Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 01-30-2024, 04:19 PM   #1
HO455
HO455's Avatar
Stink Ten Two. The second Blazer.
I picked up this 1988 Blazer a couple weeks ago it's pretty solid but has some issues to be corrected. Obviously it's an ex-Forest Service rig. Its an odd combination of options 2.8 V6 with a manual transmission, manual steering, manual windows, no AC but a rear window defroster. I'm not sure if the side mirrors are factory or aftermarket as I don't remember ever seeing any like them before.
The first thing to fix is the steering as it has a ton of slop in it. I ordered a Red Head box for it. Apparently most of the manual steering boxes on S10's are S10 only and such the core charge is more than the box was.
After removing the guard on the coupling I found the cause of most of the play.
RIP Bob Parks.
Old 01-31-2024, 12:46 AM   #2
dagnabbitt
dagnabbitt's Avatar
Re: Stink Ten Two. The second Blazer.
Wow, I really like that, great truck. Post more pics if you can!
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 01-31-2024, 08:46 AM   #3
I love ex-municipal trucks. Even cooler with custom touches. I believe those mirrors are aftermarket. I'm wanting to buy something more trim for the Sonoma. It seems manual boxes wear sooner than power. I think it's that the P/S systems absorb more "road steer" between the box and steering wheel. But I do see the contributing culprit
Old 01-31-2024, 11:20 AM   #4
4793
4793's Avatar
always good to see another Forest Service green vehicle out there, and your Blazer is nice and straight
I think the Forest Service tried to keep their trucks fairly bare bones with options suitable to where the truck was working. I imagine in the northwest rear defrost is more necessary than AC. My Forest Service truck came out of the southwest and is very basic but it does have AC- and, weirdly enough, the cassette deck radio
4793 is offline   Reply With Quote
Old 01-31-2024, 01:41 PM   #5
HO455
HO455's Avatar
Apparently somehow I didn't save all of the post. Here's the other photos. And coupe more. The seats are 95 Camaro and the door panels have had the fabric replaced with GM pleather.
The rag joint was not made of the normal rubber fiber I'm used to seeing (Like the new one) but was made of a urethane looking material. It looked as one part had been broken for awhile as the edges looked kind of polished Needless to say it drives much better now.
I did contemplate converting to power steering but that would turn a 4 hour job to a 4 week job and I'd miss out on all the aerobic exercise.
RIP Bob Parks.
Old 02-03-2024, 09:49 PM   #6
yeah, stick with the Armstrong steering
Old 02-08-2024, 06:52 PM   #7
HO455
HO455's Avatar
The lil Blazer needed a change of tread so out with the Michelin Maypops and in with some Firestone Indy 500s. While up on the lift I got some photos to post.
Front suspension has 2002 spindles and lower control arms with UMI upper control arms.
The rear axle is also 2002 vintage with 3.42 gears bolted to a posi carrier.
RIP Bob Parks.
Old 02-24-2024, 01:07 AM   #8
HO455
HO455's Avatar
I put the new Blazer to work today. Drove out to Orchards and picked up the lower end of new the engine for my 72 Firebird. I was thinking of starting a thread about it in the Alternative Tinkering section once I start doing more than gathering parts.
RIP Bob Parks.
Old 03-06-2024, 11:45 PM   #9
HO455
HO455's Avatar
Got all the wagons together for a photo.
RIP Bob Parks.
Old 05-17-2024, 08:27 AM   #10
HO455
HO455's Avatar
I got to wondering how a Forest Service vehicle was ordered so I took a photo of the RPO codes in the glove box, found a decoder sheet on the interweb and started decoding the 62 RPO's listed.
I was able to decode all but 11 of them. I was surprised as to how many changes had been made to the truck since the factory. The SPID showed it originally was a 4.3 automatic 3 speed with OD and a roof rack. After reviewing I the list closer I started to question the decoder list I was using. Maybe it was for a different year or brand of GM vehicles. Then I got smart and compared the VIN number on the SPID to the one on the truck and found they don't match!
I guess someone swapped glove boxes or dash boards at some point.
Oh well it kept me amused for an hour.
RIP Bob Parks.
Old 05-19-2024, 07:22 PM   #11
HO455
HO455's Avatar
Having driven the new Blazer for a couple hundred miles now I've identified some things that need correcting.
The console has been covered with vinyl to match the seats and door panels. There is a chrome trim piece around the shifter that I don't believe is factory. However the console isn't bolted down and when it is centered on the shifter you can't lay the rear seat flat as the top of the seat hits the console preventing the seat from laying flat. (Photo #1) And if you move the console forward so it clears the seat back the chrome trim then prevents the shifter from going into the even numbered gears. (Photos #3) Grrr!
This will take some figuring out my part to find a clean solution. After close to 20 years of always having the seat folded flat in the old Blazer I'm not going to start going around with the seat up now.
The truck also has quite a few rattles to trace and fix and the drivers side door takes too much effort to shut. And I need to locate a spare tire. One of those space saver spares that is
Then when I when to change oil, the filter I got for the 2.8 V6 didn't fit. Another PO inflicted problem?
RIP Bob Parks.
Old 06-07-2024, 03:45 PM   #12
HO455
HO455's Avatar
Spent a couple hours cleaning and doing some little projects on the Blazer. I replaced the faded marker lights with my freshly cleaned marker lights. Woo hoo!
Then I removed the woofer speaker that was living behind the drivers seat just being a invitation to drug addicted thieves. (Photo #3 ) Besides the big mess of wiring which I couldn't stand. It was preventing the rear seat from folding flat. (Photo #4 arrow ) Which for me is the default position. And it didn't work either. However during removal I discovered why. There was remote volume knob for the unit and its cable was smashed inside the drivers side seat track. It took more time to clean up than it did to remove the speaker and it's wiring. So before I completely removed the wiring I tested it and found that once the crushed wires were removed the speaker worked. Maybe I'll put in the WMB at some point. There's just no room in the Blazer for it.
Then I replaced several missing screws in the dash hoping to solve some the the rattles. That lead to me finding a unidentified metal component deep in the dash that is loose and hanging free to bang around. I didn't have time to tear into the dash deeper to get to it. I had promised to mow the lawn for the missus. Along the way of fixing rattles I discovered leftover pieces from a now gone Pioneer stereo and 12 disc CD player. More stuff to remove on another day.
RIP Bob Parks.
Old 06-09-2024, 11:25 PM   #13
HO455
HO455's Avatar
I decided to run the valves yesterday on the Blazer and got a pleasant surprise. Aftermarket roller rockers.
They have no names or other information on them and aren't as nice as the set of Harland Sharp rockers that I currently have on the shelf in the shop. But certainly nicer than factory stamped ones.
After measuring them I came up with 1:6 as the ratio. Set up with ARP Poly Locks but only 3/8 studs necked down to 5/16 threads on the top. Like the factory ones.
It's hard to get a accurate measurements of a rocker with just a caliper but I did comparison measurements on the H&S rockers that I know are 1:6's and I feel confident in the findings.
After reading my How to Rebuild LT1 & LT4 book (That came with the truck) on how to find TDC. (I know that should be a no brainer but I discovered that LT1s & LT4s don't have a timing pointer/indicator on the block or timing cover.) That's when I made my mistake after reading what the book said about an X on the balancer being at 12 o'clock to adjust the valves. Well my balancer is aftermarket and is degreed with TDC indicated and thus doesn't have an X.
I then made an ASSUMPTION that the factory X on the balancer was the same as TDC on my aftermarket balancer. Long story short it's not!
So when I finished most of the valve train was quieter but 3 or 4 rockers were now louder. As it was now after 9 pm I decided to sleep on the dilemma of the noisy valves. And in the morning I looked up a couple videos on how to find TDC on a LT1 and low and behold I discover that Gen II LT engines don't have a a keyway on the crankshaft or the balancer hub. So the balancer could be installed with TDC pointing anywhere!
REALLY GM!
So after some poking around the engine I believe that I was some 30 to 40 degrees off of TDC when I adjusted the valves which would account for most of them being okay. So now I either need to fabricate a pointer and after manually locating TDC install the pointer in the proper place. Or just adjust the valves again but this time with the engine running. I really want to have a proper pointer but in the short term adjusting the valves running is likely going to be best option.
So two nice surprises the rockers and the balancer. One of the benefits of the rockers is I can label them with a marker before I start adjusting to prevent confusion as I work through them. I also have a check list to mark off each one after I've adjusted it. (Pink note pad at top of the last picture.) Then I use a paint pen to mark each poly lock once adjusted
I know it's a lot of double checks but, invariably if I don't mark my progress as I go someone or something will come up and interrupt the job.
Another thing I do is to put a small line or dot on the push rod with the paint pen. (Green arrows in last photo.) That gives me a visual aid when I'm trying to find the zero lash point. I use one finger to move the push rod back and forth while watching the paint mark. When the paint mark stops moving I know l'm at zero lash as my finger is sliding on the push rod.
RIP Bob Parks.
