Old 05-26-2021, 01:38 AM   #1
Asshat
Asshat's Avatar
14 bolt conversion to disc questions/options
Not sure if this is the best place, but I am looking for info on disc brake conversion on a GM 14 bolt, 8 lug, semi float rear end. I just can’t seem to get the drum brakes right, so I’m thinking of a conversion.
Can I buy just the bracket for the calipers and rotor, or do I need to buy a kit?
Are there any other options for a parking brake? All the kits want to add $200 for the parking brake calipers. Are there parking brake calipers from other cars that would work?
When’d did the rear ends (3/4 ton) start getting disc brakes? 1999?
Any help would be greatly appreciated. I’m sure there must be somebody out there that has done this.
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 05-26-2021, 08:43 AM   #2
v30crewcab
v30crewcab's Avatar
Re: 14 bolt conversion to disc questions/options
ruffstuff probably has just the brackets.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 05-26-2021, 08:44 AM   #3
v30crewcab
v30crewcab's Avatar
the vans got a disc semi-float 14 bolt in 03.
71 longbed 5.3 4l80
Old 05-26-2021, 09:52 AM   #4
84 400
Sb 400 club
84 400's Avatar
Here is my opinion….
Since you have a semi float and since you want a working ebrake. I would swap in an full float factory disc axle from a newer gen truck.
Personally it all comes down to cost. I think the ebrake calipers are junk. They were junk back when cadi used em on the eldo. I ran them on my conversion at first but now have a deive line ebrake and am running regular calipers.
Coat me
Ruff stuff brackets
Rotors
Calipers
New lines
Brake pads
Drive line ebrake kit from TSM
A newer axle from a 2500 or 3500 would have cost me
Perches and shock mounts from ruff stuff
Axle from bone yard or CL
Ebrake cable mods?
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 05-26-2021, 10:10 AM   #5
Asshat
Asshat's Avatar
Coat me
Ruff stuff brackets
Rotors
Calipers
New lines
Brake pads
Ebrake cable mods?
What is a driveline brake? Do they have kits available?
This one from Lugnutz is $379 without the ebrake calipers.
https://lugnut4x4.com/product/14-bolt-semi-float/
What is so bad about the ebrake calipers? Is the regular braking affected, or just the parking feature?
292, 4-speed
Old 05-26-2021, 01:23 PM   #6
Asshat
Asshat's Avatar
I believe 1977-1987 Chevy K20 front calipers, pads and rotors will work on the rear of the 14 bolt rear ends.
And the 76 Cadillac Eldorado.
Can anyone confirm?
292, 4-speed
Old 05-26-2021, 03:39 PM   #7
84 400
Sb 400 club
84 400's Avatar
Can anyone confirm?
Thats what i used on my 14 bolt FF. I know i used eldo calipers not positive they were 76 model year.
Is your project 4x4 or 2wd?
A drive line brake puts a disc or drum brake on your output yoke. When you set it it will keep your drive shaft from turning. Common on med duty trucks.
I used a driveline brake on the back of my NP205 transfercase.
High-angle drive line makes them too.
https://www.tsmmfg.net/np205-transfe...ing-brake.html
Really it all boils down to what you use your truck for. For me i offroad alot and wanted to ditch the heave 13.5 drums that would get mud packed. I also wanted to be rid of ebrake cables that caused me problems. If i could of used a lever lock or line lock as an e brake i would of gone that way. But for inspection i needed a mechanical e brake.
If i was towing i would of kept the 13.5 drum brakes.
With the eldo calipers i could not get a good adjustment for the caliper and park brake. I got tired of messing with them and sold them. With the regular front sibgle piston calipers and a few other mods i got a great pedal.
I also installed:
1978 c3 corvette master cylinder ( equal fluid capacity. More fluid moves with calipers then cyl)
Disc/disc proportioning valve. ( a must in my mind altho many don’t)
I was having problems with rear brakes locking up and the proportiobibg valve fixed that.
This swap has been done a zillion times on the FF. People have different takes on it. Keep in mind what components your changibg and how the system was designed to work.. i highway drive my truck on 39 inch tires and was glad i took the time to go through the system when a tour bus cut me off..
1985 C10 LWB Sold
Old 05-26-2021, 03:51 PM   #8
BlueJeep
BlueJeep's Avatar
And the 1500HD's got the SF 14 in 2000. Most yards sell these complete for less than the cost of a kit, then Rockauto for all the wear items.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 05-26-2021, 08:54 PM   #9
hatzie
Moderator
hatzie's Avatar
The GMT800 2500HD had 14bolt AAM full floating axle with rear disc brakes. They have full two shoe drum parking brake inside the disc brake hat.
The semi floating 9.5" 14bolts are lighter duty all the way around. They have the same ring shoe parking brake friction liner as my 2009 Impala.
I believe The AAM 10.5" rear disc setup was installed from 2003-06 but it might've been a few years earlier.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 05-26-2021, 09:35 PM   #10
Asshat
Asshat's Avatar
I spoke with Ron at Ruffstuff, he said they have a weld on bracket that I can use for the semi float. I can order the entire kit with the weld brackets, calipers, rotor, hardware, etc. $364 + tax and shipping. The bracket alone is $53.95.
I thought I could maybe procure all the other parts, however, in the end, I’ll probably spend that much or more getting all the parts.
He also confirmed the parts for the K20 and 76 Eldo.
292, 4-speed
Old 05-26-2021, 10:35 PM   #11
v30crewcab
v30crewcab's Avatar
I chose to use a 02 silverado 2500hd rear in my crewcab, so I had a good ebrake. works great, and other than moving perches was a drop-in. It takes the same gears as any FF 14bolt.
I don't understand swapping on a old rear anymore when you can pick these rearends up for less than the swap parts usually. but everyone does it their own way.
I have the old bracket setup on my offroad truck, but I don't have the ebrake functional on it.
71 longbed 5.3 4l80
Old 05-26-2021, 10:47 PM   #12
Asshat
Asshat's Avatar
I’m still considering swapping in another rear end, just wish I could find one that has gears taller than 4:10. Seems like all the 3/4 ton rear ends are geared low.
And, my truck is a 63, so some of the newer ones might be too wide.
292, 4-speed
Old 05-27-2021, 09:22 AM   #13
v30crewcab
v30crewcab's Avatar
there was some adapters to put the newer disc/ebrake setup on the older axles, but they were not cheap, around $200 just for the brackets. haven't seen any lately, don't know if they still make them.
71 longbed 5.3 4l80
Old 05-27-2021, 11:49 AM   #14
kipps
The 14bff is one of the easiest axles to regear. The pinion preload can be preset before installation, and the carrier does not require shims.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 05-27-2021, 01:47 PM   #15
57taskforce
All about them K’s
57taskforce's Avatar
I had my local cnc machine shop Build a set of backing plate mounts to run the 01+ disk setup on my ‘89 V30 14 bolt. They were rough cut on a water jet out of 1/2” plate then finished on the CNC. They are pure beef and set me back about $250. I already had the 01+ axle to rob brake parts from. It may have been easier to re perch the 01+ axle but I didn’t want to go that route as I have a matched set D60/14 bolt from the same square body 1 ton that I’m building for my 72 K20. The old style hubs that capture the drum behind the hub have to be machined slightly to center the rotor on the hub as well.
I’ve been peeking in on this thread a bit but wasn’t really sure my setup would help much with the semi floating axle.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is online now   Reply With Quote
Old 05-27-2021, 02:21 PM   #16
Asshat
Asshat's Avatar
The more I think about it, the more apparent it becomes that I will be better off swapping in a new rear end. Hoping I can use a later model with disc brakes and 3:73 gears; still concerned about width.
Would these work?
https://orangecounty.craigslist.org/...317962388.html
292, 4-speed
Old 05-27-2021, 08:07 PM   #17
hatzie
Moderator
hatzie's Avatar
Would these work?
There are at least two AAM 14bolts in the left rear of the picture.
They were available in 10.5" on the 6.0L & 11.5" on the dirtymax trucks.
If you can use a squarebody or 67-72 axle in your 63 you can use a T800 axle.
3.73 gears are easy to swap into a 14bolt. No shims at all. The pinion housing bolts into the nose of the axle so you assemble the pinion in the pinion housing and pick steel gaskets between the housing and the diff housing to set the pinion depth. The carrier bearings are set with threaded rings.
Old 05-27-2021, 08:43 PM   #18
kipps
I agree with Hatzie. You likely don't want the massive 11.5" 14-bolt that came behind the 8.1 and 6.6 diesel engines. The 10.5" is the one you want, and it was found in the 6.0 trucks.
Some of the early-2000's 10.5" 14-bolts came in 3.73 gears. You might get lucky and find one. Most were 4.10's though.
If you're running a conventional slip-yoke transmission or transfer case, grab the driveshaft to go with that rear axle. It will likely be too long, but it's cheap enough to shorten it. That way, you won't have to swap out the pinion yoke on the rear axle or run a conversion u-joint. From my experiments, all the slip yokes from the 1980's through the 2010's were identical. The early 2000's 2500hd trucks with a 10.5" 14-bolt have a 1410 u-joint.
Old 09-20-2021, 09:00 PM   #19
Asshat
Asshat's Avatar
For now, I am going to do the disc brake conversion on the 14-bolt.
So far, I have this:
Caliper mounting brackets
12.5 rotors from a 73-87 K20
Debating on which calipers to buy, parking brake style or regular ones.
And, not sure if the ones from the 76-77 are different than the ones from 80-85.
These two on ebay:
https://www.ebay.com/itm/32204212340...kAAOSwpDdVS8Kf
https://www.ebay.com/itm/12375051254...4AAOSw3TFcxw-O
Is there any other way to setup a parking brake, instead of using those Eldorado parking brake calipers?
292, 4-speed
Old 09-20-2021, 11:22 PM   #20
Ziegelsteinfaust
Can anyone confirm?
Depends on the kit. Depending on the year calipers Wilwood D52 calipers are a good swap too. There light weight with dual pistons.
If you do the swap. You need a adjustable proportioning valve. Otherwise the rear brakes get touchy, and lock up a bit to easily.
Ziegelsteinfaust is offline   Reply With Quote
Old 09-21-2021, 05:35 PM   #21
Asshat
Asshat's Avatar
Well, I’m not buying a kit. I purchased the rotors from Rock Auto and the bracket from Ruff-Stuff. I just need calipers and pads.
Didn’t really want to go with the parking brake calipers, but they seem like the only option if I want a parking brake. Pretty sure the later ElDorado calipers won’t work; probably need to find the 76-77 calipers.
No other options for parking brakes - bummer.
292, 4-speed
Old 09-22-2021, 12:55 PM   #22
hatzie
Moderator
hatzie's Avatar
The mid aughts GMT800 6.0L Silverado 2500HD axles are plentiful and very easy to install. 2001ish through 2005 at least. I think they went back to drums in 2006 or 2007 to save money.
They're the same 10.5" GM Corporate 14bolt full floater as your truck but manufactured by AAM using the GM design.
The discs are massive with two piston calipers bone stock.
The parking brakes on those axles are rock solid. The parking brake drum is the inside of the hat of the rotor. The parking brake shoes are essentially slightly scaled down, and I do mean slightly, good old fashioned drum brakes. Probably about the same diameter drum as a 4 banger S10 but the shoes are quite a lot wider.
Old 09-22-2021, 06:19 PM   #23
kipps
Originally Posted by hatzie View Post
The mid aughts GMT800 6.0L Silverado 2500HD axles are plentiful and very easy to install....They're the same 10.5" GM Corporate 14bolt full floater as your truck but manufactured by AAM using the GM design....
Hatzie's post is entirely accurate, as far as I know. I'm working with a 2005 2500hd axle myself, and will be installing it on my squarebody. The spring perches need to be moved. I'm using a driveshaft from the same donor truck, and will have it shortened a few inches to fit. The slip yoke is the same exact size as the original 1987 driveshaft, so it will fit the same np208/np241 transfer cases.
The main thing I wanted was 4.10 gears. It was going to be very expensive to regear my original 14bsf axle, so I started looking at different options. A parking brake on my manual transmission truck was a non-negotiable-- I had to have one. The '05 axle seemed to be the best way to get a solid parking brake, a strong axle, 4.10 factory gears, and the lower unsprung weight of disk brakes all wrapped in the same package. As a bonus, I don't have to keep track of a lot of different vehicles when ordering parts for my rear axle. Everything is factory correct for a 2005 2500hd with a 6.0 engine.
Old 09-22-2021, 08:02 PM   #24
Asshat
Asshat's Avatar
You guys are probably right, that would be a good option. Right now, I don't know if I am up to it.
Not sure if I could even find one.Maybe something I will do in the future; it's just right now, I have almost all of the parts. for just the brake conversion.
I'll think about it.
292, 4-speed
Old 09-23-2021, 04:24 PM   #25
hatzie
Moderator
hatzie's Avatar
Depends on how far you're willing to drive. There are some huge salvage yards just off Glenoaks Northwest of the Intersection with Sunland Blvd in Sun Valley. I used to drive past them on my way to work at the LACMTA transit garage in that area. It's been a decade and a half but they're still showing on the Satellite maps.
Sun Valley is around an hour and a half from San Clemente. There were a few big yards in the Riverside San Bernardino area but not like the ones in Sun Valley.
