11-13-2023, 09:52 AM | #1 |
Wiper Transmission gasket
Hi again everyone, I have another question and will probably have more as I put this 57 pickup back together. I bought this as a started project and it was a bare shell. I am putting the wiper motor and transmissions in soon and there is a gasket and am not sure how it goes in. Should I put it on the transmission and have it between the transmission and cowl on the inside or should it be between the bezel and cowl on the outside? I am trying to avoid any leaks so need the correct placement. Thank You Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
11-13-2023, 10:59 AM | #2 |
Re: Wiper Transmission gasket
you could check the assembly manual for the way it was put together at the factory. if you don'y have a copy you can do a free download from the trifive site. google
55-59 chevrolet truck factory assembly manual and choose the trifive site a pic of what it is you are looking at would really help. is it a gasket for the wiper arm shafts where they go through the firewall below the window? |
11-13-2023, 01:05 PM | #3 | |
11-13-2023, 02:04 PM | #4 |
not sure if this is what you are referring to. truk has a rubber gasket under the wiper bezel. it seals the water from running down the shaft into the wiper motor, but more importantly (imo) keeps the paint from chipping around the bezel
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
11-13-2023, 05:21 PM | #5 |
That's what I was gonna say too, rubber against paint. If you're worried about water through the hole maybe make another gasket for the inside or seal it with some non hardening or super flexible gasket sealer on the inside.
11-13-2023, 10:25 PM | #6 | |
I am going to do something to seal that area where the transmission base goes through the body. Steve
