Old 10-28-2016, 10:17 PM   #126
factorystock
factorystock's Avatar
Re: Rarest factory paint combos
Originally Posted by GMCNUT View Post
I found a matching Tahiti Coral two-tone long fleetside identical to yours in a junkyard one time and found it super interesting because it also came with the special Sage Green interior which was only used with this Tahiti Coral exterior - totally different than the normal Bluish Silver interior color used in 1961.
Interesting, would like to find some type of documentation from 1961 about the Sage Green interior color, thought it was only used on 60's GMC big rig cabovers , aka "crackerboxes".
factorystock is offline   Reply With Quote
Old 12-04-2016, 05:10 PM   #127
factorystock
Another GMC in a rare factory applied special order color, this one appears to be a gold brown metallic color?. Funny how much harder it is to find a Chevys in a special order color compared to GMC's. An interesting observation, IMO, most Chevys with special order paint were owned by governments or fleets, most GMC's seem to have been privately owned. Maybe GMC salesman pushed selling more unique colors with a lineup of trucks that had more unique mechanical features than the competition?
Old 12-05-2016, 01:10 PM   #128
GMCNUT
GMCNUT's Avatar
I'd have to go dig it up but somewhere I have some documentation on it seems like. I wish I had taken photos of the sage green factory painted interior on that longbed I found that time - I do however have one of that trucks' sage green door panels w/ green based armrest so I will dig that up and attach here
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 12-05-2016, 01:12 PM   #129
GMCNUT
GMCNUT's Avatar
This looks to be the very same brown used on my 66 GMC Suburban
Old 12-05-2016, 03:03 PM   #130
60-66
60-66's Avatar
From the 1960-1961 GMC data book
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 12-05-2016, 03:47 PM   #131
GMCNUT
GMCNUT's Avatar
Jon, this is changing the subject, but do you know what the two tone paint code is for 1966 Chevrolet Dark Aqua & White by chance?
Old 12-05-2016, 04:28 PM   #132
60-66
60-66's Avatar
Old 12-05-2016, 05:05 PM   #133
GMCNUT
GMCNUT's Avatar
Thank you Jon! I knew you'd know it
Old 12-05-2016, 09:44 PM   #134
yelmer
here is a tag that i pulled off do not know the paint code also says 7600 instead of 7500 paint code 559
yelmer is offline   Reply With Quote
Old 12-06-2016, 08:53 AM   #135
60-66
60-66's Avatar
was this truck Green Mike ?
Old 12-06-2016, 12:08 PM   #136
yelmer
I cannot remember jon I took it off years ago I looked the code up it comes back blue? Do you know?
Old 12-06-2016, 12:21 PM   #137
60-66
60-66's Avatar
I found it as a 1965 Coca Cola Sprite truck fleet color called light green ? This looks like a 1965 tag.
Old 12-09-2016, 05:12 PM   #138
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by 5661DWL View Post
Just starting restoration on a 1961 Chev Apache 10 in Tahiti Coral/White. This is the only truck I've ever seen in this color. 283ci/4spd truck.
Hey, What's up?!
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 12-09-2016, 10:12 PM   #139
LostMy65
LostMy65's Avatar
From another thread:
Originally Posted by 60_Apache View Post
1961 color
Old 12-13-2016, 05:24 PM   #140
GMCNUT
GMCNUT's Avatar
5661DWL - I finally snapped a few quick pics of my most recent acquisition - the Tahiti Coral and White 61 I told you about earlier in this thread. Here are some shots. Had a 235 from the factory and my buddy bought an incredibly well preserved 61 Chevy Viking 70 series firetruck and robbed the 8,800 original miles 348 Big Block from it and stuck it in this little 61....runs smooth as silk and purrs like a kitten. Great motor. The cannister on the drivers inner fender is dealer installed vacuum power brakes - available as an option back in 61....pretty cool
Old 12-13-2016, 07:15 PM   #141
5661DWL
GMCNUT, Very Cool. Especially with the 348 and power brake booster. I will get more pics of our truck when I am out there again. Thank you.
5661DWL is offline   Reply With Quote
Old 12-14-2016, 08:30 PM   #142
factorystock
X2! Period air cleaner and generator make this '61 look like a factory job.
Old 12-15-2016, 11:52 AM   #143
GMCNUT
GMCNUT's Avatar
Thanks - I thought it was really neat that if you run the engine suffix and casting # it comes up as "1961 348 - truck" so technically speaking its "correct" and numbers matching minus the overall fact that Chevrolet did not offer the 348 in a 10 series truck.
Old 12-15-2016, 09:40 PM   #144
factorystock
Yeah, as a regular production option, but, there have been cases were the Central Office (COPO) got involved and special ordered equipment for finicky customers who insisted on paying the extra cost.
Old 06-30-2019, 09:14 AM   #145
blackbart63mule
blackbart63mule's Avatar
Found this over in Let’s Post 60-66 SUBURBAN Only Pictures...
Black Bart-63 panel http://67-72chevytrucks.com/vboard/s...d.php?t=664660
blackbart63mule is offline   Reply With Quote
Old 06-30-2019, 10:57 AM   #146
blackbart63mule
Here ya go!
Old 07-02-2019, 12:20 AM   #147
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
What a KOOL Truck
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 04-29-2020, 12:35 PM   #148
pdxhall
pdxhall's Avatar
Does anybody have any pics of the 62-63 only Sea Mist Jade Metallic? I have a tailgate I picked up for my truck that I believe was this color and I have only come across one truck that I believe is the color.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 04-30-2020, 02:22 AM   #149
oem4me
check this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=637932
Old 04-30-2020, 09:59 AM   #150
bigmoe
bigmoe's Avatar
I see on the 66 color chips they have a silver. Anyone ever see a factory silver 66?
bigmoe is offline   Reply With Quote
