Old 07-31-2020, 10:11 PM   #76
Ben IV
Re: 70 gmc DIY build
So I had everything back together and took it for it's maiden voyage as a short bed. I know the long bed guys say short beds don't ride as good but there isn't much difference. But it stops better and spins the tires better.lol I'm going to need a posi of some sort. But I'm pretty Damn happy with it. Except the stance that is.
70 GMC custom short bed conversion
69 GMC panel truck
Ben IV is offline   Reply With Quote
Old 07-31-2020, 10:33 PM   #77
lolife99
67-72 parts collector,…
lolife99's Avatar
Looks perfect!
Keith
Convert to disc brakes.
Old 07-31-2020, 10:36 PM   #78
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks great
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 07-31-2020, 11:07 PM   #79
Ben IV
Looks perfect!
Thanks looked like a 4x4 though.😂
Originally Posted by Ol Blue K20 View Post
Looks great
Appreciate it.
69 GMC panel truck
Old 08-01-2020, 12:05 AM   #80
SCOTI
SCOTI's Avatar
Nailed it!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-09-2020, 06:12 PM   #81
Ben IV
Couldn't live with the rake so I installed a set of drop shackles which leveled things out nicely. That will have to do till I get everything together to lower it for real.
69 GMC panel truck
Old 08-09-2020, 06:52 PM   #82
Kronald_70GMC
Kronald_70GMC's Avatar
That looks much better! How low are you planning to go?
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 08-09-2020, 09:48 PM   #83
cornerstone
cornerstone's Avatar
And just like that... he's done..... lickety split...
I know some guys that take that long to do a brake job!
Very impressive work and speed!
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 08-10-2020, 03:01 PM   #84
T2true
I'll be following this build, for sure.
T2true is offline   Reply With Quote
Old 08-10-2020, 08:46 PM   #85
Ben IV
4..5/6 that's what I have on my panel and like it.
I'm just now caught up. Was mostly at this point when I started the thread.
69 GMC panel truck
Old 08-12-2020, 07:52 PM   #86
kvn1011
Kvn1011
kvn1011's Avatar
looking good!
kvn1011 is offline   Reply With Quote
Old 05-15-2021, 06:09 PM   #87
Ben IV
Been a while since I've updated my progress because there hasn't been much. Just been enjoying it though I did change the tires. Put the tires from the 70 on my panel so I ran the chrome smoothies for a few days while getting the 4 nub 15x6.5's painted up. 2 were on the truck 2 were on the original owners winter tires so I was running 2 5.5 wide and 2 6.5 wide and didn't realize it.
If someone told me when I got my first c10 at 14 that some day I'd be running wheel covers and white walls I'd have told them they were crazy. But I love the look now.
69 GMC panel truck
Old 05-15-2021, 06:15 PM   #88
Ben IV
Picture with the smoothes which did look good and really filled things out in the back. Plus put a sport bumper on it. Couldn't find an original that matched the truck so I just bought a new one from the guy I've been buying parts from for the last 20 years.
69 GMC panel truck
Old 05-15-2021, 08:32 PM   #89
chewychevy67
That is absolutely perfect. I love it
chewychevy67 is online now   Reply With Quote
Old 05-15-2021, 10:17 PM   #90
Ben IV
Thanks, the pictures do it too much justice though.
69 GMC panel truck
Old 05-18-2021, 04:41 PM   #91
69Tom
69Tom's Avatar
So onto welding the frame back together. First a little background on myself. I've been working in industrial steel fabrication more than a decade and have welded on everything from oilfield trucks to pressure vessels for refineries. I chose straight cuts because I see no need for the "z" cut. I've done straight cuts in various types of materials that hold 10's of thousands of pounds so it's good enough for a half ton pickup.
So here's a bit of a P.S.A on what I feel is the proper way to do it. First thing you need is a welder rated for the thickness you're welding (220 volt machine). You need mig wire with shielding gas. I'm using 75% argon 25% co2 with .035 er70s-6 wire. Even though I have welding experience I took the pieces of frame I cut out and cut them to make multiple joints to practice on which I highly recommend. It will allow you to get your machine dialed in and work on your travel speed.
When it comes to prepping the 2 halves of the frame you want to put a bevel on the inside of the frame rails almost to a point and leave about a 1/16" gap between the front and rear rails when they go back together. This is to achieve full penetration welds. You want to weld the inside of the frame rails first then grind into the back side of your welds on the outside of the frame with an 1/8" grinding disk to make sure you're achieving full penetration and welding to nice clean steel. When you knock down your welds don't go crazy, stop when they are flush.
First picture shows the prep and fitup you want. Second shows how running a few practice joints helps get things dialed in. My first weld had porosity from the ceiling fan being on. If you get any porosity you need to grind it completely out before continuing. Third picture shows the penetration on the outside of the frame. As you can see the first weld didn't burn all the way through the second and third is what you're looking for. Last picture shows the first weld ground into the weld then the weld after finishing.
Hopefully I wasn't too preachy or long winded but I see a lot of sketchy scary welds on frames. If cutting down your truck is your first welding project I strongly recommend watching some quality how to videos and getting some scrap to practice on before moving on to yourframe.
Wow. Ben, would you like to come to Arizona for a visit? I'm about to do this to my frame. Haha.
69Tom is offline   Reply With Quote
Old 05-18-2021, 05:51 PM   #92
SCOTI
SCOTI's Avatar
Looks perfect!
Looks great
Appreciate it.
What is your plan for the drop?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-18-2021, 09:31 PM   #93
Ben IV
If you're in Arizona look up Metaloxfab.
69 GMC panel truck
Old 05-18-2021, 09:42 PM   #94
Ben IV
Shooting for 4.5/6 not sure exactly what I'm going to get in the rear yet. It's a leaf truck so I bought new saddles to weld on instead of spending more money on a flip kit. Already have about everything I need. Bought a whole front end from a squarebody so I can rebuild everything before I tear my truck down.
69 GMC panel truck
Old 05-18-2021, 10:29 PM   #95
Ben IV
Picked up a front end to rebuild and have accumulated most of the parts I'll need. For the front cpp drop spindles and 6 lug rotors. UMI 2" drop springs. Moog everything to rebuild the front end PST polygraphite control arm bushings. Delco master and brake hoses, front end has all the brake lines and proportioning valve on it so I'm planning on using them. Also bought a Redhead quick ratio steering box. For the back I bought new perches spring plates and Ubolts from Roughstuff specialties. I already have 1 to 2" drop shackles in the rear I can leave them or go back to the stock shackles depending on what flipping the axle gives me.
69 GMC panel truck
Old 05-19-2021, 01:27 PM   #96
69Tom
69Tom's Avatar
Definitely looks like they do really nice work. I shot them a PM on Facebook for an estimate.
Old 05-19-2021, 01:51 PM   #97
68Gold/white
Bumper looks good!!!
Which color of blue is that???
68Gold/white is offline   Reply With Quote
Old 05-19-2021, 02:41 PM   #98
SCOTI
SCOTI's Avatar
It's pricey but money well spent vs. potentially screwing up nice/clean sheet metal.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-19-2021, 02:46 PM   #99
69Tom
69Tom's Avatar
Well, I actually have a short bed for my truck, so no sheet metal work needed, luckily. Just would like some nice welds on my frame. If they weld like Ben, that's a couple pretty easy straight cuts and some welding. Shouldn't be too bad, I wouldn't think.
And back to regularly scheduled programming of Ben's build....
Old 05-19-2021, 04:44 PM   #100
hewittca
hewittca's Avatar
Very awesome work on the shortbed conversion, definitely learned some things that I could have done different/better if I were to go back and do another.
With the caps and white lines, your truck looks a lot like my new one! You are beating me to the drop, so I'm following along for inspiration! Keep up the good work (and keep us posted).
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
