07-22-2021, 08:02 AM | #526 |
Re: New 64 Stepper Project
Nice touch.
07-22-2021, 08:05 AM | #527 |
Moderator
07-22-2021, 08:13 AM | #528 |
love the striping....
07-22-2021, 11:21 AM | #529 |
Pinstriping
Vince Galatians 6:14 62 SWB stepside, 94 Wrangler, 99 Z71, 99 vette My Project http://67-72chevytrucks.com/vboard/s...d.php?t=719086 "If it's too loud, you're too old" |
07-22-2021, 11:34 AM | #530 |
Moderator
Thanks Joe
Thank you.
07-22-2021, 03:29 PM | #531 |
So, when are you going to wash the truck and give us some full beauty shots? These teasers are killing me
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
07-22-2021, 05:54 PM | #532 |
Moderator
Post 491 has them.
07-22-2021, 10:02 PM | #533 |
Good point, but I meant with all the pinstriping on it too. Pinstriping or no pinstriping, your truck has turned out great!
07-22-2021, 10:08 PM | #534 |
Moderator
Thank you.
07-29-2021, 09:00 PM | #535 |
Perfect. Absolutely perfect.
The pinstriping really finishes pulling it all together. A long trip indeed, I really enjoy seeing them completed. Lotta hours into this one. Outstanding, Chief!
-JDH Insomnia is a terrible thing to waste https://www.youtube.com/watch?v=jWYVs7widI0 (Misanthropic curmudgeon attempts starting old truck in house at 2AM) |
07-29-2021, 09:19 PM | #536 |
Moderator
Thank you
07-29-2021, 10:40 PM | #537 |
Not bad for a step side
07-30-2021, 07:07 AM | #538 |
Moderator
07-30-2021, 09:23 AM | #539 |
I'm just glad to be here!
Pinstriping is just enough on this truck. I like the one to separate the white and the red. Nice touch!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
07-30-2021, 09:35 AM | #540 |
Moderator
Thank you aggie91.
08-10-2021, 03:35 PM | #541 |
Moderator
Drove it into Waco to get a tank of gas, about 15 miles each way. Up and down hills back-roads, stop lights etc. from 25 to 65 MPH.
Came home and used a laser temp meter and found these temps on the engine. I dont know if thats good or bad? Top of radiator - 120 degrees Top of Thermostat Housing - 191 Under the Thermo housing - 171 Head between first 2 exhaust ports driver side - 192 Front of head - 191 Block - 191 Temp Gauge reading (Lectric Limited sender for year model gauges): So what do you think?
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 08-10-2021 at 03:53 PM. |
08-10-2021, 04:35 PM | #542 | |
08-10-2021, 05:05 PM | #543 |
Moderator
Thanks for your help, wasnt sure.
08-10-2021, 05:20 PM | #544 |
What temp range thermostat are you running?
08-10-2021, 05:25 PM | #545 |
Moderator
180
08-10-2021, 05:39 PM | #546 |
I have the same exact readings.....I feel better too...lol...
08-10-2021, 07:26 PM | #547 |
I would expect around/within 15° of the thermostat opening point.
08-10-2021, 07:55 PM | #548 |
Moderator
So 11 degrees is good huh?
08-10-2021, 11:31 PM | #549 |
My 63 gauge runs about that same degree on the sweep with my 180 thermostat and letric limited sender unless I'm running in 95+ weather when I've been going for a few hour At that point it will sit about in the middle. When I had a 195 thermostat in it, the gauge was almost pegged constantly
08-11-2021, 12:26 AM | #550 | |
Question, is that still an amp gauge, or has it been mod to a volt meter? With what I saw in your engine compartment, I would be using a 100 amp alternator at minimum, if that is an amp gauge, it won’t handle it well…. |
