09-26-2018, 12:04 PM | #76 |
Moderator
Re: OMG Honda door weatherstripping fits perfect no cutting required !!
If your door won’t shut, remove the seal and use a block of wood and a mallet to bend the pinch weld in slightly. Reinstall seals. Done. Two of my trucks had no issues with the seals, one had to have the pinch weld “adjusted”. This goes for any seal, not just push ons.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
09-26-2018, 12:46 PM | #77 | |
09-26-2018, 02:23 PM | #78 |
09-26-2018, 07:09 PM | #79 |
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
10-10-2018, 11:45 AM | #80 |
Perfect fit and operation!!!! Stop everything you are doing right now and order these!!!
10-11-2018, 12:43 AM | #81 |
Adding this to my list. Who was the guy who figured this out? And how?
10-11-2018, 04:12 PM | #82 |
I ordered stock replacements from Rockauto, $20 for the pair. :shrug:
68 K20 Custom Camper/CST Wrecker. 97 GMC K1500 short bed reg cab. |
10-11-2018, 04:18 PM | #83 |
10-11-2018, 04:19 PM | #84 |
I also got a set back in March. They were too tight when I first put them on but I adjust the doors a little and after a couple months of baking in the summer heat they're pretty good now.
10-11-2018, 04:31 PM | #85 |
Adjusting the doors will help the doors close but do not help body lines though.
10-11-2018, 04:53 PM | #86 |
Fine. Installed no issues. Is there a reason? Remove old. Glue new on. Not overly difficult. Same style as what I pulled off.
10-11-2018, 05:31 PM | #87 |
10-11-2018, 05:46 PM | #88 |
10-11-2018, 06:23 PM | #89 |
That's awesome, happy to hear they worked out for you!!
10-12-2018, 07:48 AM | #90 |
Still Learning
Very interesting thread. I put the glue on seals in my truck and have been slamming the doors from the outside for years. I found that if I open the window slightly from the inside the doors shut pretty reasonable.
I think the 69-70 model without the vent in the door frame make them a little more air tight than say the 71-72 |
10-12-2018, 10:36 PM | #91 |
that is the ones i used and i was lucky to find a decent pair...but they fit perfect! like they were made for it
11-25-2018, 02:06 AM | #92 |
interesting thread... I was looking at purchasing a set of door seals from classicparts but now I'm thinking about going with the Honda Civic's. I don't want to be dealing with slamming my doors nor trying to adjust the hinges and what not...
11-25-2018, 01:54 PM | #93 | |
The Older Generation
There is no guarantee that you won't have to slam your doors or move the striker plate out no matter which seals you get. Every truck is different so what works for another guy may not work for you, without modifications..... LockDoc
11-27-2018, 02:17 AM | #94 |
how have these held up? I'm thinking of ordering. Did you have to modify your doors?
1967 C10 SWB Stepside (without the ugly spare tire holder) 1968 c10 SWB Stepside (with the ugly spare tire holder) |
11-27-2018, 10:00 AM | #95 |
Tag for later
11-27-2018, 11:09 AM | #96 |
02-18-2019, 09:02 PM | #97 |
Zane picked up a set from pick and pull for less than $15. 2 minutes to install. They fit perfectly. Door closes as it is supposed to close. No amount of adjusting was going to make the crappy glue on seals work.
Fantastic find by OP. Thanks.
Zane's 71 Build |
02-18-2019, 09:58 PM | #98 |
Thanks for the civic door strip advice my expensive replacements are junk too.
02-18-2019, 10:28 PM | #99 |
No problem your welcome, yeah put them on a few more friends trucks since I did this thread.They work so good still can't believe how they fit.
1971 c10 custom deluxe fleetside swb LS3 w/BTR stage IV cam,4L85E w/3600 stall 67-72chevytrucks.com/vboard/showthread.php?t=558024 |
07-20-2019, 04:09 PM | #100 |
Any wind noise with these civic weatherstrip??
