11-02-2021, 08:05 PM | #76 | |
The Older Generation
Re: New Complete Oil Pressure Line
I can't think off the top of my head where the oil line port is on a 396. Same as small block or same as 454? Either way I have one I just need to be sure of the length. Thanks, LockDoc
11-02-2021, 08:24 PM | #77 |
The line port is in the same place as the BBC that you have a pic of in the #1 post in this thread.
It's not rust, it's called patina Trying to bring a 68 Panel Truck back from the dead. 396 Big Block, 4 on the floor, and a whole lot of rust. |
11-02-2021, 08:26 PM | #78 | |
OK, PM incoming. Thanks, LockDoc
11-05-2021, 11:38 PM | #79 |
Got it in the mail today. Thanks Leon! It took about 5 min. to install the new line. My old one was steel and made with two pieces joined by a union. Rusted through and was leaking. I like that the new line is copper. Easier to bend. I'll include a couple pics of where the line port is on my 68 396:
11-05-2021, 11:52 PM | #80 | |
Good deal! Thanks for the follow up. LockDoc
12-24-2021, 04:58 PM | #81 |
I want one of these for my SB 350.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 |
12-24-2021, 11:42 PM | #82 |
PM sent
Thanks, LockDoc
12-25-2021, 02:51 AM | #83 |
Leon, sign me up for two big block set ups. No rush on my end and Merry Christmas
1971 LSX "Bonnie" build thread http://67-72chevytrucks.com/vboard/s....php?p=8026381 paypal is curtbarton1971@yahoo.com |
12-25-2021, 12:08 PM | #84 | |
I will check here in a minute and see what I have left. Thanks, LockDoc
12-26-2021, 11:44 PM | #85 | |
Thanks. LockDoc
12-27-2021, 12:30 AM | #86 | |
Payments received. I will mail them out tomorrow. Thanks, LockDoc
01-18-2022, 04:02 PM | #87 |
low n' slo
hey leon, any SB lines left?
need one for my ls swap. i bought an adapter from amazon, so im assuming one of your lines should work?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
01-18-2022, 11:09 PM | #88 | |
Yes, it will work if you take the brass fitting out that is now installed in the adapter and use the one that comes with my line. That fitting is for an aftermarket oil line, not a stock type one. PM sent. That is all I have for now. Thanks, LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-15-2022 at 10:20 PM. |
07-11-2022, 07:32 AM | #89 |
Hello, I need one for a sb if you have any left.
07-11-2022, 10:37 AM | #90 |
I don't have any 1/8" OD copper tubing left and I haven't been able to find any at a reasonable price. Someone said to try a shop that works on big trucks. I guess they use that stuff for different things on trucks. Sorry, Leon
07-01-2023, 09:33 PM | #91 |
I really need one of these for my 72 chevy c20!! Small block 350
07-02-2023, 07:59 AM | #92 |
Mr. Cheyenne
Is this the right stuff, granted it is 50 feet! Perhaps if you supply the line to Leon (assuming the below is correct), he'll put it all together with fittings.
1/8" OD x 50' Copper Refrigeration Tubing Coil Edit Amazon - this is 2 meters $7.59 Quickun Copper Tube 1/12" ID × 1/8" OD (2-3mm) Seamless Round Pipe Tubing (6.56FT)
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 07-02-2023 at 08:05 AM. |
07-03-2023, 11:41 AM | #93 | ||
I have some tubing ordered and it should be here in a couple of days. LockDoc
07-07-2023, 11:57 PM | #94 |
Copper tubing arrived, so I have oil pressure lines available again..... Thanks, LockDoc
07-08-2023, 08:17 AM | #95 |
Leon,will take for sb.Post off mo.Paul...
07-08-2023, 09:21 AM | #96 |
I will send a PM shortly.
Thanks, LockDoc
07-08-2023, 09:59 AM | #97 |
Thanks Leon.
07-15-2023, 09:20 AM | #98 |
To top for ya Leon,got mine..Thanks. Paul....
07-15-2023, 10:18 AM | #99 |
Leon, I’ll take one for a 72 K20 with a 350. I can pay with PayPal. Thanks
Dave R. 1972 K20 1972 C20 Highlander 1957 Chevy 210 Delray 1967 C10 |
07-15-2023, 01:34 PM | #100 | |
Thanks, LockDoc
