Old 07-18-2020, 12:16 PM   #1
harrij4
DIY CST Chrome Interior Bedside Strips
This was buried in another thread of mine, but at the suggestion of a forum member, I'm breaking it out to make it easier to find.
I thought I'd share what I think is a pretty successful "hack" to create your own CST chrome interior bedside strips (the ones that hold the top of edge of the vinyl panels in place).
Step 1: Order 2x of these Schluter Rondec 3/8 Stainless Steel bullnose tile edging. DO NOT TRY TO USE ALUMINUM! The AL ones are hard anodized and you will be unable to polish the rolled edges without a witness line.
Step 2: Trim to length. Because the bed-rail is recessed you have to measure to the outer edge of the two S-curve profiles at either end of the bedrail. The final product is longer on the inboard side than the outboard side, so make sure you measure and trim to the longer inboard length.
Step 3: Cut a rough profile. Cut a rounded taper from bottom to top, and a a slight taper from back to front (outboard to inboard). The outboard to inboard taper should match the S-curve profile of the recesses in the bedrail. Note, the front and rear S-curves are slightly different, for a perfect fit you'll want to measure and cut them specifically.
Step 4: Roll the cut edge. I tried several approaches but ultimately just ended up using some stubby needle nose pliers to slightly roll the cut edges under.
Step 5: Sand & Polish. The pliers will leave some pretty deep gouges, so you'll have to sand them smooth. Then polish the living hell out of the entirety of both pieces.
Step 6: Rivet in place. Prior to riveting, I applied a half-width of some very thin 3M trim adhesive tape. This helps with mounting, but more importantly it prevents any buzzing between trim strip and the bedside. I used very small stainless steel rivets about every 10" to fasten the trim strips to the bedside. You could possibly use screws, but they would need VERY low-profile heads so that the vinyl panel's top edge can still slide up into the trip strip.
Step 7: Install your CST panels and enjoy!
I'm personally thrilled with the way these came out, and the whole thing cost ~$100 which is about 1/10th the price of tracking down the real thing, then getting them re-plated. But, I know for some folks they'll want the authentic parts, and more power to ya'! Just wanted to share this as an option.
harrij4 is offline   Reply With Quote
Old 07-18-2020, 12:17 PM   #2
harrij4
Re: DIY CST Chrome Interior Bedside Strips
And, the finished product:
Old 07-18-2020, 12:32 PM   #3
wesmigletz
wesmigletz's Avatar
Looks good. Nice write-up. Thank you for sharing
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
www.picturetrail.com/wesmigletz
wesmigletz is offline   Reply With Quote
Old 07-18-2020, 01:04 PM   #4
Thealien
Thealien's Avatar
What he said!
I already bought the strips because of your discussion. Probably be a year before I need them.
Old 07-18-2020, 03:24 PM   #5
harrisoncole4
harrisoncole4's Avatar
This is a great alternative to the hard to find and expensive originals!
1969 K5 Blazer - 507 Light Blue - http://67-72chevytrucks.com/vboard/s...d.php?t=802858
harrisoncole4 is offline   Reply With Quote
Old 07-19-2020, 10:11 AM   #6
Classics Fan
Nice work and great story-by-step directions! Something that caught my eye was your statement that alluded to OEM rails in new condition being in the range of $1k. I spent a few minutes looking online and didn’t see any new, used or repops. I’m interested in knowing if OEM’s are really that pricey. My 1971 Jimmy came without the panels but the trim was there and is like new.
Classics Fan is offline   Reply With Quote
Old 07-20-2020, 12:21 AM   #7
harrij4
My $1k price is just my own ballpark for what I've seen in the last couple years. IF you can find them (as you noted, usually you can't), they run $500-$750 a pair. And, since they were low carbon steel with 1970's quality chrome (read: crappy) they inevitably need replating - something that's getting more and more expensive due to reduced B2C demand and more environmental restrictions. So, by the time you're done....$1k. The odd thing is, the earlier 1st Gen door panels used the same trim profile on the top. Whoever is making repops of those could probably make the bedside trim fairly easily....but they don't.
Old 01-10-2021, 12:50 AM   #8
a1vintage69
a1vintage69's Avatar
Reposting it to the top!
a1vintage69 is offline   Reply With Quote
Old 01-10-2021, 04:02 PM   #9
wesmigletz
wesmigletz's Avatar
I just ordeed the strips from HD. I was reminded when I saw your post on FB the other day. Thanks again for sharing.
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
Old 01-10-2021, 07:59 PM   #10
Blazerowner
Blazerowner's Avatar
This is great. Thanks for the write up.
Kirk
72 Blazer CST 4wd highlander
66 Nova
Blazerowner is offline   Reply With Quote
Old 01-10-2021, 09:35 PM   #11
68panelman
68panelman's Avatar
Perfect alternative
68panelman is offline   Reply With Quote
Old 04-28-2022, 03:56 PM   #12
mcmlxix
Collector of Projects
mcmlxix's Avatar
Looks great!
Rich
1972 K5 Blazer CST Click HERE
Old 04-28-2022, 06:00 PM   #13
CG
BlahBlahBlah
Thats really thinking out of the box, nice job. I work at Lowes and I see those all the time, I had no idea they were Blazer parts haha!
Old 04-28-2022, 06:24 PM   #14
Blazerowner
Just to add to this that these are reproduced. Not to take away from this option, but you can pick these up from Motor City k5.
https://www.motorcityk5.com/i-13858-...=category:9936
Kirk
66 Nova
Old 05-01-2022, 09:06 AM   #15
52napco
That worked great..was going to send mine out to be chromed for $825 thanks for the heads up.
52napco is offline   Reply With Quote
Old 05-01-2022, 10:05 AM   #16
a1vintage69
I got another Blazer last month and didn't look to see if the chrome strips were there. I just went out and looked, wow they are present. It's a good feeling to find them just like when a found the spid in the console.
Old 05-02-2022, 09:28 PM   #17
harrij4
That's awesome! (And definitely new since I created my knockoffs). Motorcityk5 just keeps making great parts!
Old 05-02-2022, 11:04 PM   #18
Blazerowner
I agree. I think these are made in the USA as well. Good to have these options for sure.
Kirk
66 Nova
Old 05-03-2022, 07:28 AM   #19
A1971Blazer
A1971Blazer's Avatar
These cost less than I paid to have an original set re-chromed..
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
