12-21-2020, 09:43 PM | #251 |
Re: NJ Suburban
looking good ......
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
12-27-2020, 03:06 PM | #252 |
Re: NJ Suburban
Nice work. You've come a long ways.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-02-2021, 10:57 PM | #253 |
Re: NJ Suburban
Inside done with base. Clear going on tomorrow!
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
01-07-2021, 10:34 PM | #254 |
Re: NJ Suburban
It's been fun doing mechanical work for a change instead of body work! Drive shafts rebuilt with new universal joints. Also new transfer case output shaft seals and speedy sleeves.
01-11-2021, 07:57 PM | #255 |
Re: NJ Suburban
Nice work sir!!
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
01-11-2021, 09:34 PM | #256 | |
The Older Generation
Re: NJ Suburban
I think I would rather do body work.... LockDoc
01-11-2021, 09:45 PM | #257 |
Re: NJ Suburban
Leon I've been fighting with the quarters on the truck for over a year. Believe me this is a welcome change!
Paul
01-11-2021, 10:39 PM | #258 | |
Re: NJ Suburban
If it has been that long I guess it would be... LockDoc
01-16-2021, 03:22 PM | #259 |
Re: NJ Suburban
01-21-2021, 05:24 PM | #260 |
Re: NJ Suburban
Sandblasted and painted the shift levers. The np205 transfer case shifter has bushings that aren't available anymore. After some research I made a "wet bolt" for the pivot shaft. I took out a 7/16 x 2 1/4" bolt that had lots of rust. The bolt has a small hole drilled along it's length and then through the side with a grease zerk tapped into the head. This will allow the pivot to be greased. The local hardware store didn't have nylon washers so I made some from a plastic milk crate and a hole saw.
Paul
01-22-2021, 12:46 PM | #261 | |
Re: NJ Suburban
"Necessity, the mother of invention"....... Good job! LockDoc
08-21-2021, 08:29 PM | #262 |
Re: NJ Suburban
Yikes it's been 7 months since I've updated the build thread. Now that the body is back on the frame and it's settled into position, the quarters are finally straight. I'm not sure what to do next. Originally I had planned on finishing up all the bodywork and paint the truck in my new pole barn. Then do the wiring and mechanical stuff. The town took 4 months to approve the plans, the guy doing site work is backed up and the pole barn company gave a March delivery/construction date. I wasn't going to do the mechanical work till the body was done. Below is a list of what I need to do. Just so I'm not staring at the truck for the next 8 months what mechanical work should I do? Any recommendations/suggestions are welcome.
Body: Hood: Strip, sand and do body work Hang the doors Install the core support Sandblast door hinges Mechanical Brake booster and master Wiring Radiator Hoses Steering Clutch linkage Finish engine connections Paul
08-21-2021, 08:44 PM | #263 |
Re: NJ Suburban
there you are!
I started out with nothing - and I still have most of it |
08-21-2021, 09:17 PM | #264 |
Re: NJ Suburban
I think I would start with the steering, then the clutch linkage, then the booster and master, then the radiator and hoses, then the wiring. I don't know what you have left as far as engine connections but if you have anything at the back of the block I would do that before installing the booster and master..... LockDoc
08-22-2021, 11:26 AM | #265 |
Re: NJ Suburban
One thing wish I had done at the stage you're at would have been to fabricate some mounting points for 2nd row shoulder harness seat belts.
I am going to take advantage of the impending repair work and convert my fuel tank to a non-vented gas cap. I am tired of the gas cap leaking when doing going around a tight right turn at speed with more than 1/2 a tank of fuel. Previously I installed a vent in the fuel tank sender and will route it to the driver's side and hook it to 72 Suburban style evap set up. Might be something to consider. What are you planning for bumpers? Have your rebuilt the door hinges? The kick panel vent doors on mine needed new seals installed. How is your heater core? It sure would be easier to replace with no front clip. I don't remember if you replaced the spring shackles when you installed the new springs.
08-22-2021, 04:15 PM | #266 | |
Re: NJ Suburban
Lots of good tips here thanks! I don't think I'll do the second row 3 point seatbelt brackets. I'm not sure I'll even put the second row seats in. Funny my Sub was my daily driver from the early 80's till 1997. Never had a problem with gas coming out of the gas cap! I have bumpers but haven't done anything with them yet. They could be sandblasted and primed. I'll probably go with white painted bumpers. I'll have to look up the rebuild kits for all the door hinges. Not sure I'll need to though. My 68 donor body was from a low mileage truck but I'll definitely check them out. A few months ago I rebuilt and detailed the heater box complete with new seals and a new heater core. One of the original 70 style kickpanel vents disappeared. Both 68 vents are in my pile of parts so I'll install them. Where did you find seals for them? Maybe that's something I can install too. The springs are the originals. Ride height is good but I should look up new shocks. Originally the truck was non power drums on all four corners. The guy I sold it to converted to power drums. I need to source a replacement master and booster assembly. The one in it is pretty ratty. Paul
08-22-2021, 04:38 PM | #267 |
Re: NJ Suburban
Paul
thanks for the update... congrats on the new construction I like to check it out in the spring ...we did some major Reno last summer added a family room and a kitchen out to the pool I haven't done a darn thing to my trucks remember if you need a hand let me know. I do have a car trailor now seeing up a wench here shortly if you need help on relocating the Burb Jess
08-22-2021, 05:40 PM | #268 | |
Re: NJ Suburban
08-22-2021, 06:32 PM | #269 | |
Re: NJ Suburban
Maybe consider just rebuilding the driver's door hinges. I didn't rebuild the hinges on my Burban but, after 30k miles the driver's door is starting to get loose. I can feel the door just starting to drag on the latch when I open the door. I may have pull the drivers door hinges over the winter and rebuild them. I mentioned the shackles as they have quite an effect on the how the truck drives down the highway. Worn ones will give you that wandering down the road feeling. Many folks don't replace them when they do a front end rebuild and the truck never quite drives as it should. Don't ask how I know this. Man oh man there's nothing better than white painted bumpers on a K model in my book! Looking forward to the end result. https://67-72chevytrucks.com/vboard/...698377&page=10
08-22-2021, 09:31 PM | #270 | |
Re: NJ Suburban
09-25-2021, 03:59 PM | #271 |
Re: NJ Suburban
Picking away at things. Steering column installed and waiting to install the rebuilt master and booster. Of course the gold cad paint is in USPS limbo. Working on the drivers door now. The recessed screw holes for the door latch were pulled through so had to make new ones.
11-18-2021, 11:16 PM | #272 |
Re: NJ Suburban
It’s getting too cold to paint here in NJ so the suburban is getting some mechanical work done. Installed spark plug heat shields, master cylinder/brake booster, clutch linkage and working on the e brake. Was missing the bracket that holds the end of the front cable to the frame so I made one.
11-19-2021, 09:01 AM | #273 |
Equal opportunity joke ofender
Re: NJ Suburban
Looking good Paul
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
11-20-2021, 09:39 PM | #274 |
Re: NJ Suburban
Nice work! I love doing that kind of stuff.
11-21-2021, 12:12 PM | #275 |
Re: NJ Suburban
Same here! It was a lot of fun and worked out perfectly.
