that truck.
jessemthompson is offline   Reply With Quote
Old 06-28-2018, 04:28 PM   #12
WhiteCST
WhiteCST's Avatar
Thank you sir, I stand corrected. And another agreement with grumpy old man. 5k definitely sounds accurate for the full job completed if you buy a new bed. Maybe a little less if you do the conversion and weld it yourself. Or paint yourself etc. whatever your skills are.
1968 C10 CST LWB
Old 06-28-2018, 10:28 PM   #13
dagnabbitt
dagnabbitt's Avatar
Nothing wrong with chopping a frame, but why not try it with a piece of junk first? The one you supplied a pic of is really a little too nice.
What will happen when after you chop is you will: sandblast and powdercoat the frame; replace the driveshaft; lower it; upgrade to disc brakes etc etc.
Might well do it with a truck that needs all that stuff anyway.
That said, its your truck!
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 06-28-2018, 10:45 PM   #14
Southpaw69
That's a nice looking truck sir. I don't think you'd be "crazy" to make it a short bed if that's what you really want. As far as value, I think you'll be ahead leaving it as is. By the time you pay to get it done right I don't think you'd get it back if you sold it. Judging from that picture, it's already in the high end category.
Southpaw69 is offline   Reply With Quote
Old 06-28-2018, 10:59 PM   #15
mistral
Thanks for the input guys. Yes a lot of work has gone into my truck. A guy spent three years on it. I think I will take the advice and leave it as it is. I am tight in the truck so I will concentrate on a different seat and maybe a turbo 400 trans. She needs another gear.
Ron
Old 06-28-2018, 11:17 PM   #16
WhiteCST
WhiteCST's Avatar
I have a low mile th400 with a shift kit, too bad you’re in Texas
1968 C10 CST LWB
Old 06-29-2018, 02:39 AM   #17
stsalvage
Scrapper 1
stsalvage's Avatar
My one problem.Would your tear up a nice truck to do this No.That's why the guy below said they made a tone of these trucks.If every one is doing it find one half way done but the guy ran out of money.Buy it and finish it.I rather have 2 trucks instead of just one.Whats the fun in that.If your a diehard GM man having 2 of these trucks wont hurt you.Now this is what cracks me up the most about this He asked will it hurt the value.If your doing this to make more money yes it will unless your so good about covering up all the tale tale of converting your truck from long bed to short bed.Yes some guys later down the road will say you have a flip truck.That's like me putting SS badging on a Inline 6 camaro Nova or chevelle and saying its a true SS car every one laughs there ass off about guys buying Cars that look like yenko's has all the goodies But turns out it was a inline 6 with no options.
Trucks don't have that problem.But if you say its a factory short bed and you live in the south You might get a bullet or rock salt in your butt and live like a monk for the about 5 years or move out of the state No one like lyres.When you sell it be honest tell the truth and every one is happy
stsalvage is offline   Reply With Quote
Old 06-29-2018, 07:53 AM   #18
mistral
No one said anything about lying about it being a factory short bed. You ever buy something from me I tell you everything I know even if it cost me money. The question about value was just that you have a converted truck that is up front what would that do to value. Mute point at this point.
Old 06-29-2018, 10:52 AM   #19
66clow
66clow's Avatar
I have no problem cutting one but that is too nice of a truck. It needs to look like mine did to cut. Lol what I have in mine is way cheaper than buying an original shortbed. Tried finding an original ended up going this route.
66clow is offline   Reply With Quote
Old 06-29-2018, 11:55 AM   #20
bs46488
I cut mine, so I'm not against cutting up a truck.
But mine was in a far worse starting condition than yours.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
