03-07-2023, 09:08 PM | #326 |
Re: 53 3100 - complete rebuild and upgrade . . . .
Thanks all! Should be plenty of progress in the near future. More later -
Dan
Just playing in my shop, trying to maintain my sanity and maybe finish a project here and there. . . . My 53 3100 "rebuild" - Soon to be Scott's suspension, LS, low and mean. https://www.67-72chevytrucks.com/vbo...d.php?t=791886 My 65 Ford project . . https://www.67-72chevytrucks.com/vbo...d.php?t=792428 |
03-08-2023, 08:15 AM | #327 |
much sexy
03-08-2023, 08:51 AM | #328 |
One last update - should have the rear together in the next weeks, hanging the tank as well. Using a 15 gallon universal tank from "Tanksinc" with internal pump. Customer service was outstanding with them. Rear will be a 31 spline 9in, Detroit Truetrac with 3.89 gears. With 28.4" tires and 0.68 OD should turn around 2k at 65 - not too bad.
More later - Dan
03-08-2023, 11:38 AM | #329 |
wow, thats a lot of work that went into the structure back there. should be stiff for sure.
keep postting up those pics, curious to see what thats gonna look like with a diff in there and all connected up. |
03-10-2023, 09:47 AM | #330 |
Playing around with hanging the gas tank while waiting for the rest of the rear end parts to show up. One bite at a time . . .
Dan
03-10-2023, 11:06 AM | #331 |
be sure to insulate the straps and anything that touches the tank. I'm sure you have that already in mind.
03-10-2023, 04:51 PM | #332 | |
Dan
03-10-2023, 10:12 PM | #333 |
yep, ground the tank to the frame and the filler spout, at the spout end, to the frame as well. static kills.
ever been at the airport and seen a fuel truck? they ground everything. the vehicles sit on rubber, so insulated from the actual ground, so making a complete circuit from the filler to the tank is essential. this is a step forgotten by most. good thinkiing on your part. |
03-12-2023, 11:24 AM | #334 |
Continuing along on a rainy day so starting assembly on the 9in. True-trac, 3.89 gear, etc. Whipped up some brackets to hold everything still, just enjoying the day. One of my favorite parts. More later -
Dan
Just playing in my shop, trying to maintain my sanity and maybe finish a project here and there. . . . My 53 3100 "rebuild" - Soon to be Scott's suspension, LS, low and mean. https://www.67-72chevytrucks.com/vbo...d.php?t=791886 My 65 Ford project . . https://www.67-72chevytrucks.com/vbo...d.php?t=792428 Last edited by big_dan; 03-12-2023 at 02:28 PM. |
03-12-2023, 03:33 PM | #335 |
It's nice spending time on something you enjoy. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
03-12-2023, 06:04 PM | #336 |
great work! doin it right. lookin good and with a Bass boat in the back, dont get much better than that!
03-12-2023, 07:21 PM | #337 |
I wish I knew how to set up rear gears.
03-12-2023, 08:44 PM | #338 |
thats my favorite diff to set up, so much adjustment is built in.
03-13-2023, 06:27 AM | #339 | ||
Absolutely. That's why we have this hobby for sure!
All it takes is practice- dive in! There's tons of literature available and it's rewarding, plus saves $$! Quote:
Thanks for the input, fellas. More later- Dan
03-14-2023, 02:04 PM | #340 |
I've been studying EFI for months now. Finally made a decision and had a day off, so made a quick road trip with my Dad to Summit in McDonough, GA and picked it up. Going with Edelbrock ProFlow-4, 550hp kit. Looks nice, will be a little different than the"log" style, and I've always had great service with Edelbrock if needed. Still moving along - thanks for looking-
Dan
03-15-2023, 10:24 AM | #341 |
I have a PF4 and it works really well! I'm sure you will like it.
03-15-2023, 10:34 AM | #342 |
curious, what do you need in the system leading up to that. fuel pump etc?
03-15-2023, 08:20 PM | #343 | ||
Thanks for looking - Dan
03-16-2023, 08:08 PM | #344 |
A few evenings and the 9in is ready to go. Started with a 0.015" pinion shim, set backlash at 0.008", marked it up and it fell right in where I wanted. I've set up a ton of these and was tickled to not have to chase it for days. A little loctite, install the keepers and it's ready for paint. More later - thanks for looking -
Dan
03-17-2023, 09:53 AM | #345 |
nice work.
I like your assembly fixture, looks like ti was cheap and can be re-purposed. haha. |
03-17-2023, 12:53 PM | #346 | |
Dan
03-18-2023, 10:55 PM | #347 |
Still making a little progress. Painted the axle housing and third member, finished mocking up the gas tank and tacked in the upper straps. More later-
Dan
03-19-2023, 09:47 AM | #348 |
And a few more from the weekend. Excited to say this is the first part that's finished! On to finishing up the chassis -
More later- Dan
03-19-2023, 10:23 AM | #349 |
looks great. did you put oil in it already? if not better tie a string around your finger, wouldn't wanna forget that little step.
03-19-2023, 02:01 PM | #350 | |
One last pic / test fit before going on the road for a week - gonna have to relocate that alternator! There's no interference, but it looks gaudy hanging out where it is. Thanks for looking - Dan
