Old 04-01-2021, 10:58 PM   #51
skymangs
skymangs's Avatar
Re: My 58 Brookwood
The problem was that even with 7.4 pushrods and the rockers adjusted all the way up. The valve train was just way to tight.
my Solution is to make 1/8" spacers to place under the pedestals.
skymangs is offline   Reply With Quote
Old 04-02-2021, 09:50 PM   #52
skymangs
skymangs's Avatar
Re: My 58 Brookwood
We put on the new water pump and the throttle body today
Old 04-03-2021, 10:08 PM   #53
skymangs
skymangs's Avatar
Re: My 58 Brookwood
we spent all day making these spacers to try to salvage the rockers, but it looks as if they won’t work!
Old 04-17-2021, 12:11 AM   #54
skymangs
skymangs's Avatar
Re: My 58 Brookwood
This is the LS3 all buttoned up
Can anyone tell me if the steam tubes have to be in front? I’ve converted them to 4AN.
This is a real 6.2, just over 500hp!
Old 04-17-2021, 06:46 AM   #55
gigamanx
Re: My 58 Brookwood
Very cool looking valve covers.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 04-17-2021, 09:18 AM   #56
skymangs
skymangs's Avatar
Re: My 58 Brookwood
thank you
Old 04-21-2021, 09:43 PM   #57
skymangs
skymangs's Avatar
Re: My 58 Brookwood
Finally received the correct belt today and installed it
Bolted the fuel rails down
Took out the radiator and prepped the 250 to pull
Did a 1/8 NPT tap for an elbow to route the steam tubes to
Old 04-22-2021, 08:03 AM   #58
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: My 58 Brookwood
This is a sweet build and that is an awesome engine! What did you finally figure out on your valve train issue?
Ryan
1969 Chevy milk truck
Old 04-22-2021, 09:05 AM   #59
skymangs
skymangs's Avatar
Re: My 58 Brookwood
Went back to stock rockers I will do rollers later
Old 04-22-2021, 09:26 PM   #60
skymangs
skymangs's Avatar
Re: My 58 Brookwood
Pulled the old 250/3 speed out. Making way for the LS3!
Empty engine bay. I will be converting from manual steering to a CCP Power gearbox. I will also be converting to dual reservoir power disk up front
Old 04-23-2021, 03:14 PM   #61
BlueJeep
BlueJeep's Avatar
Re: My 58 Brookwood
Agreed! Where did you get those? Most of the "pretty" valve covers seem to omit the oil fill cap, and that's not good for routine maintenance.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 04-23-2021, 03:48 PM   #62
72gmguy
72gmguy's Avatar
Re: My 58 Brookwood
Watching carefully! I have a 59 brookwood that burns as much oil as it leaks. Planning a 5.3 so I’m excited to see how your project goes. Love those old wagons! Keep the updates coming and thanks for sharing.
Jeremy
1969 Blazer 4x4 original cst
1971 Blazer partial 2wd convert
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper
1970 4x4 suburban w/ 6in lift and 35in tires
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
Old 04-23-2021, 10:54 PM   #63
skymangs
skymangs's Avatar
Re: My 58 Brookwood
72gmguy-love these old wagons!
Old 04-23-2021, 11:01 PM   #64
skymangs
skymangs's Avatar
Re: My 58 Brookwood
the pitman arm
After removing the old manual steering box
The manual box
The new power steering box, some trimming will have to be done on the sheetmetal
Old 04-26-2021, 11:37 PM   #65
skymangs
skymangs's Avatar
Re: My 58 Brookwood
Here’s engine bay before we started
Here it is minus the battery tray, motor Mount pedestals, and clutch linkage
Tomorrow we’ll work on getting the pedal assy and steering column out
Old 04-27-2021, 09:40 AM   #66
skymangs
skymangs's Avatar
Re: My 58 Brookwood
Radiator surround is back where it should be
sheetmetal trimmed for the power steering box
Old 04-27-2021, 09:58 PM   #67
skymangs
skymangs's Avatar
Re: My 58 Brookwood
so today JP took out the front seat
He also got the pedal assembly about 95% removed. Tomorrow he’ll finish that, remove the steering column, and the gas pedal.
Old 04-28-2021, 10:34 PM   #68
skymangs
skymangs's Avatar
Re: My 58 Brookwood
Today we got the steering column out
The master cylinder came off
And the Brake/clutch pedal assembly came out
Old 04-29-2021, 11:00 PM   #69
skymangs
skymangs's Avatar
Re: My 58 Brookwood
We cut the bump for the master and steering column. Removed all the Wiring in the engine bay, and removed any clutch/throttle linkage.
This is the steering column I bought for it.
Old 04-30-2021, 07:58 PM   #70
skymangs
skymangs's Avatar
Re: My 58 Brookwood
We welded in that firewall patch to smooth it out.
Then we modified an S10 brake pedal assembly to work
We wound up using part of the 58's pedal assembly to get it to be bolt-on.
Old 04-30-2021, 08:11 PM   #71
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: My 58 Brookwood
It's making progress!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Ol Blue K20 is online now   Reply With Quote
Old 04-30-2021, 08:31 PM   #72
skymangs
skymangs's Avatar
Re: My 58 Brookwood
Old 04-30-2021, 09:19 PM   #73
skymangs
skymangs's Avatar
Re: My 58 Brookwood
The Brake pedal and booster are in. We may need to go With a smaller diameter booster because it contacts the hood hinge.
Old 05-03-2021, 08:52 PM   #74
skymangs
skymangs's Avatar
Re: My 58 Brookwood
The patch is all cleaned up. The brakes and steering column have been mocked up and modified. Pics tomorrow
Old 05-04-2021, 10:08 PM   #75
skymangs
skymangs's Avatar
Re: My 58 Brookwood
We got the steering column in today
Cutting out the lower column bracket
Tacking the bracket
