03-09-2024, 12:28 AM | #1 |
Info for manual throttle cable for '68 (not accelerator cable)
I have a manual throttle cable on my '72 K5 for use if I needed to throttle up my idle when using a winch for example. I was thinking of adding one to my 68 Suburban. The K5 has a cable operated accelerator but the '68 has a rod from the peddle to carb. Does anyone have an example of how the cable would connect? I had a manual throttle on my '58 3100 but that was almost 50 years ago and I don't remember how it hooked up. Any help would be appreciated.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
03-09-2024, 01:46 AM | #2 |
The Older Generation
Re: Info for manual throttle cable for '68 (not accelerator cable)
These threads have some info in them.... http://67-72chevytrucks.com/vboard/s...d.php?t=182074 https://67-72chevytrucks.com/vboard/...d.php?t=623772 (post #6) http://67-72chevytrucks.com/vboard/s....php?p=1505334 \http://67-72chevytrucks.com/vboard/s...d.php?t=130124 (post #7) .
03-09-2024, 09:32 AM | #3 |
If you end up going with the correct for 1967-70 manual throttle setup, I have this special throttle cable firewall clip I save from my 1970. I went with the 1971-72 throttle cable setup instead of the rod.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
03-09-2024, 07:13 PM | #4 | |
