Old 03-19-2021, 11:50 PM   #401
forestb
forestb's Avatar
Re: New 64 Stepper Project
What product did you use?
forestb is offline   Reply With Quote
Old 03-20-2021, 09:06 AM   #402
The Rocknrod
Moderator
The Rocknrod's Avatar
Epiphanes.
Old 03-20-2021, 07:15 PM   #403
forestb
forestb's Avatar
Have you had experience with that product before?
Old 03-20-2021, 07:39 PM   #404
The Rocknrod
Moderator
in marine use yes. Takes some work and time to make it right. Not for the get it done fast crowd.
Old 03-20-2021, 08:21 PM   #405
forestb
forestb's Avatar
How does it hold up to the sun and rain? I did a 2 part marine varnish from por-15 and it didn’t work vary well at all. I am hesitant about trying it again with another product.
Old 03-20-2021, 08:53 PM   #406
The Rocknrod
Moderator
So if your hesitant, what would you use?
This is a real marine product, it's what they specialize in. Being in the sun and sea. I'm doubting my weekend at a car show will cause it harm.
Years ago i used varithane or deftane and i cant remember which, was peirside with that truck for a couple years (daily driver) and was stationed in las vegas a couple years. I never saw a wrinkle in that finish. Used white oak then too.
Old 03-20-2021, 09:40 PM   #407
forestb
forestb's Avatar
I’m sorry. I meant I’m hesitant to use it myself. My truck is always exposed to the elements. It is probably a really good product. I am hesitant to use anything.
Old 03-26-2021, 11:27 AM   #408
The Rocknrod
Moderator
Bed and wood getting close.
Old 03-26-2021, 11:30 AM   #409
The Rocknrod
Moderator
Tank view.
Old 03-26-2021, 11:32 AM   #410
forestb
forestb's Avatar
Is that a stock rear bumper? Can we get a pic if not?
Old 03-26-2021, 11:36 AM   #411
The Rocknrod
Moderator
I posted here earlier in the thread, not stock. Next generation - https://67-72chevytrucks.com/vboard/...&postcount=142
Old 03-26-2021, 11:39 AM   #412
forestb
forestb's Avatar
Vary nice. it tucks in nicely.
Old 04-01-2021, 08:48 PM   #413
The Rocknrod
Moderator
Got it started today on April fools day.
Forgot to tighten a heater hose clamp on the heater core. Fixed that.
Timed per Blueprint engines to 15 degrees BTDC (they say 12-16 degrees) vacuum plugged.
Topped off trans, power steering and radiator.
Started right back up, good sign.
Old 04-01-2021, 09:22 PM   #414
Joe Pass
Joe Pass's Avatar
As mentioned that bumper really sets it off....did you fab the brackets or stock ones worked?
Congrats on the first fire up
Joe Pass is offline   Reply With Quote
Old 04-01-2021, 09:27 PM   #415
forestb
forestb's Avatar
Am I correct in assuming it’s a stepside bumper?
Old 04-01-2021, 09:34 PM   #416
The Rocknrod
Moderator
Thank you.
1972 stepside bumper, used the 72 brackets also.
Old 04-01-2021, 09:40 PM   #417
Joe Pass
Joe Pass's Avatar
Nice touch....
Old 04-01-2021, 10:16 PM   #418
The Rocknrod
Moderator
Thanks Joe.
Old 04-02-2021, 12:33 AM   #419
justa dumb hick
justa dumb hick's Avatar
Wow- first start up, that’s great! Always an inspiration for continued momentum. Those Blueprint engines tend to be pretty good right outta the box. Congratulations on your milestone! I looked back to the first posting on this thread and it was April 6, 2015. A long road you have wandered since then.
-JDH
Insomnia is a terrible thing to waste
https://www.youtube.com/watch?v=jWYVs7widI0
(Misanthropic curmudgeon attempts starting old truck in house at 2AM)
justa dumb hick is offline   Reply With Quote
Old 04-02-2021, 07:20 AM   #420
The Rocknrod
Moderator
Thanks man. I can't believe it's been that long.
Old 04-02-2021, 01:12 PM   #421
pdxhall
pdxhall's Avatar
The truck is looking awesome and congrats on start up. Fun times coming soon.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 04-12-2021, 06:17 PM   #422
The Rocknrod
Moderator
Finally took for a short driveway drive just an initial check out after too many things to list getting it ready to drive.
Old 04-12-2021, 06:20 PM   #423
roll_the_dice
roll_the_dice's Avatar
Congratulations! Felt good didn't it?!
roll_the_dice is offline   Reply With Quote
Old 04-12-2021, 06:40 PM   #424
The Rocknrod
Moderator
Sure did. Wife said it sounds great (no mufflers yet).
Old 04-12-2021, 06:41 PM   #425
SCOTI
SCOTI's Avatar
Victory!
Even the small ones count
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
