#26 |
Re: Who makes a Fuel Injection tank for Blazers
I used Tanks Inc from Summit. Went into a stock Blazer tank.
#27 |
@Rickjz
That is what I did but am having clearance issues. The inlet and return are inline with the body mount and crossmember and the brass 90 degree fittings hit the crossmember by a lot 1/2-1" Just want to give you a heads up as I am dealing with this now!
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
#28 |
I used a Universal Tank from Tanks Inc. It had a in tank pump and return. Also a sending unit. Works great.
#29 |
Do you remember which one? Do you have any pics?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#30 | |
![]() Had the same problem, took my stock tank to a fab shop and they welded a shelf in it
#31 |
[quote=jaros44sr;8858372]
![]() Had the same problem, took my stock tank to a fab shop and they welded a shelf in it[/quote] What pump and ring are you using?I Actually prefer a stock type pump assembly To the tanks incorporated 1 of using.
#32 |
#33 |
vapor workz
#34 |
#35 |
Yea, it’s pretty close! There is one fitting that is practically touching, the rest are clear. I do have new body mounts.
#36 |
I also have new body mounts And tank is installed using the factory spacers. my fitting is halfway into that cross member.
#37 |
I guess I got lucky My Blazer is a 2wd. Not sure if it makes a difference. Your ID photo also looks like a 2wd.
#38 |
I'm using https://www.summitracing.com/parts/sum-250151
It was an easy instal and it's working well so far. |
#39 | |
I need to get the tires and brakes on and set ride height. Then I will decide if I can drop the tank an inch? Try and move the fittings around so they will miss the crossmember. Or weld in one of the recessed pump trays? I would have bought a Boyds but his fill is 1 1/2 and the fuel fill is 1 3/8 and he doesn't want to make one 1 3/8? Oh well its been going smoothly until this. About to get into wiring, starting where issues can come up?
#40 | |
#41 |
Mine is in a 69 GMC truck with tank in rear.
#42 |
Thanks for the inspiration, this is how mine turned out.
#43 |
![]() Join Date: Dec 1999
Not sure if this is of any interest in this thread, but I thought it might be. I am using a later model Blazer tank in my truck I used a weld in ring and pwm controller from VaporWorx. Factory return less ZL1 pump I am using should be good to 650+ whp from what I understand. OEM pump is the only way I wanted to go. Aftermarket is to old school, and I am old school. Owner Carl is local to me. Real smart and nice guy, responds quickly to questions. Give them a call if interested.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
