06-16-2021, 09:59 PM | #1 |
Which AC compressor for r134 AC?
I bought all the factory stuff I need to convert my heater truck to AC. I was going to go with vintage air but wanted to be able to pull in fresh air because the south is very humid.
Anyway. I think I have figured out most of the stuff I need to do a r134 conversion when I install everything. The only thing I am still up in the air about is the compressor. I was looking at an AC delco A6 compressor from rock auto. Would that work without pulling too much HP away from my engine? Is the sanden a better option? Any more options? I want to be able to stay the coolest and use as little HP as possible. I’m pulling 16.5 mpg at 70 with my 350/sm465 307 rear right now and would I like to not take it down too much by adding AC. I also will usually drive the truck at 1300-1500 rpm in town. It just putts. I drive it like an old man (no offense to any old men). Would the A6 even work well at idle or low rpms? Thank you. |
06-16-2021, 10:42 PM | #2 | |
Re: Which AC compressor for r134 AC?
I drive like you do. I used a 4seasons aluminum A6 which works fine. Since I bought that thing I've heard some have had them fail. If I were to do it again I'd get a rebuilt GM/Delco/Harrison/Frigidaire. I used this condenser with the Vintage Air mount. I don't notice the HP loss and it gets plenty cold.
06-16-2021, 11:40 PM | #3 |
Who Changed This?
I'd use the stock type A-6 compressor if the conversion uses a POA valve adjusted for 134. If you are going to a switch to cycle the compressor, use the R-4 compressor, because the A-6s don't suffer cycling gladly and fail fairly quickly, based on what I've seen over the years, here. You probably already know, but the oil for a 134 system is different.
06-17-2021, 09:50 AM | #4 |
I run the A6. Next time it fails...I'm replacing it with a Sanden. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
06-17-2021, 09:53 AM | #5 | |
06-17-2021, 10:55 AM | #6 | |
Yep, the clutches don't have the surface area to by cycled on and off.
06-17-2021, 11:17 AM | #7 |
Moderator
I use an A10, aluminum replacement for the A6. Factory AC in my 68. No leaks, no belt squealing, been working great for about 4 years now. I used R12 as original. I will never use an A6 again.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
06-17-2021, 11:39 AM | #8 |
Who made your compressor and the part number? When I bought mine a few years ago I understood I was buying an A10 but the manufacturer's description says it's an A6. Mine is a 4 Seasons 58098.
06-17-2021, 11:50 AM | #9 |
Moderator
I don’t recall the manufacturer. I would imagine they all come from the same place, with each vendor putting their name on it. I bought an entire kit from autozone that included the compressor, drier/receiver, expansion valve, and a quart of mineral oil. They called it an A6 replacement but it’s an A10.
06-17-2021, 11:51 AM | #10 |
I have been the A6 aluminum replacement (four seasons) for years. Works fine. But, it came out with the engine to replaced with a LM7 LS engine...switching to R134a and using the Denso LS compressor. Going to try and sell the engine/700R4 as a package including the compressor.
06-17-2021, 12:32 PM | #11 | |
So maybe mine is actually an A10. I'm using ester oil in case I didn't like the R134 result and opted to switch back to R12. With the POA properly adjusted R134 works just as well as R12. I love POA systems!
06-17-2021, 12:45 PM | #12 |
Moderator
I never had any luck with r134 in a factory AC system conversion, even adjusting the poa and other factors. If it works for you, great. I’m happy with r12. I have stockpiled both and use 134 in all of my newer cars that call for it.
06-17-2021, 01:23 PM | #13 | |
Who Changed This?
06-17-2021, 10:57 PM | #14 | |
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
06-17-2021, 11:46 PM | #15 |
06-18-2021, 08:53 AM | #16 |
06-18-2021, 09:14 AM | #17 |
Who Changed This?
Thanks for the response. I'm looking at replacing or rebuilding the 400 in my truck. That would be a pain to adapt.
06-18-2021, 12:17 PM | #18 | |
Having a system that lets you open & close the fresh air intake is the best option but max cooling & dehumidification is accomplished when the air is recycled.
Made in America by Americans |
