Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 10-29-2023, 05:17 PM   #301
KFF 1
KFF 1's Avatar
Re: New project : 72 Suburban
This morning the torque converter swap is now complete. Now its just a waiting game for the heads and intake. If the steering gear kit arrives this week maybe I will tackle that next weekend and get it out of the way. LockDoc was right, I worked myself out of a job LOL!
KFF 1 is offline   Reply With Quote
Old 11-05-2023, 03:56 PM   #302
KFF 1
KFF 1's Avatar
Well, I went out to the garage Monday after work and to my surprise the bolt circle on the new converter was wrong. So, Thursday after work I pulled the short block back out, boxed up the converter and went to Summit after work Friday to exchange converters. Yesterday while the short block was out I installed the lifter and trays, timing chain and cover, plus the oil pan then put it back in and bolted it back up to the transmission. This morning I bolted up the converter and installed the AC compressor back in the bracket then cleaned up the bench to make room for the heads and intake which should be finished this week. Not sure if I will have it running next weekend but it will be close, if not no big deal.
Old 11-05-2023, 08:56 PM   #303
LockDoc
The Older Generation
LockDoc's Avatar
You just need to burn a little more "Midnight oil" to make up for the lost time...
LockDoc
Leon
Old 11-07-2023, 06:35 PM   #304
KFF 1
KFF 1's Avatar
LockDoc
Yes sir ! If the heads and intake are finished and picked up Friday there will be plenty of "Midnight Oil" burning .... Probably at least a 55 gallon drum LOL !!!
Old 11-07-2023, 11:28 PM   #305
LockDoc
LockDoc's Avatar
LockDoc
Leon
Old 11-12-2023, 07:25 PM   #306
KFF 1
KFF 1's Avatar
Little to no progress was made over the weekend. Picked up the heads and intake last night only to find out that the intake was not correctly ported and had to be returned today. Intake should be done by Friday and ready for pickup so I will try again next weekend to get the top end of the motor back together and ready for fire up.
Old 11-18-2023, 09:24 PM   #307
KFF 1
KFF 1's Avatar
Finally made some decent progress today. Heads are installed, valves adjusted, valve covers are on, starter is on and wired up, power steering pump is on, and crank pulley is installed. Tomorrow I will try to assemble the intake, get it installed along with the water pump and radiator. If time permits I might start installing the ignition coils, but all and all Im happy with todays progress.
Old 11-18-2023, 11:38 PM   #308
LockDoc
LockDoc's Avatar
Lookin' good! All of that bright paint is hard on the eyes....
LockDoc
Leon
Old 11-19-2023, 02:26 PM   #309
KFF 1
KFF 1's Avatar
LockDoc
Thank you LocDoc, I should have turned off the florescent trouble light.
Old 11-19-2023, 02:32 PM   #310
KFF 1
KFF 1's Avatar
Intake is on, water pump, alternator, radiator, and coolant is in the motor. Friday I will finish up the wiring and ignition coils then try to bring it to life.
Old 11-21-2023, 12:49 AM   #311
3757chevy
3757chevy's Avatar
Thumbs up Re: New project : 72 Suburban
Looking Good.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 11-23-2023, 12:39 AM   #312
KFF 1
KFF 1's Avatar
Made a little more progress this evening. Grounds all bolted up, oil pump is primed, fuel lines are hooked up, plugs are in, plug wires are on, and coils are mounted and wired. Hope you all have a Happy Thanksgiving !!!!
Old 11-23-2023, 02:21 PM   #313
LockDoc
LockDoc's Avatar
Sounds like you are about ready to fire her up.
You and your family have a great Thanksgiving too.
LockDoc
Leon
Old 11-30-2023, 10:46 PM   #314
KFF 1
KFF 1's Avatar
Fired up the Suburban last Friday, then came 3 or 4 days of delays. Steering gearbox had to be replaced. Installed it yesterday and bled system so all is good there. Today my Dad and I went for a short ride out the road and back, ran really well but the stall converter is going to take some getting use too LOL. Made some tweaks to the shift points in the tune so if the weather isnt to bad tomorrow I will make another trip out the road and back and see how the Burb reacts to it.
Old 12-01-2023, 01:19 AM   #315
LockDoc
LockDoc's Avatar
Good luck on the drive tomorrow. It just takes a little time to get everything where you need it to be....
LockDoc
Leon
Old 12-01-2023, 07:31 PM   #316
KFF 1
KFF 1's Avatar
LockDoc
Yes it does LockDoc. Weather was pretty bad today it rained most of the day and at times it was coming down pretty good so no ride out the road. I did make some other adjustments that were a little off. Got the throttle cable adjusted and dialed in. The brake light switch was way off after adding the hydroboost ( Never gave it a thought to check that ) Clocked the steering wheel so its straight now. And added some trans fluid,and coolant. The weatherman said " tomorrow will be a much better day " we will see lol
Old 12-02-2023, 03:09 PM   #317
KFF 1
KFF 1's Avatar
Here is a video of the Suburban running in the driveway. New motor combo
https://youtu.be/guTAqelXVrw
Old 12-02-2023, 04:22 PM   #318
LockDoc
LockDoc's Avatar
Well, it certainly sounds good! ...
LockDoc
Leon
Old 12-22-2023, 10:39 PM   #319
KFF 1
KFF 1's Avatar
You wont see this very often. I have been using the garage bay while refacing the cabinets in the kitchen and wouldnt you know it, as soon as I decided to leave the Suburban out over night it snowed
Old 12-23-2023, 08:45 PM   #320
LockDoc
LockDoc's Avatar
That figures!!!
We are supposed to get a lot of rain in the next few days and I bet it is headed your way next. It will be snow on the back side so we will see what that brings....
LockDoc
Leon
Old 12-25-2023, 08:35 AM   #321
KFF 1
KFF 1's Avatar
Merry christmas !!!!!!!!!!!
Old 12-25-2023, 01:10 PM   #322
LockDoc
LockDoc's Avatar
Merry Christmas to you and yours. And everyone else that celebrates the day on here....
LockDoc
Leon
Old 12-30-2023, 11:49 AM   #323
KFF 1
KFF 1's Avatar
Came home from town last night on the roll back. There is a first time for everything I guess LOL. I took my wife to Dollar General and as I was turning into the parking lot the steering started acting funny and then there was no brake assist from the hydro boost. Got out and looked, PS fluid down the entire driver side. Went inside and got some fluid, filled the reservoir, started it up and a stream of fluid was pouring out of the input shaft at the rag joint. So this morning I took the box off and the replacement one will be here on Wednesday. Looking at the box I cant see where it pushed the seal out or maybe it is the oring on the gland itself. I just installed the box less than a month ago.
Old 12-30-2023, 12:57 PM   #324
kev2809
low n' slo
kev2809's Avatar
dang that's tough, good thing you were turning into a parking lot
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 12-30-2023, 09:21 PM   #325
LockDoc
LockDoc's Avatar
He's had his share of bad luck lately that's for sure. I guess that is the good part.
LockDoc
Leon
