Old 04-29-2022, 10:49 PM   #26
hardwaa
hardwaa's Avatar
Rear wheels painted. New rear tires, tires de nippled!!
Clean and Simple.
hardwaa is offline   Reply With Quote
Old 04-30-2022, 09:13 PM   #27
hardwaa
hardwaa's Avatar
Progress. Rear cpp 5” drop springs installed along with rear wheels, tires and center caps.
Old 04-30-2022, 09:43 PM   #28
Getter-Done
Getter-Done's Avatar
Re: 1968 Chevrolet CST Survivior.
Very Nice
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 05-05-2022, 10:43 PM   #29
hardwaa
hardwaa's Avatar
Center cap hassle. I hate ugly hardware. Had to drill and tap my 15x7 fronts from 1/4 20 to 5/16 18. Very Happy with results, I really like this Look! Clean and Simple!
Old 05-05-2022, 10:47 PM   #30
hardwaa
hardwaa's Avatar
Front wheels painted, tires mounted. I always trim the “nipples” of the sidewalls on new tires.
Old 05-05-2022, 10:48 PM   #31
hardwaa
hardwaa's Avatar
Always fun to put new parts together.
Old 05-08-2022, 10:14 AM   #32
hardwaa
hardwaa's Avatar
Progress!! Static dropped. Can’t wait to run parts in this HOTROD longbed!!
Old 05-09-2022, 12:05 PM   #33
lolife99
67-72 parts collector,…
lolife99's Avatar
Another killer truck!
I like your style.
Keith
Convert to disc brakes.
Old 05-09-2022, 06:41 PM   #34
CG
BlahBlahBlah
Looks great, what size are your tires?
Old 05-19-2022, 11:55 PM   #35
hardwaa
hardwaa's Avatar
I like your style.
Thank you!
Old 05-19-2022, 11:57 PM   #36
hardwaa
hardwaa's Avatar
More fun.
New dome light install, steering wheel, also neg bat cable.
Old 05-20-2022, 12:00 AM   #37
hardwaa
hardwaa's Avatar
Refreshed the cooling system last weekend.
Old 05-20-2022, 12:01 AM   #38
hardwaa
hardwaa's Avatar
Engine block data. I need to look this up.
Old 05-20-2022, 12:04 AM   #39
hardwaa
hardwaa's Avatar
Put the tail gate trim on. This truck is starting to take shape!!
NO…NOT FORSALE !! Gotta keep this truck!!
Old 05-30-2022, 11:54 PM   #40
hardwaa
hardwaa's Avatar
New ignition. It always amazes me how good these old engines run with a pertronix ignitor and coil upgrade!
A couple buddies gathered for a Memorial Day Hotrod Breakfast.
I LOVE BURNOUTS:metal
NO BOZO's
Old 05-31-2022, 10:21 AM   #41
tutone
tutone's Avatar
Looks like a 1980 camaro 305/auto engine
Built July 15 in Tonowanda
Should do fine as that truck would have had a 307 possibly anyway. Tough engines but low hp. compared to an earlier engine.
:My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=807535
1972 K10 swb/1968 Camaro 350/4spd
1955 210 2 dr sedan/1998 RCSB Z71
tutone is offline   Reply With Quote
Old 06-01-2022, 09:46 AM   #42
dagnabbitt
dagnabbitt's Avatar
That steering wheel looks like it was born with the truck.
When you put the 5 inch rear drop springs in did you have to do anything in terms of panhard bar, etc?
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 06-01-2022, 02:14 PM   #43
68Gold/white
Might be, BUT the wide pad that those stampings are on, was generally not seen past 1976. The blocks with the wide pad were the heavier cast blocks. Narrow pad denotes thinner cast blocks, lighter weight AND lighter duty.
Would be interesting what the rest of the markings on block look like. (Behind driver side head)
68Gold/white is offline   Reply With Quote
Old 06-01-2022, 03:08 PM   #44
tutone
tutone's Avatar
Agreed but CMJ was used as a 1974 350 police eng and
a 305. I have a pretty extensive list of suffix codes and I am like you, I would like a block casting number to narrow this down.
If I am wrong, it certainly won't be the 1st time. Or th last for that matter.
I hope it turns out to be the 350.
:My build thread
Old 06-01-2022, 07:36 PM   #45
68Gold/white
I was mostly going by the pad width.
I sure hope it is NOT a 305 also!!!
Old 06-06-2022, 07:48 AM   #46
What size tires are you running on your wheels?
Old 11-07-2022, 06:03 AM   #47
hardwaa
hardwaa's Avatar
Updates.
May 2022.
Had the windshield replaced added a stock radio it’s powered but no speaker. I Also gave the truck a good bath.
NO BOZO's
Old 11-07-2022, 06:06 AM   #48
hardwaa
hardwaa's Avatar
I did ad the early classics pan had bar. Rear end is now centered lady to right in truck. Also I did trim the bracket for additional clearance.
NO BOZO's
Old 11-07-2022, 06:08 AM   #49
hardwaa
hardwaa's Avatar
Also back in may 2022 cleaned out the interior.
NO BOZO's
Old 11-07-2022, 06:18 AM   #50
hardwaa
hardwaa's Avatar
When I bought this truck I wanted to get it road worthy and enjoy it! Even if it’s a parts runner. The first event I took it to was 2nd Saturday at Vintage parts of Arizona June 2022. It was Great to be back participating at events. A buddy took the pick of us knuckleheads gathered around the 68!
NO BOZO's
