Hello from TX - 1968 C10
Hello Everyone,
Thanks for the add. I've been slowly restoring my fathers truck over the last 2 years. It's a 1968 C10 Custom Long Bed (Short Bed Now). PS, PB, AC. I really appreciate this community and look forward to sharing the progress. Thanks to everyone who contributes here, it has been super helpful! Work Done So Far: Blast and Painted Frame CPP 3/4 drop kit Moog Front End Boyd Tank Brothers Shortbed Conversion Currently working on rust repair and LS engine build. Lots left to be done! Thanks Again! Last edited by josephuta214; 02-19-2022 at 12:34 AM. |
![]() ![]() ![]() Join Date: Jan 2018
Re: Hello from TX - 1968 C10
Welcome! We like to see pictures of your truck over here, so please throw some up when you get a chance
EDIT: I see now that you've added some pictures. Great work so far! The firewall section doesn't look like a fun piece to fix
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson Last edited by cwcarpenter98; 02-19-2022 at 01:39 AM. |
Thanks for the posts and pics. Love `em.
I'd consider a 5 lug conversion since you can move to disks in the front from many later years and even the rears land in the local picnpull fairly often. There are 3-4 picnpulls in DFW and lots of other similar outfits. Picnpulls just allow you to search inventory. 5-lug all around gives some wheel choices and disk brakes in the front is a good thing. |
Moderator
![]() ![]() Join Date: Aug 2011
Wow nice truck. Welcome to the forum.
#5 | |
Thanks! Yes the firewall/cowl area has been a challenge. I'm handing the rust repair/welding work over to my uncle whose a master welder. While I focus on the engine build. |
#7 | |
#8 | |
Moderator
#9 | |
Welcome to the site from your neighbor over in Dallas.
They make 6-lug disc brake conversion rotors that are available through the aftermarket if you want to utilize the current wheels front & rear for now. As far as I know they use the same spindle bearing set-up as the HD 5-lug rotors so it's just a different 6-lug rotor. Worth looking into.
#11 | |
![]() ![]() Join Date: Jan 2011
Nice truck man. Great job on the frame cut down. Welcome to the board.
Welcome! You've already made a lot of good progress and glad you could join up here. Thanks for all the pictures.
