08-28-2018, 10:46 AM | #1 |
Door locks
When I bought my 72 the previous owner had lost the key to the door locks. After sinking a bunch of money into the truck, I would really like to be able to lock it. Is there a way for someone to key the existing locks, or do I need to get new locks? What is the best course of action?
08-28-2018, 11:45 AM | #2 | |
The Older Generation
Re: Door locks
I can make keys for your existing door locks or sell you a complete new OEM GM set. http://67-72chevytrucks.com/vboard/s...d.php?t=734140 If you don't need or want OEM you can buy reproduction. Last I checked there were two suppliers to the vendors, one being made overseas and one being made in Mexico. The ones being made in Mexico are better quality than the ones being made overseas. The set I would buy is "Classic Auto Locks CL 104" with the number 53-480 on the package. https://www.classicparts.com/1967-72.../#.UmaFKsgkzTo There is no guarantee that they have not changed suppliers though. If anyone buys a set from ClassicParts let us know if they still say "Made In Mexico" on the package. LockDoc
08-28-2018, 01:43 PM | #3 | |
Re: Door locks
I have tried the ignition key and it definitely will not turn the door locks. I have another issue, too. I can push the knob down to lock the doors, but not when they are latched. Perhaps there is some sort of strike that isn't catching on the jamb side, but I can see the mechanism moving at the strike area when I press the knob up and down. This is the first time I have really tried to dig-in on the issue, and I just assumed that there was a separate key for the doors, kind of like the old oval GM keys you would have on a car for the trunk. |
08-28-2018, 02:07 PM | #4 | |
Re: Door locks
Roll the window down and push in on the door from the outside while you push the button down and see if it works. Have you lubed the door latch and lock mechanism? Roll the window down and spray some good penetrating oil (not WD-40) on the back of the lock and on the latch. You can see the latch and back of the lock inside the door with the window down if you use a good light. The two key system for the trucks started in 1973. Leon
08-28-2018, 02:24 PM | #5 | |
Re: Door locks
I was able to tinker with the door jamb latch enough to get the doors to lock, though. I have been needing to do that for a while anyway to get my doors to close flush with the body. |
08-28-2018, 02:36 PM | #6 | |
Re: Door locks
You are evidently right on the locks being different My guess would be that someone changed the ignition lock cylinder at some point. Good deal on the latches. LockDoc
03-17-2023, 10:05 PM | #7 | |
Re: Door locks
Reviving a 5-year old thread. My new to me '71 only has one ignition key, and it will not work on either door lock. In fact, it won't even push half way into the lock cylinder on the door, let alone turn them. I need to make a duplicate ignition key, but I also want it open the door locks. Or, I am also fine have a separate key for the door locks, but can this even be done without replacing the cylinders? And if I HAVE to replace the door lock cylinders, should I just go all the way and get a matching replacement ignition cylinder with the set? Any ideas or suggestions are appreciated.
Trio 1971 C20 350/700R4 |
03-17-2023, 10:15 PM | #8 |
Re: Door locks
You need to message LockDoc. He can answer all your questions.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
03-17-2023, 10:56 PM | #9 | |
Re: Door locks
That means that the ignition lock has been changed at some point in time. If the ignition key won't fit in the door locks they can't be re- keyed to match the ignition key. Does your ignition key have a letter stamped into the side of it, or a number on it? Take a look at post #18 in this thread. http://67-72chevytrucks.com/vboard/s...d.php?t=842698 That post is about hatch locks but the principal is the same. If you can figure out what key series your ignition uses I might have a pair of used door locks that I can key like your ignition key. Let me know what you find. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-17-2023 at 11:30 PM. |
03-18-2023, 10:55 AM | #10 | |
Re: Door locks
Stamped "B44" over top of an "E". I'll shoot you a PM with a pic. Yes, would love to have a set of door locks keyed the same. Also, it is easy to find a blank to have another ignition key cut? .
03-18-2023, 11:19 AM | #11 | |
Re: Door locks
I do have two "E" groove door lock cylinders I can key to your ignition key. I also have all kinds of key blanks. PM returned. LockDoc
03-18-2023, 02:32 PM | #12 |
Re: Door locks
03-18-2023, 02:46 PM | #13 |
Re: Door locks
Those are automobile door locks with black faces instead of stainless face truck locks. They will still fit our trucks, but can't be matched to the truck ignition because they use the oval head keys instead of the rectangular head keys.
LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-18-2023 at 07:24 PM. |
03-18-2023, 07:05 PM | #14 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Door locks
I just replace all three, get reacquainted with door locks and ignition switches. Less than $30... https://www.classicparts.com/1967-72.../#.UmaFKsgkzTo PS. I have a Counterpart 53-480 in my hand that say's "Made in Taiwan" that does a good job of replacing the OEM or NOS stuff. I was ordering plugs today, R44T's were $2 bucks a plug, "Made in Taiwon" but you can only buy 12, once, my card wouldn't go for the second attempt. I'll try again tomorrow, two bucks a plug is cheap! I REALLY like the one key concept, it's a life saver for some of us!
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 03-18-2023 at 07:26 PM. |
03-18-2023, 07:49 PM | #15 | |
Re: Door locks
Michael, I respectfully disagree on the overseas locks being as good as the OEM or NOS, or being a good replacement for them. I have disassembled some of them and the tumblers and springs used in them are inferior to anything made in the US or Mexico. Classic Parts used to sell the "Classic Auto Locks" CL-104 sets which are just as good as OEM and they are made in Mexico. I'm sure they quit selling the CL-104 because they can get the Counterpart sets a lot cheaper. Yes, the Classic Auto Lock sets are $10 more but they are well worth it. Speedway sells the CL-104 sets and I can tell you for a fact that all of the internal parts in those locks are 100% interchangeable with the original and OEM GM locks for our trucks..... https://www.speedwaymotors.com/Class...GM,116526.html Buy these and forget about the overseas lock sets. You won't regret it. You may find them cheaper from other suppliers, shop around. Just my 46 years of Locksmith experience 2¢ worth. LockDoc '
03-18-2023, 08:22 PM | #16 |
Who Changed This?
Re: Door locks
I replaced the ignition switch awhile back, but even before that the switch and the door keys didn't match. I actually prefer that. The reason (if I heard it right) for different keys was to lower theft rates. Thieves would use a slide hammer to remove a door lock, copy it and start the car with the correct key. Once that didn't work, they just busted the column and got around the lock, since the switch was actually at the bottom of the column. Thieves.
03-18-2023, 09:18 PM | #17 | |
Re: Door locks
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
