Old 08-01-2022, 12:55 AM   #151
rnrdthefox
Re: '50 3600 re-do. Shortening things up!
Where did you get your door panels from? Thx
rnrdthefox is offline   Reply With Quote
Old 08-01-2022, 09:28 AM   #152
mobileortho
mobileortho's Avatar
Roddoors I got the matching headliner too. I'll get around to installing them one of these days.
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 08-01-2022, 11:24 AM   #153
joedoh
joedoh's Avatar
door panels look great! glad to hear you are getting better too!
Old 08-02-2022, 10:12 AM   #154
mobileortho
Thanks Joehoh. As my grandfather would say, "I'm still kicking, just not high!"
Robert C.
1950 3600
Old 08-05-2022, 11:04 AM   #155
mobileortho
Sooo... I think I have all the parts needed to make the LS run. I've been seriously thing about firing up on the stand this weekend. More to come!
Robert C.
1950 3600
Old 08-08-2022, 09:52 PM   #156
mobileortho
Well, thing’s didn’t go exactly as planned. Didn’t get to start it up. I spent hours trying to find the intake bolts and fuel pressure gauge. I hate it when I put up stuff for easy access only to forget where that was!! 🤔🤔 I stumbled across them tonight in the very last place I thought to look! Also ran into an issue with the Powermaster mini starter. This one was clockable but I had to rotate it 180 degrees to clear the exhaust manifold placing the electrical connectors on the backside rendering them inaccessible. The gear wouldn’t disengage from the flywheel 100% of the time so I’m gonna send it back for something else.
It wasn’t a complete waste of time though. I did get the engine to prime so I’m glad about that. Will try again this weekend. Fingers crossed!
All
Robert C.
1950 3600
Old 08-18-2022, 11:33 AM   #157
mobileortho
Still working to get the engine started. Got the replacement started installed and it works fine. Ran into an issue with the fuel pump supplied with the kit. It only puts out about 20 psi. Contacted tech support & the said it should be closer to 70 and that I was going to need a regulator to get it to around 58. They're sending me a new pump & I'll go ahead and install a regulator.
Robert C.
1950 3600
Old 08-18-2022, 12:49 PM   #158
joedoh
joedoh's Avatar
sheesh seems like a whole host of problems. good think you are shaking it out now.
Old 08-18-2022, 01:44 PM   #159
mobileortho
I KNOW!!! I was warned by dsraven awhile back!
Originally Posted by dsraven View Post
now ya done it, started down the slippery slope. haha.
Someone else warned that it was going to nickel & dime me to death and that's proving to be true!! But, on the flip side, hopefully i can get all the bugs now. If not, I'll sell the Fitech and get a Sniper.
Robert C.
1950 3600
Old 08-27-2022, 06:31 PM   #160
mobileortho
Success!!! It sounds NASTY!!
First fire!
I’m gonna get in so much trouble!
Robert C.
1950 3600
Old 08-27-2022, 07:07 PM   #161
joedoh
joedoh's Avatar
haha we do some sketchy stuff to get things fired up for sure!
congrattys!
Old 09-03-2022, 08:03 PM   #162
mobileortho
My grandson explaining the finer points of the LS! Lol! He loves asking me about all things automotive!
Decided to swap the stick valve covers. Never really liked the tall oil filler on the stock one and I think the splash of orange is a nice touch. Also just got my trans in from Jegs. With with a 4L70 rated for 500hp so it should match the output of the engine.
Robert C.
1950 3600
Old 09-04-2022, 09:52 AM   #163
oldman3
oldman3's Avatar
Nice...Jim
oldman3 is offline   Reply With Quote
Old 09-06-2022, 01:21 AM   #164
joedoh
joedoh's Avatar
is that all the packing it got?
i like the valve covers, glad to hear your grandson understands the best stuff
Old 09-06-2022, 08:31 AM   #165
mobileortho
No, it was well packaged. I just removed it.
Robert C.
1950 3600
Old 09-18-2022, 11:07 PM   #166
mobileortho
Ma intent was to finish up the firewall before installing the engine, but my son had a weekend off & wanted to lend a hand, so we sat the engine in. Wasn’t sure if I was going to have to install a trans tunnel but I’ve got clearance. The only issue I see so far is that the ac idler hits one of the lines on the rack.
Robert C.
1950 3600
Old 09-25-2022, 09:16 PM   #167
joedoh
joedoh's Avatar
looking good!
Old 10-02-2022, 01:06 PM   #168
mobileortho
Ended up going with the Holley accessory drive.
Robert C.
1950 3600
Old 10-02-2022, 03:45 PM   #169
Advanced Design
Advanced Design's Avatar
I had an enjoyable afternoon going through your build and it is looking great! Thanks for sharing.
I used the same accessory drive on the 48 Burb and am pleased with how it fits.
Advanced Design is offline   Reply With Quote
Old 10-02-2022, 11:11 PM   #170
mobileortho
Thanks Doug! Much appreciated!
Robert C.
1950 3600
Old 10-06-2022, 12:20 PM   #171
joedoh
joedoh's Avatar
i really like the holley mid mount!
Old 10-06-2022, 01:02 PM   #172
dsraven
just had time to watch your fire up on the engine stand. fee-oof, that brought back memories of a buddy whose engine did a rotation and fell on the floor. I seen yours start to do that but you realised what was gonna happen and resisted the urge to blip the throttle a little more. always good when things fire right up. awesome.
nice looking project.
Old 10-06-2022, 01:50 PM   #173
mobileortho
Thanks Joedoh! I really like it too! I found out too late that I could have saved some $$$ by just buying the Holley water pump and then buying the accessories from other sources! There's a couple of youtube vids that list the part numbers.
Robert C.
1950 3600
Old 10-06-2022, 01:53 PM   #174
mobileortho
Luckily I had stuck a screw driver in the hole for the lock pin that was way to small. It wasn't going anywhere but it sure did get my attention!!! Lol!
Robert C.
1950 3600
Old 10-07-2022, 01:41 AM   #175
joedoh
joedoh's Avatar
whoa thats outstanding about the cheaper mid mount, I watched the youtube, $900 bucks savings is enough for a new low profile intake!
