06-26-2020, 11:50 PM | #176 |
Re: My 56 build
A little more progress . Now to make the tracks and finish the brackets for the wheels.
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
06-27-2020, 07:59 AM | #177 |
Re: My 56 build
Looks and works great Jason!
Mark
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
06-27-2020, 09:32 AM | #178 |
Re: My 56 build
Great job!
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
06-30-2020, 11:30 PM | #179 |
Re: My 56 build
Look what followed me home! Gen V 2016 5.3 with 8L90. Convinced my wife to let me keep it Simple conversion to 2wd.
06-30-2020, 11:33 PM | #180 |
Re: My 56 build
A few pictures I took while I had the truck rolled out to clean the garage.
07-01-2020, 03:38 AM | #181 |
Re: My 56 build
Heck yes!!! Keep going man
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
07-01-2020, 10:57 AM | #182 |
Re: My 56 build
what a beauty !.......... and with such a high level of workmanship.
Keep it going, and thanks for posting your progress, always interesting.
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
07-05-2020, 10:59 PM | #183 |
Re: My 56 build
Worked on the hood some this weekend. Still a work in progress. Have to do some more adjusting to get it right. I’m getting closer!
07-05-2020, 11:04 PM | #184 |
Re: My 56 build
Also spent some time getting into the harness on my new engine. I plan on doing the stand alone harness myself. Just need to order the fuse/relay box. The wires running up over the dipstick is the transfer case part of the harness. Everything else seems straight forward.
07-06-2020, 09:21 AM | #185 |
Re: My 56 build
I'm interested to see how you do the harness and the 2WD conversion. I haven't done hardly any research on the 2WD conversion, but the first option I found was a new tailpiece and a couple small parts for like $600 which seems excessive.
What are you using for references for the harness rework? I haven't been successful in finding a source like LT1swap for the Gen V.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
07-06-2020, 09:28 PM | #186 | |
Re: My 56 build
https://m.youtube.com/watch?v=vRWWpSL5PlM As far as the harness, I’m doing research. Most of it is left alone. I’ve found wiring diagrams and ecu pin outs. As far as sensors, I only need to delete the downstream O2 sensors. Otherwise buy a fuse/relay box and run all hots to the proper fuse. Isolate and lengthen OBD2 and gas pedal wires. I’ll need 2 relays, one for the ignition and one for the fuel pump. I’m just going to use a walbro(spelling?) 255 pump and the C6 filter/regulator setup. We’ll see, I’ll keep you updated
07-07-2020, 03:59 PM | #187 |
Re: My 56 build
Mdpotter... I found the tail shaft at summit for about $60
https://www.summitracing.com/parts/ado-24267251 housing at rockauto for $122 https://www.rockauto.com/en/catalog/...+housing,17929
07-07-2020, 04:27 PM | #188 | |
Re: My 56 build
I'm learning that a lot of these Gen V swap parts are so expensive just out of a lack of support or product offerings so companies are making fat profits on their parts. With a little research, all the challenges that come with Gen V swaps don't seem to be big issues at all. High pressure/PWM fuel supply, 2WD conversion, vacuum pump, A/C compressor mounting, power steering, harness rework.
07-14-2020, 02:30 PM | #189 |
Re: My 56 build
WOW--What incredible work...
I did my first harness this year and the one thing I would do different is using a pre-made pigtail. I would be happier with this fusebox than the one i made and wired myself. There are cheaper alternatives on ebay and other sources https://www.michiganmotorsports.com/...ess-obd2-port/ Also the sideways pictures can be solved by opening the picture in "photos" for windows or something similar. It will probably show the correct side up, then just crop off the slightest edge of the photo and save it, then re-upload it. All of my pictures off my iphone do it. |
07-15-2020, 11:11 PM | #190 |
Re: My 56 build
truck looks great. What color are you going to paint it??
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
07-16-2020, 07:09 PM | #191 |
Re: My 56 build
Right now I’m leaning towards AC Bristol princess blue with a pearl white roof n engine compartment. But who knows... I’ve changed my mind three times since I’ve started
Here’s a link to an AC Bristol in that color. It changes from blue to silver depending on the light https://www.mecum.com/lots/CA0819-38...stol-roadster/
07-19-2020, 10:58 PM | #192 |
Re: My 56 build
Fixed the gap on drivers door... still have the passenger side to do. Been trying to figure out what to do about the front bumper. First two pictures are an original bumper. Last two are from an old bumper that also came with truck. I chopped it down, but not sure I like it? Not really excited about the V shape. Looking for input on what everyone thinks. If I go with the narrower one I’m going to build a front roll pan to fill in the area between the fenders.
07-19-2020, 11:10 PM | #193 |
Re: My 56 build
Also fixed my front running/blinkers...again. I was going to use Jeep style headlights with the blinker being part of the headlight. Then saw barnfind62’s 1950 Pontiac taillights and jumped on that ship... now the originals just flow with those taillights. So I frenched them in like the taillights. I threw a picture of the taillights at the end... you can see the theme!
Quick question... anyone know how thick the rubber bumpers are that go on the side of the hood? I’m gaping the hood next.
07-20-2020, 02:41 AM | #194 |
Re: My 56 build
That about the thickness of a paint stick. That’s what I used to do the gaps. What did you use to French in the front park light?
07-20-2020, 08:20 AM | #195 |
Re: My 56 build
I just made them from 14 gauge. I found this hole cutting jig on another post. Helps cut perfect circles.
07-20-2020, 11:48 AM | #196 |
Re: My 56 build
On your front bumper feedback: I intend on flipping my stock one upside down but the top of it needs to be level with that body line. Can't do it with just flipping the stock brackets as it would sit too low and look goofy. When getting it up high enough you would have to angle the end of the frame back for clearance for the "new" bottom portion. Chip Foose put 1st gen Camaro bumpers on his "Z10" both front and rear. Those are thin and V shaped - check it out.
07-21-2020, 09:09 AM | #197 | |
Re: My 56 build
07-21-2020, 10:11 AM | #198 |
Re: My 56 build
....a front roll pan with some kind of 'air dam' in the design???
I just want to see some more of your metal fab skills.
07-22-2020, 12:28 AM | #199 |
Re: My 56 build
We’ll see what I come up with
07-22-2020, 12:32 AM | #200 |
Re: My 56 build
Nice work! Love the frenched lights...did them on mine as well. I think the Foose 1st gen idea would be great on yours! I flipped mine but I had to make brackets anyway because of the new frame. Keep up the great work!!!
