Old 07-06-2014, 01:20 AM   #251
Hankster
Hankster's Avatar
Re: 89 crew cab k20 4wd twin turbo cummins swap
Sweet!! Keep up the awesome work!
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 07-07-2014, 04:05 PM   #252
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
It sure does look awesome to not have the HVAC box under the hood! Your truck looks really sweet and clean. I feel for you in trying to keep it that way once you start driving it. No slam intended.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-08-2014, 02:17 AM   #253
kikkegek
kikkegek's Avatar
I had a good look at your engine bay....which is by the way pure eye candy! and I never knew one could route twin turbo's like this...isnt there a risk of one turbo pushing or pulling the other one? or do they sell these like a perfectly tuned couple? Never seen this before, su just curious
kikkegek is offline   Reply With Quote
Old 07-12-2014, 10:02 AM   #254
881ton
881ton's Avatar
Looks great!! I'm waiting to see this finished, awesome work keep it up!
ROB
881ton is offline   Reply With Quote
Old 07-12-2014, 11:07 AM   #255
eric28miller
eric28miller's Avatar
Thanks guys!
Yea the twins come as a tuned towing package for low end boost.
Sorry i didn't get back right away with more pics, been busy cleanin out grain bens.
Been spending most my time on the mountain of wiring, i'm slowly but surly gettin closer
It was a lot of work hiding all the wiring and tucking everything away neatly but well worth it! Gives the engine bay the nice clean simple look i'm going for
eric28miller is offline   Reply With Quote
Old 07-12-2014, 12:03 PM   #256
jlsanborn
jlsanborn's Avatar
Holy smokes there's just a little wire in there! The white loom is cool man but I think some white tape would clean it up even more on the ends and where you split into other runs. An electrical supply joint should have some Scotch brand phase tape that is high quality. Love this build!!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 07-14-2014, 09:41 AM   #257
carboncrew
carboncrew's Avatar
Getting that wiring cleaned up....as always, looking good
________________
My very own build
My tailgating ambulance
carboncrew is offline   Reply With Quote
Old 07-14-2014, 03:01 PM   #258
eric28miller
Thanks I never thought of using tape instead, i'll see what I can find.
Got the gauges done yesterday! I had some custom overlays made to match the autometers, then painted the needles and trim to match. Turned out great i'm really happy with them.
Old 07-14-2014, 03:24 PM   #259
MTCK
MTCK's Avatar
Those look great! Who did the overlays for you?
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 07-14-2014, 05:19 PM   #260
kikkegek
kikkegek's Avatar
looks freaking awesome!
Dont drive it man! Put it in a museum....its so clean!
good luck on the winring...and love how the gauges look!
Old 07-14-2014, 05:19 PM   #261
Hankster
Hankster's Avatar
Those are sweet!
Current Build
Old 07-14-2014, 06:53 PM   #262
eric28miller
I ordered them from whitegauges.net They can make anything you want they're awesome! but pricey for custom stuff..
The overlays arn't perfect but from 2 feet away you'll never notice.
I also bolted the rpm gauge to the console shifter, made some good use of it anyway..
Old 07-19-2014, 09:17 AM   #263
1969x11
Did you have to cut the floor pans down to use the Ford seats? Do you have any interior pics? I am going to try and use the King's Ranch seats in my crew and was wondering how much work was involved. Thanks a ton!!
1969x11 is offline   Reply With Quote
Old 07-20-2014, 10:53 AM   #264
eric28miller
nope i didn't have to cut the floor pans, kept them original in case i wanted to throw the bench seats back in. For the front seats I just drilled new holes, modified the brackets a bit and they bolted right in, but the rear seats were not easy. I welded in plates across the pan that matched the bolt pattern on the seats. Wish these truck cabs were just slightly longer, not much rear leg room.. I thought about using my parts cab to make this a mega cab or 6 door but didn't want to sacrifice turning radius. I don't have any recent pics but there should be some in the beginning of this tread somewhere
Old 07-20-2014, 10:58 AM   #265
eric28miller
yep halfway down page 4 shows the seat brackets
Old 08-03-2014, 04:56 PM   #266
eric28miller
Been workin like crazy on the little white giant, finally took it on it's first voyage last night! Drove it to town, rode like a wet dream! Got to the bar and there was coolant leakin inside and outside, oil puked everywhere, and the shut off solenoid shorted out internally..
Everything was fine on the first little test spin but then again it never got real warm and rpms stayed pretty low.
Got her back to the shop last night and this morning i fixed most of the oil leaks, still have a few, and all the coolant leaks. Regular hose clamps are not strong enough for steel braided lines.
Took it back out for about half n hour today, rides like a half ton and steerings like a golf cart, but my left leg is going to be twice the size of my right! Gears are tricky to find, the new shift forks are pretty tight but float in and out pretty easy with no clutch.
I noticed boost would only climb to 20psi at first and as i drove it boost would climb higher with every few spools. I'm still takin it easy yet but i'm guessing the turbos won't fully spool until they're broken in.. Again i'm still a greenhorn here.. Last night was the first time i've ever driven a cummins powered pickup..
Anyway heres a few pics after i washed the pig up on my lawn, i still have quite a few things to button up so don't get too nit picky on me lol
Old 08-03-2014, 05:02 PM   #267
eric28miller
[URL=http://s1030.photobucket.com/user/eric28miller/media/Cummins%20swap/20140803_132331.jpg.html]
My wife bought me a surprise trip for my 26th birthday tomorrow so I won't be able to reply for a week.. No idea where were goin til we get to the airport terminal, but you can guess what i'll be thinkin about all week : )
Old 08-03-2014, 05:42 PM   #268
WillieloRidez
WillieloRidez's Avatar
Nice work man the truck looks killer!
WillieloRidez Drive em in Drag em out!
Projects:
1956 Chevrolet 210 2dr post
58 chevrolet 2dr delray
58 chevrolet belair 4dr hardtop
1965 Chevelle big block 4spd
88 crewcab 1/2 ton long bed aka STRETCH Lt1-4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=388445
WillieloRidez is offline   Reply With Quote
Old 08-04-2014, 12:45 PM   #269
hardcore4life
hardcore4life's Avatar
Damn! That truck looks awesome!
68 C10 lwb, 406 sbc, 700R4
86 K30 srw, 454 bbc, TH400
11 Camaro RS, 217 V6, 6M
hardcore4life is offline   Reply With Quote
Old 08-04-2014, 12:56 PM   #270
Low Elco
Bad. Ass.
Low Elco is offline   Reply With Quote
Old 08-11-2014, 07:50 PM   #271
Dieselwrencher
It looks awesome! Are your gauges on your dash pad hard to see? Your turbos shouldn't require any "Break in". You may want to check for boost leaks or check to see what your waste gate(s) are set at. If your fueling is too low that can add to low boost as well.
Ryan
Old 08-12-2014, 02:02 PM   #272
eric28miller
Hey i'm back, Thanks guys!
I think they're getting plenty of fuel, lots of black smoke with the pump turned up. I'm hitting 45 psi now, actually blew a clamp off the other night.. How do I check where the waste gate is set at? Or for leaks when it's not under boost?..
So I only have 30 miles on the truck and it started leaking oil real bad from the front of the motor. One step forward is always 2 steps backward with this thing. As it turns out the bolt came loose for the fan pulley and wore through the timing gear cover! The gears look to be ok, but the cover is junk which was customized for the adjustable pump gear cover.. So I had to dip back into my savings and buy a billet timing gear cover from ZRM Enterprises.. Hopefully it'll be here before we leave for Scheid next week.. I would like to get more miles on it before the long haul..
Old 08-12-2014, 06:11 PM   #273
Dieselwrencher
Dang that stinks! To check your waste gate you need to use an air pressure regulator and hook shop air to it. Start at 0 and adjust the regulator slowly until you see the actuator move. Make sure you are able to watch the air pressure gauge on the regulator while observing the actuator. Do you have internal or external gates, I can't remember?
Ryan
Old 08-13-2014, 01:05 PM   #274
eric28miller
There's an internal waste gate on the smaller turbo and nothing on the larger one, but i'm guessing the smaller phatshaft needs to open up when the larger s474 spools up. I try calling industrial injection but I can never reach anybody.. A few threads on the cummins forum said they had to drive a couple hundred miles before the turbos were broke in? I've never heard that before. What are you running for boost on your set up?
Old 08-13-2014, 02:30 PM   #275
Dieselwrencher
I wouldn't believe what most of those guys on cummins forum say. There are bronze bushings and chrome moly sealing rings in the turbo center section as well as a bronze center bearing and a steel sleeve the turbine shaft goes through. These pieces may loosen up after some wear, but I wouldn't call that break in per say. S300's all seem to become pretty loose compared to holsets and garretts from what I've noticed. Haha Anyhow, You should still be getting the normal amount of boost from the secondary unless they have some monster turbine housing on it. If it's a phat shaft is it a 64/71 or a 62/71 and do you know if it is a .80 or .83 ar? The turbos I have on my car, the secondary is gated to start opening at 20psi and have it fully open at 25psi. It'll still make over 70psi not WOT with the modified 75mm GT4294. I'd first try to see what your internal gate is set at and make sure you have no boost leaks. Make sure you have o-rings on your compressor housing outlets as well.
Ryan
4wd, c/k 30, crew cab, cummins swap, twin turbo
