Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WIW
Old 01-08-2020, 03:13 AM   #1
61ChevyPanel
Active Member
61ChevyPanel's Avatar
Looking for info on NOS Bendix Hydrovac
Can anyone identify this unit? I believe I won this in a raffle from Golden State Pickup Parts at a Magic Mountain truck show in 1983. It's been in my closet since then. I don't think the speedo cable goes with it but I had it in the same box. The only number I found was on that little brass tag and nothing came up on an online search. I don't have a use for it.
61ChevyPanel is offline   Reply With Quote
Old 01-08-2020, 08:34 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Looking for info on NOS Bendix Hydrovac
You posted in the for sale section. Is this for sale?
If not you might want to post this in - https://67-72chevytrucks.com/vboard/...isplay.php?f=6
Or even in - https://67-72chevytrucks.com/vboard/...splay.php?f=24
Good luck on your information search.
Old 01-08-2020, 08:39 AM   #3
VictoriaHardware
VictoriaHardware's Avatar
I have a lot of info at home. I'll have to check tonight. I believe it is a unit that mounted underhood on the fenderwell of light duty trucks. GMC's I think.
VictoriaHardware is offline   Reply With Quote
Old 01-08-2020, 09:06 AM   #4
The Rocknrod
Moderator
Here is a thread on it - http://67-72chevytrucks.com/vboard/s...d.php?t=747457
A video of the inner workings - https://www.youtube.com/watch?v=keChCevuKk8#t=200
Old 01-08-2020, 08:34 PM   #5
VictoriaHardware
Tons of info here-
https://www.bepco.biz/sites/default/...20PRODUCTS.pdf
Old 01-09-2020, 12:25 AM   #6
CustomGMC’s
Looks like a 63-66 c60 setup that would have mounted on the frame.
CustomGMC’s is offline   Reply With Quote
Old 01-09-2020, 10:18 AM   #7
GMCNUT
GMCNUT's Avatar
measure the diameter of the booster body and if its 7" let me know, but from what I see that is the bigger one for 4000 series up larger size trucks
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 01-09-2020, 10:21 AM   #8
GMCNUT
GMCNUT's Avatar
measure the width of the booster body (what the J hooks are holding together) and the diameter - it sure looks small in these pictures. If it turns out to the the smaller booster like it looks I want it
Old 01-10-2020, 08:47 PM   #9
61ChevyPanel
Active Member
Thanks everyone. I listed it in this section to get an idea of what it's worth so I can post it for sale on this site. Does anyone know the value? It's been in a dark, low humidity, climate controlled room for the past 38 years so it looks to be in very good condition.
Old 03-24-2024, 07:29 PM   #10
58ApacheGuy
I know it's been a few years, you still have this unit?
58ApacheGuy is offline   Reply With Quote
Old 07-12-2024, 03:53 AM   #11
61ChevyPanel
Active Member
Sorry I sold this back in 2020.
