All about them Ks
![]() Join Date: Jun 2014
71-72 Throttle cable
Anyone bought a 71-72 4x4 throttle cable worth a crap lately? I replaced my original in early 2021 with a part from Classic Parts of America. At the time Wes and GMC Paul’s didn’t have them that I recall (could be wrong). Yesterday with less than 1,000 miles on the cable it decided to begin hanging the throttle part to wide open, and eventually break about 25 miles from home. The 10 miles or so it was acting up before it broke were a real blast, filled with full throttle runs, cutting the ignition at speed, 4-5 stops to modify the return spring so it would pull it all the way closed, ultimately leading to the cable snapping. Good thing it’s got a 4 speed so I still had full hydroboost brakes while it was running with the Ignition off.
So… Anyone bought a decent part lately that will last more than 1,000 miles?
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's 87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue 10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Re: 71-72 Throttle cable
I've seen this on vehicle with poor starter grounds. While cranking the engine starter current is flowing through the throttle cable causing to degrade.
All about them Ks
Good points, it’s got 2-3 years since new 1-0 welding cable from the starter to the battery and the same for battery ground, the 2 engine to frame grounds I added are new within the last 2-3 years as well, and made from 8 or 10 gauge if I remember correctly.
The cable looks like it started to fray and began wearing in the sheath. I think I’m going to buy another cable and try to lube inside the sheath with silicone lube or something like that and see how it goes.
Graphite would be better but not sure how you would get it inside the cable ?
71 C-20 07 Magnum RT AWD |
The Older Generation
Try PB Blaster Dry Lube. It sprays liquid and will run down inside the cable. It then drys into a really slick white microfine powder..... Works good on locks too. LockDoc
All about them Ks
Excellent advice Leon, thanks!
![]() Join Date: Jan 2017
Just a suggestion, Bob's speedometer can make you a new one. They have a website. Might be better quality than a reproduction.
All about them Ks
Thats exactly the kind of info I was looking for. I will check it out thanks!
