My 56 build
I started this thread by accident in the general forum, so I decided to move it here as this is where it should be. The first pictures I took with my phone had the wrong orientation. Sideways... so I’m only including a few of how the truck started! It came with a 350 /700R4 combo, which I’m replacing with an LS. I haven’t obtained one yet, but have lots to do in the meantime!
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build Last edited by Rickysnickers; 07-11-2021 at 06:12 PM. |
Re: My 56 build
Enough of the sideway pics
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
Re: My 56 build
This is how the c-notch ended up. And I built the shock mounts. The 3rd pic is where my final ride height should fall in the rear. I also added some 45 degree braces on a downward angle to prevent any frame flexing. Also notched them so I can still fish any brake and fuel lines down the frame. Then I c-notched the front for the rack and pinion
Re: My 56 build
Now That i have the frame to my liking I began sheet metal work. I don’t mind the sheet metal work, but don’t really care for the finish work. I’m too much of a perfectionist
Re: My 56 build
Here are some of the problems I have to fix! Thanks to others on this forum I decided to be more adventurous and build some of the cowl panels that needed to be replaced! So after lots of pounding n shaping I came up with new lower cowls and kick panels
Re: My 56 build
After further review of the cab I decided I needed to brace the door openings as well. I had to completey remove the a post from the step and replace the lower. I ordered a bunch of new sheet metal parts including new front cab supports. Had to build a frame to support the front of the cab using the cowl. Also cut out my new firewall. I left the hinge mounts in place so I wouldn’t have to relocate them! At this point I could finally start putting everything back tighter!
Re: My 56 build
This is where I am at currently. Just finished up the left front of the cab and am waiting for a lower a post to be delivered ( thought I was going to be able to salvage the original... wrong) her are the pictures or the left side complete. After I finish the right hand side and replace the floor I’m also going to redo the steps!
Re: My 56 build
i really recommend to hang a door to check gaps and general fit. it's better to find a fitment issue sooner than later when the panels are already welded in. it will set the gap below the door as well. also remove the striker plate so it doesn't affect the fit by pulling the door up or down.
just a thought |
#9 | |
Re: My 56 build
![]() ![]() Join Date: May 2015
Re: My 56 build
id use original ...
![]() Join Date: Jul 2012
Re: My 56 build
I vote original as well. Nice fab work!
Re: My 56 build
Have made some more progress. Finished the right a-post, kick panel and cowl. Now onto the floor pan and firewall. Spent most of the day fitting the floor pan. I also tore into my original hinges and there really worn! One pin was already replaced with a 3/8” bolt and another has a replacement hinge pin. The hinge with the new pin is still really bad
Re: My 56 build
After sleeping on the cup washer idea I decided to just make them. Was really simple. A washer and a piece or pipe. Got the floor welded in and the firewall tacked in place. Slowly making progress! Had to get creative with the ratchet strap to straighten the firewall! Next I’m going to replace the steps then order hinges and fit doors. I’m not going to weld the center of the floor together yet. Figure I might have to move it to adjust door gaps. We’ll see
Re: My 56 build
if anybody else is wondering about those cupped washers, I have used the washers from newer cars with strut suspension. they use a washer similar to that on the struts. beware of the springs in there when undoing nuts though.
#15 |
Re: My 56 build
Over the last two week I’ve managed to remove both steps. Found rust holes filled with mud in both lower b-posts. Ordered new for each side along with the step supports. Just cut my own steps. Plan on covering them with a piece of stainless... so flat works better. Also finish welded the firewall in place. Came out pretty good, but I’m a perfectionist
#16 |
Re: My 56 build
I’ve spent a lot of my last two weeks battling Mother Nature... won’t quit snowing! Today I replaced the drivers cab corner. The passenger side was already done! Once I’ve replaced both lower b-posts the whole lower 12” of the cab will be new! Minus the rear half of the floor
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build Last edited by Jason 56; 02-18-2019 at 12:31 AM. |
#17 |
Re: My 56 build
nice.
do yourself a favor and cover up that glass, welding and grinding sparks will melt in and your glass will be toast. |
#18 |
Re: My 56 build
It’s already cracked n needs to be replaced
#19 |
Re: My 56 build
I managed to get a couple days of work done on the truck this weekend! I haven’t been able to do anything to it due to snow removal... it’s finally warming up some this far north! When I bought the truck the right hand cab corner was already replaced so I figured I wouldn’t need to fix that corner. Couldn’t of been more wrong! I could see a patch panel on the inside of the corner, but didn’t expect 1/4” of bondo covering up crappy sheet metal work. See picture #3 of the piece I cut out. So a weekend of patching the corner back together. Had to make a 2” filler panel to make up for the crap I had to cut out. Last thing I did today was cut out all the bracing n began fitting doors. The center of the floor n the step still aren’t welded in. This leaves the bottom half of the cab still adjustable! So far the 1st door looks good. Once both doors are fitted I’ll weld everything together. Cab is almost done
#20 |
Re: My 56 build
Got the truck pushed out of the garage so I can see the stance. I got the doors fitted n the cab floor welded back together. The steps are in place and the door gaps look good. I had to make a cut parallel to the passenger side door to fix that gap. I see that’s quite common from other posts. Now onto the front fenders. I was pretty bummed to find that they were in worse shape than they looked. Going to order half fenders for each side. Also the piece over the headlight on the right side. I have to reinstall my rocker panels, but noticed they don’t line up with the front fenders. I put the fenders on so I could make sure they would line up before I weld them back on. Is this a common problem on these trucks. If so what’s the best way to fix it?
#21 |
![]() Join Date: Mar 2007
Re: My 56 build
Nice fab work....from one Michigander ( SW Lower MI) to another...
Keep it up.... Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#22 |
![]() Join Date: Jan 2015
Re: My 56 build
lookin good bud
#23 |
Re: My 56 build
Cool project and great job on the chassis and body work!
#24 |
Re: My 56 build
Thanks guys... it’s supposed to be nice this weekend so I can roll her out n get some pictures of the stance. I’ll post them asap
#25 |
Re: My 56 build
Here’s some pictures of the stance. Apparently my dog is photogenic
