Old 12-28-2015, 02:33 AM   #226
tinydb84
tinydb84's Avatar
Re: 1961 Crew Max
A bit overkill....hahahha
David
Instagram: myfabguy
Old 12-28-2015, 10:36 AM   #227
2mas
Re: 1961 Crew Max
Hey,
Did some research on the hydraboost. Maybe you know this, but the hydraboost can be rotated so that the avcumulator will face the driver side instead of against engine. That will probably make it fit!
I'll have this tested soon👍
Your frame looks killer!
/Thomas
1965 c10 BBW LWB - Duramax
2010 Camaro SS - Whipple (721hp)
2017 Volvo V60 diesel-hybrid (233hp)
2008 volvo XC70 diesel
http://67-72chevytrucks.com/vboard/s...d.php?t=677577
2mas is offline   Reply With Quote
Old 12-29-2015, 01:42 PM   #228
Bomp
Bomp's Avatar
Re: 1961 Crew Max
Nice job on the frame stiffener.
I feel motivated every time I get an update on this build.
Bomp is offline   Reply With Quote
Old 01-03-2016, 02:52 PM   #229
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Re: 1961 Crew Max
Little more progress yesterday. Got all the rockers closed up and most of the rust repairs done along the bottom outside area. most likely when the cab goes back on we will cut out most of the inner floor to build a tunnel. We also made a center cab support that will have a new body mount to the frame. It seems like they should have put these in from the beginning. There is 72" from front to back cab mounts. We also kept warm by catching the seat on fire in the cab. Thanks CHIZZLER
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 01-03-2016, 03:18 PM   #230
Advanced Design
Advanced Design's Avatar
Re: 1961 Crew Max
Looks good Chizzler. Glad the seat fire didn't get out of hand.
Advanced Design is offline   Reply With Quote
Old 01-04-2016, 09:54 PM   #231
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 1961 Crew Max
Great work! Do you have to have a high tunnel and use buckets or will you be able to use bench type seats still?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-05-2016, 01:51 AM   #232
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
Right now the output shaft from the trans is at floor level. There will be a tunnel through most of the cab. Going to use early blazer bucket seats with some kind of console in the middle probably built into the tunnel. Going to try and use the rear seat from the d-max donor as it was a extended cab and folds up. Thanks
61-crew cab D-max
Old 01-17-2016, 11:46 PM   #233
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
Quick update. Cab is back on to start building tunnel and floor. Started by trimming firewall and making clearance. Had to add A piece at the top edge for the turbo shroud. Next we took a piece and rolled it to fit the new cut out in the firewall. Cut grind cut grind cut grind. Finally fits. Once that was tacked took and made a template out of cardboard for the second piece then transfered to metal. Overall fit is good. Tacked it in. We are trying to leave as much room as we can for pedals. Thanks CHIZZLER
61-crew cab D-max
Old 01-18-2016, 01:34 AM   #234
Bomp
Bomp's Avatar
Re: 1961 Crew Max
Having to cut into the firewall and reconfigure the tunnel takes time. Especially to make sure there is plenty of room for the pedals.
Looks clean, nice work.
Are you running heavier springs up front for the added weight of the motor and trans?
Old 01-18-2016, 09:41 PM   #235
Dieselwrencher
Re: 1961 Crew Max
That looks great! That was the biggest hurdle in my Vette. Trying to keep enough room for your feet and pedals.
Ryan
Old 01-19-2016, 06:29 PM   #236
winslowgoodwin
Re: 1961 Crew Max
awesome build!!
winslowgoodwin is offline   Reply With Quote
Old 01-24-2016, 11:46 AM   #237
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
Made it out to the shop yesterday. More tunnel and floor work. Making the tunnel round not square will allow it to be much tighter. I need all the room i can get for pedals. Overall fit is good with the new low back buckets. Plenty of room between for a console. We cut the section of floor out that was added to stretch it and will be building a better floor structure. You can see the turbo down pipe is right at the bottom corner. Going to get a aftermarket pipe and try to cut and turn it to pass over the frame right at the toe board. Its gonna be tight. Thanks CHIZZLER
61-crew cab D-max
Old 01-24-2016, 02:01 PM   #238
flashed
Re: 1961 Crew Max
Looks good .
flashed is offline   Reply With Quote
Old 01-24-2016, 03:26 PM   #239
Advanced Design
Re: 1961 Crew Max
Nice work on the transmission tunnel. Are you using a slip roll?
Old 01-24-2016, 09:56 PM   #240
65sub
65sub's Avatar
Re: 1961 Crew Max
Good looking tunnel Chizzler. What gauge sheetmetal are you using.
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 01-24-2016, 10:07 PM   #241
Bomp
Bomp's Avatar
Re: 1961 Crew Max
You aren't kidding. Don't think you could even get the tip of your pinky in there.
Looking good
Old 01-25-2016, 12:16 AM   #242
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
Yes. 4' slip roll.
Floor is 18 gauge.
Looking good
There is about 1" all the way around.
61-crew cab D-max
Old 01-25-2016, 12:17 AM   #243
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
Originally Posted by flashed View Post
Looks good .
Thank you.
61-crew cab D-max
Old 01-25-2016, 08:09 PM   #244
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: 1961 Crew Max
Great build.. Always enjoy the updates!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 01-26-2016, 12:52 AM   #245
Dieselwrencher
Re: 1961 Crew Max
Great work!
Ryan
Old 01-28-2016, 11:17 AM   #246
Luther Grimace
Luther Grimace's Avatar
Re: 1961 Crew Max
Chizzler you are doing great work. Tunnel and firewall look great. Just to let you know, I had Ken Wolkens do my harness work. I also had a reference of his do my ECM and TCM work. Cranked my engine this weekend and it fired off first try with a couple of wires.
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540
1992 Chevy K1500 Silverado ECSB
1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered
Luther Grimace is offline   Reply With Quote
Old 01-28-2016, 10:23 PM   #247
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
That is great. I would love to see some pics of how it all went together and what was needed to fie it off.
61-crew cab D-max
Old 01-28-2016, 10:33 PM   #248
namloc
namloc's Avatar
Re: 1961 Crew Max
Awesome work.Great to see progress .No matter what space always seems to be a premium when squeezing in all the needed go fast stuff.
The Snortin' Bull
namloc is offline   Reply With Quote
Old 02-01-2016, 12:11 AM   #249
CHIZZLER
CHIZZLER's Avatar
Re: 1961 Crew Max
Todays progress. We got the middle cab supports in place with energy suspension poly mounts and made a weld on mount. We started building a new floor support. The original pieces they welded in when they stretched it were not great. We came off the front to back floor supports and made a inner structure that now is closer to the middle and has a drop down under the driveline. We also added supports for the front bucket seats. The sheet metal was left long in the middle till we build the tunnel. CHIZZLER
61-crew cab D-max
Old 02-01-2016, 04:48 AM   #250
Grizz1963
Grizz1963's Avatar
Re: 1961 Crew Max
Well Chizzler, I just spent as long as it takes to go through all three your build threads.
And all I can say is Man, you are very good.
I love your vision and execution.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
