06-15-2021, 03:03 AM | #26 |
Re: 72 C10 SWB LSx Build, truck with no name
Its a bit hard to see in your pics but how much space do you have? I had to switch to a smaller dual diaphragm brake booster because my hotside was in the way.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
06-17-2021, 11:56 AM | #27 | |
Gonna be a truck to take out for Fri/Sat night cruise, local stuff 5-10 miles. She will see the track, but will be on a trailer more times then not (when headed to the track)
'72 C10 5.3 SINGLE 76, freight train |
06-17-2021, 11:57 AM | #28 | |
its possible. I will have to look into that. I am going to post some pics of current situation.
06-17-2021, 11:59 AM | #29 |
Here she is minus brake booster.
06-17-2021, 12:00 PM | #30 |
I have zero idea on why pics post sideways
06-17-2021, 12:06 PM | #31 |
06-17-2021, 12:28 PM | #32 |
That is one serious header!!
If you hold your phone in landscape orientation when you take pictures, then they will show up correctly without any extra work. |
06-17-2021, 12:48 PM | #33 |
My steering column parts came in, so Im going to try and get the steering column back together and finish up the wiring this weekend. I'll have some more pics (Im sure they will come out sideways though)
06-17-2021, 05:31 PM | #34 | |
But in doing so, I found out I can put arrows on my picture on point to things! 🤣🤣🤣🤣 Here is my old turn signal lamp. 💀💀💀💀
06-17-2021, 05:32 PM | #35 |
Landscape = holding your phone sideways so the photo is wider than it is tall
06-18-2021, 01:34 PM | #36 |
Fuel cell.
06-18-2021, 03:56 PM | #37 | |
I gotta mock it up again (sorry I missed your post earlier). My son has 2 ball games tomorrow, and we play on Sunday. Depending on outcomes of those will determine if I can get some work done on it this weekend. We were supposed to be off (baseball), but last minute changed that. I may feel froggy this evening, but in this heat, after long week, doubtful I get in the garage tonight. I need to mock most everything back up (just had pulled everything apart so I could wire the truck)
09-30-2021, 02:35 PM | #38 |
Update:
Well, the heat finally did me in and had to take the summer off. After working 11 hour days, I was finding it tough going trying to get work done in 95* heat and 1,000,000% humidity. LOL So, weather has finally cooled down some and plan on getting back on her so I can have her back on the road for her 50th birthday (May 2022)
10-06-2021, 01:30 PM | #39 |
I just got the Terminator X Max for my a969 C10 with 5.3 rebuilt LS with 4l60E tranny. I have the PSI full LS engine kit with brain and honestly I am not a fan of that only because i cannot see, manipulate, or play with the data in the system. So with this one i can do everything and that is what i want. Yet to install it, but will be next weekend.
John 3:16 - Saved me... God Bless |
10-16-2021, 09:45 PM | #40 |
following this.
Question why you running a carb intake if you go Turbo. are planning on Blowthrough carb? Are you running a twin Turbo? If single why you use the forward manifold on the Driver Side? i had the terminator X on a previous build ( i just sold) ... its great fro what you doing. Just FOLLOW THE DIRECTIONS no shortcuts with Bat power and ground!! and you will be fine. i have a similar build right now 69 LWB to SWB but i cant decide between a cammed 5.3 LS i have sitting here or a nice BUICK 455 i have as well. i think i try the 4551st to see how she fits in there and oil pan clearance if that dont work the LS will become the choice https://67-72chevytrucks.com/vboard/...d.php?t=820880 IF LS i will ONLY do Terminator X its worth the $even my dumb ass was able to figure out tuning. Last edited by Sebambam; 10-17-2021 at 09:32 AM. |
