Old 09-26-2018, 09:47 PM   #1151
mcbassin
Still Learning
mcbassin's Avatar
Re: LS1 into a 73 cheyenne
Looks Great Alex!
Old 11-04-2018, 12:40 AM   #1152
z71se
No updates in over a month everything good with truck!
77 C10 Silverado SWB - LS Swap, mechanical resto-mod
05 Z71 Silverado RCSB - 5.3L LM7, 76mm turbo, 4L80e
z71se is offline   Reply With Quote
Old 11-04-2018, 07:11 AM   #1153
Mjminino
Mjminino is offline   Reply With Quote
Old 11-23-2018, 11:19 PM   #1154
smokedat
smokedat's Avatar
the progress is slow as i only work on it once a week for a few hrs. i did finish the fuel delivery dilemma, i did flex lines out of the tank to the regulator hardline out to a fuel filter and out to the fuel rail with a line that is part flex to hardline
Alex - Dirty AL "One Piece at a Time"
Follow me on Instagram alex.barr.ios
smokedat is offline   Reply With Quote
Old 11-23-2018, 11:20 PM   #1155
smokedat
smokedat's Avatar
heres a pic of the line up to fuel rail
Old 11-23-2018, 11:25 PM   #1156
smokedat
smokedat's Avatar
i rebuilt the fuel injectors with new orings and pintle caps and clips and SS bolts
Old 11-23-2018, 11:32 PM   #1157
smokedat
smokedat's Avatar
i completed the dynamat in the cab and i mounted the steering column and steering wheel with the steering u joints, non of this is final in the pic the horn button is also sunk in not in place i more so mounted all this to relief space
Old 11-23-2018, 11:55 PM   #1158
smokedat
smokedat's Avatar
i also started on the truck wire harness, i wanted to use the same one but it seems to bulky the nature of the design going from firewall to inside of the cab plus it has allot of unnecessary wires since i deleted wipers heater & AC. its just to big for my needs so i will be getting a new one from speedway and will extend if needed and route away from view as much as possible, i will sleeve it with braided expandable loom and hang it with SS cushion clips. Im soldering and heat wrapping the joints.
Old 11-23-2018, 11:59 PM   #1159
smokedat
smokedat's Avatar
for anyone in need i highly recommend this weller WSD51 hardly any wait it heats up in seconds
Old 11-24-2018, 12:04 AM   #1160
smokedat
smokedat's Avatar
this is the harness i will use MFG. Part #: 91064022
Speedway Universal 22 Circuit Wiring Harness
i will need a new female plug to math the one on my column from ididit
ididit Steering 3106050010 Female Wire End Plug
Old 11-24-2018, 12:37 PM   #1161
dmack91
dmack91's Avatar
It used that speedway kit when I wired my 1950 F1. Easy to use and only ran into one problem with an error in their diagram, which they walked me through.
Got the 12 circuit kit for my k20 since I didn't use half the circuits when I did the F1. Not as happy with the smaller kit as it just doesn't seem as simple to use.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 11-25-2018, 12:35 PM   #1162
smokedat
smokedat's Avatar
i mounted the radiator and fan shrouds and a radiator catch tank from moon, i ended up changing my fans and shroud for an aluminum shroud and 2 - 14" fans, with an aluminum replica of the cap. For the radiator mounts i used an aluminum universal kit that i ended up cutting to my needs from Speedway. As for the plumbing from radiator to tank still needs to be done in which case i think i may end up hard lining it
Old 11-25-2018, 12:49 PM   #1163
Dads79GMC
Dads79GMC's Avatar
Great info and build!! Mike
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 11-25-2018, 12:58 PM   #1164
smokedat
smokedat's Avatar
i mounted the pedals but the gas pedal is not adjusted, on a 92mm Holley throttle body and. The air intakes are not installed but they do clear the space
Old 11-25-2018, 12:59 PM   #1165
smokedat
smokedat's Avatar
thanks mike
Old 11-27-2018, 03:25 PM   #1166
Mjminino
Old 12-09-2018, 10:40 PM   #1167
smokedat
smokedat's Avatar
so i got the harness and i made an aluminum mount from materials i had laying around, some 1/4 angle with a 1/4 flat bar with some spacers to kik it out. I installed it conveniently on the left side of the column more or less where the original location is. i still need to drill and route the wires to their locations, and i will also be making a 12 source fused block with 12 relays for the pcm and accessories related to swap only, i wont be utilising all 12 but i rather have the option, so the truck wiring will be seperate from the LS swap accessories. I will post more on this later as i am still piecing together this set up.
Old 12-09-2018, 10:44 PM   #1168
smokedat
smokedat's Avatar
here's a pic of the crimpers i have i recommend them, there ratchet type and the dies interchange without tools very easy slide in and out
there from Pertronix T3001
Old 07-22-2020, 07:00 PM   #1169
z71se
Crickets any updates?
Old 08-21-2020, 03:56 PM   #1170
z71se
Is this project still going?
Old 08-22-2020, 08:03 AM   #1171
It looks like he has not been on here for over a year.
Old 08-23-2020, 02:20 PM   #1172
tinydb84
tinydb84's Avatar
That steering wheel is just too much (in the most badass way).
David
Instagram: myfabguy
Old 09-26-2022, 12:04 AM   #1173
smokedat
smokedat's Avatar
so I finally got enough mojo to post an update, don't know how else to word it.
here I am at the exhaust part of it. I got an X pipe and the 10's from flow master, random bends and turbo flanges from amazon and this is what I ended up with.
Old 09-26-2022, 12:13 AM   #1174
smokedat
smokedat's Avatar
sections welded out and hanger
Old 09-26-2022, 12:16 AM   #1175
smokedat
smokedat's Avatar
side exit
73c10, c10, cheyenne, ls1, swap
