Old 06-20-2021, 01:19 PM   #76
SCOTI
SCOTI's Avatar
Re: 2wd swap
Originally Posted by KQQL IT View Post
Yes. Original plan was 18 inch wheels.
But they backordered til end of August so got the 20's and the rotor looks silly in there
I liked the look of OE sized front rotors in 18" wheels & the HD drums in 20's. I had that combo on my old 74 & thought the proportions looked fine (= WTF out of place).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 07-02-2021, 11:24 PM   #77
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
It's going together with the parts we have. If it stops weird I'll put the slotted stuff on my 73 and do something different on the k5
Was looking at afco calipers 1.25 rotor 4 piston deal.
KQQL IT is online now   Reply With Quote
Old 07-03-2021, 01:01 AM   #78
SCOTI
SCOTI's Avatar
Re: 2wd swap
I imagine it will stop just fine.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-03-2021, 02:05 AM   #79
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Looking at something like this
Old 07-03-2021, 11:44 AM   #80
SCOTI
SCOTI's Avatar
Re: 2wd swap
Just need to calc the dual smaller pistons vs. a D52 big piston & see what difference there is.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-04-2021, 06:14 PM   #81
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Happy 4th of July
Some more mock up stuffs
These 20's don't look to bad on my pos either
Old 07-05-2021, 02:12 AM   #82
SCOTI
SCOTI's Avatar
Re: 2wd swap
Not bad @ all.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-05-2021, 02:59 AM   #83
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Big moment this evening.
Didn't lay frame by about 1" but figured that after we didn't get the 18" wheels
Old 07-05-2021, 10:58 PM   #84
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Oof I likey
Old 07-13-2021, 03:20 AM   #85
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Bag plate questions.
Bolt bag to plates then bolt the plate to crossmember?
The fit seems kind of sloppy
Old 07-13-2021, 09:40 AM   #86
SCOTI
SCOTI's Avatar
Re: 2wd swap
I noted that on the 1st pair of plates acquired (from AirRide Technologies) so that's been a day or so ago. Since then, I've made my own & build them to better follow the contour/bend. I basically 'score' a line in the plate w/a cut-off disc where I want the bend. Bend or draw the plate to better follow the contour then run a bead down it & clean it up w/a flap disc on the angle grinder.
Some plates I've seen are shorter & don't make it to the area of the curve so it just depends on the plates. Either works.
I get the plates bolted in place on the outside perimeter of the x-member. Then get the lower arm w/bag bolted in place. This allows the bag to be optimally placed in the a-arm pocket/area. Then I use a template that's reference marked from the bag for the orientation of the top mounting hardware hole locations.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-14-2021, 09:39 PM   #87
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
I'm thinking we're gonna cut the bag plate to fit in the spring bucket hole and weld it in.
Poke 2 holes in the top of the spring bucket for a socket with 2 studs in the air bag.
Old 07-19-2021, 12:43 PM   #88
tinydb84
tinydb84's Avatar
Re: 2wd swap
Its hard to tell what it is but is that a piece of tube welded to the top of the c notch?
David
Instagram: myfabguy
Old 07-19-2021, 01:01 PM   #89
SCOTI
SCOTI's Avatar
Re: 2wd swap
My guess was it's reinforcement because of the c-notch depth into the rail.
I did something similar to my 99 OBS to retain as much of the uncut OE rail strength.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-19-2021, 02:26 PM   #90
tinydb84
tinydb84's Avatar
Re: 2wd swap
Thats what I was thinking.
Just make sure you are able to seal it up well so it doesnt build up a bunch of moisture and rust out.
David
Instagram: myfabguy
Old 07-19-2021, 03:03 PM   #91
SCOTI
SCOTI's Avatar
Re: 2wd swap
True.
My logic is if water can get in there, so can air. I stitch welded mine so I'm not worried in my Southern spot on the map but it is something to keep in mind.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-19-2021, 04:42 PM   #92
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Keep things from moving to much with the heat of welding the side plates in and will fit between the bed floor when we're done.
Baby step notch if you will
Old 07-20-2021, 12:37 AM   #93
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Its stitched in and if it sees any water I'd be surprised. That's what a daily beater is for.
Old 07-23-2021, 09:20 PM   #94
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Floor is going to get hacked now. Ha
Diff is hard in to it.
Axle tube is still 6 inches from the floor yet.
And a looks like a driveshaft tunnel maybe required
Old 07-23-2021, 09:59 PM   #95
SCOTI
SCOTI's Avatar
Re: 2wd swap
Sweet jeezus. Looking nice....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-24-2021, 12:36 AM   #96
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Thanks, Jay had a similar reaction.
Now to un bolt the floor and raise it. Or cut the floor and quarters.
I think the tubs alone are high enough but where the quarter bolts to the tub is in the way.
Old 07-24-2021, 03:20 PM   #97
SCOTI
SCOTI's Avatar
Re: 2wd swap
From the couple of burb threads I've watched on here, I believe you are correct (floor & quarters are the initial limitations).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-24-2021, 04:40 PM   #98
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Good thing it's not a last year 2wd jimmy or anything.
Time to break in our new plasma Cutter
Old 08-03-2021, 04:16 PM   #99
Snarl95
Snarl95's Avatar
Re: 2wd swap
looking good
1995 k3500 cclb srw 6.5 turbo diesel.
The lessons that hurt are the lessons that teach.
There is always a price to pay.
You are free to make any decision you want. You are not free from the consequences.
Snarl95 is offline   Reply With Quote
Old 08-04-2021, 10:20 AM   #100
blazer2007
Re: 2wd swap
On my 78 I raised the floor 3 inchs and there was one piece of the tunnel I had to cut out just behind the seat. Looks likes a cross brace I replaced the whole floor as was rotten in all 4 corners but made the floor removable just in case. Also with the raised floor I could run full exhaust, was too loud for me even with quiet mufflers. Hope it helps.
blazer2007 is offline   Reply With Quote
