Old 11-05-2015, 11:13 PM   #226
69trk
69trk's Avatar
Re: ls turbo build
Yes..comp 54-000-11.....557/.562 @114... recommended from Texas speed
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 11-06-2015, 01:15 PM   #227
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: ls turbo build
It should put down some power for sure! How must boost do you plan on running?
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 11-06-2015, 01:23 PM   #228
Crash'd Artwerks
Re: ls turbo build
We can only hope his reply is "All of it!". Hahaha!
Crash'd Artwerks is offline   Reply With Quote
Old 11-06-2015, 01:25 PM   #229
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: ls turbo build
He should meet his 800whp goal at about 18psi
Gage
Old 11-06-2015, 01:56 PM   #230
69trk
69trk's Avatar
Re: ls turbo build
On the street with pump gas around 10-12 lbs is what I'm thinking...track on e85 I'm not sure yet?
1.58- 60'
11.37- 1/4 @115.81
Old 11-06-2015, 01:59 PM   #231
69trk
69trk's Avatar
Re: ls turbo build
Anyone have any coating recommendations here In Oklahoma? Need to either coat all the hotside or wrap....depends on costs.. may leave the headers alone
1.58- 60'
11.37- 1/4 @115.81
Old 12-02-2015, 05:00 PM   #232
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: ls turbo build
Looking good. I like the aluminum downpipe. Glad I did mine that way too.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 12-02-2015, 07:44 PM   #233
Crash'd Artwerks
Re: ls turbo build
What's the reason for doing aluminum versus mild/stainless steel on the downpipe?
Old 12-02-2015, 07:47 PM   #234
boostedc10
boostedc10's Avatar
Re: ls turbo build
Who is this guy?
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 12-02-2015, 09:59 PM   #235
69trk
69trk's Avatar
Re: ls turbo build
Save a little bit on weight...
1.58- 60'
11.37- 1/4 @115.81
Old 12-02-2015, 11:34 PM   #236
Jon01
Jon01's Avatar
Re: ls turbo build
Looks good.
I'd run the DP further back or out the side, you're going to hate the drone.
What heads are on the motor?
FWIW, mine made ~650 on 8#.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's.
68 Charger R/T - #'s matching 440/auto car, 499/727/3.91.
68 GTX - 440/4-speed, Dana 60. 44,000 miles.
71 SWB C10 - LQ4+S476r
06 Duramax - LBZ - Exhaust, EFI Live, etc...
Jon01 is offline   Reply With Quote
Old 12-03-2015, 12:00 AM   #237
69trk
69trk's Avatar
Re: ls turbo build
It has a little bit of an angle facing down and out... if it's to loud I'll put a muffler on it...has 706 heads that have been worked.. kind of went overboard on everything for a bigger and better 427 ls for later.. here's a few picts with most of the ac stuff done..I'm getting close..still need some new valve covers, wires and a few small things..
1.58- 60'
11.37- 1/4 @115.81
Old 12-03-2015, 12:06 AM   #238
69trk
69trk's Avatar
Re: ls turbo build
Had to move dryer because of inner cooler.. but everything fits very nice...
1.58- 60'
11.37- 1/4 @115.81
Old 12-03-2015, 12:50 PM   #239
Wasted Income
Boosted Member
Re: ls turbo build
It's actually significantly lighter than a stainless downpipe / exhaust...and it's just badazz.
Originally Posted by boostedc10 View Post
Who is this guy?
Oh, herro round eye.
Turbo diesel
Old 12-06-2015, 10:01 AM   #240
low69chevy
low69chevy's Avatar
Thumbs up Re: ls turbo build
Originally Posted by 69trk View Post
Hotside about done
Nice progress hadn't seen this build in a while by any chance do you have any close up piks how u tied in the hotside pipes to the turbo trying to get ideas for mine similar to yours I like the way this one turned out cause both banks look pretty close in length I've seen some with the drivers side all the way to the passenger then the pass just with a 90 to the turbo and like the way this one turned out keep up the good work
low69chevy is offline   Reply With Quote
Old 12-06-2015, 10:13 PM   #241
69trk
69trk's Avatar
Re: ls turbo build
Thanks..I'll get some better pics when I pull the turbo off to wrap the hotside..
1.58- 60'
11.37- 1/4 @115.81
Old 01-19-2016, 03:29 PM   #242
prostreet1967
prostreet1967's Avatar
Re: ls turbo build
my hydraboost came in today.... just ordered my turbo... it's a borgwarner s475
What s475 did u go with?
prostreet1967 is offline   Reply With Quote
Old 01-19-2016, 05:21 PM   #243
fast70swb
Re: ls turbo build
69trk that is a nice looking truck. Just seen you live in bridgecreek I also live in bridgecreek. I'm building a twin turbo 70 swb now. But have a long way to go. Do you ever take it to the car shows in tri city when they have them?
fast70swb is offline   Reply With Quote
Old 01-19-2016, 07:36 PM   #244
69trk
69trk's Avatar
Re: ls turbo build
I went with the 1.32 ar Bws476 76mm
1.58- 60'
11.37- 1/4 @115.81
Old 01-19-2016, 07:37 PM   #245
69trk
69trk's Avatar
Re: ls turbo build
Small world.. I have not taken the truck anywhere in about 6 years..but plan on it this year.. I need to come check out your truck..
1.58- 60'
11.37- 1/4 @115.81
Old 01-19-2016, 07:52 PM   #246
prostreet1967
Re: ls turbo build
Ok, just curious I'm building similar with 1.1 ar
Old 01-20-2016, 08:48 AM   #247
mcbassin
Still Learning
mcbassin's Avatar
Re: ls turbo build
Very nice progress on the engine. Looking forward to hearing this puppy this year....hopefully....
mcbassin is offline   Reply With Quote
Old 01-20-2016, 12:32 PM   #248
fast70swb
Re: ls turbo build
Nothing to much to see yet but when i get something to look at i will let you know. Haha. I dropped the motor and transmission in for fitment and set the cab back on it so I can figure out where to mount the computer. Got the wiring harness all broken apart to build my own.. once that gets done then the frame goes for sand blasting and powered coating. Got rust to fix on the cab . I like the way your truck looks tho. .
Old 01-31-2016, 10:43 PM   #249
69trk
69trk's Avatar
Re: ls turbo build
Wrapped the down pipe and some of the hotside...also finished all the ac stuff....need valve covers, wires, turbo blanket, finish up the plumbing on the wastegates and 10an drain for the turbo..
1.58- 60'
11.37- 1/4 @115.81
Old 01-31-2016, 11:04 PM   #250
fast70swb
Re: ls turbo build
Looks good. Nice clean work. Can't wait to get to that stage..
